Keyless entry conversion when electric locks already there?
Discussion in '1st Gen. Tacomas (1995-2004)' started by nchiker1, Dec 15, 2020.
  1. Dec 15, 2020 at 7:33 PM
    nchiker1
    nchiker1 [OP] Well-Known Member
  2. Dec 17, 2020 at 8:07 AM
    nchiker1
    Bump for exposure.
  3. Dec 17, 2020 at 8:22 AM
    reallifeonhold
    reallifeonhold Well-Known Member
    Travis
    2004 4WD 5MT
    I was going to install this kit (https://www.amazon.com/gp/product/B07L4LTXSK) but when I started digging into the kick panel I found that I already had the factory 3200 module that had not been activated. I was able to get a new fob from the dealer and, after Toyota's crazy pairing routine, everything worked perfectly. Also did the "free alarm mod" while in there. I have a GBS (glass breakage sensor) on-hand to install but haven't attempted that yet.
    Picked up this fob as a spare but haven't tried pairing yet so I can't guarantee compatibility: https://www.amazon.com/gp/product/B01HDY5EWE
    nchiker1 [OP] likes this.
  4. Dec 17, 2020 at 9:02 AM
    sneaky4WD
    sneaky4WD Member
    2000 White 4WD TRD Ext Cab
    3" lift, 305/70/16s, AllPro Baja Bumper
    The thread you linked implied that any 2004 truck with power door locks has the capability to pair with a fob, even if it doesn't come with one. I don't know if that is true, but you could start with looking for the RS3200 module, as was said above me could be found in the driver's kick panel. If you're going to add a keyless entry system (assuming you do not have the module) I'd recommend a system made by Viper, or any company that is owned by their parent company DEI/Directed. I wouldn't trust a cheaper unit to be connected to my central locking system, or to not drain my battery over time due to poor design. I have the Viper 3100, basically the cheapest system available from them, and the only complaint I have is that connecting/disconnecting the battery WILL set the alarm off and you just gotta press the unlock button on the fob to get it to stop.
  5. Dec 18, 2020 at 5:38 AM
    nchiker1
    Awesome! What was the total cost for the fob from the dealer and for their pairing routine?
  6. Dec 18, 2020 at 7:28 AM
    reallifeonhold
    Travis
    2004 4WD 5MT
  7. Dec 20, 2020 at 4:59 AM
    nchiker1
    reallifeonhold likes this.
