Keyless Entry For 2016 2017 Tacoma SR SR5
Discussion in '3rd Gen. Tacomas (2016+)' started by HarlanBFlorida, Oct 26, 2017.
  1. Oct 26, 2017 at 8:06 PM
    HarlanBFlorida
    HarlanBFlorida [OP] Member
    Clearwater
    2017 Tacoma
    Trying to figure out how to add keyless entry to your SR or SR5, look no further!
    I was tired of unlocking my door with my key, i know its miserable and i couldn't find any links or forums really going into detail on how to do it. Hope this helps!
    Total Cost : $124
    First off you need to make sure you have power locks.
    Here is the Product i purchased, its inexpensive OEM and works great.
    https://www.ebay.com/itm/Toyota-Key...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
    Once you have the product, it can be tricky to install. I attached Factory Directions to help with the process.
    https://cdn.shopify.com/s/files/1/0176/5842/files/00016-32901_16ta_TOYOTA_MCDONOUGH.pdf
    CAUTION this product isn't an easy plug in & you're done. You will have to use T-Taps, remove panels, and cut & strip one wire (easier than it sounds). Mounting the receiver isn't difficult, i suggest starting the kicker panel wires first, then mounting the receiver, then proceeding to do the wires under the steering wheel.
    You'll need tools
    Philips screw driver
    Ratchet
    10mm socket (I used a long socket)
    Pliers
    Needle Nose Pliers or Electrical (to strip wire)
    *There are two Philips screws holding the lower steering panel, they must be taken out before you remove the panel. The Instructions make it hard to see. They're easily accessible when you turn the steering wheel to the left 90 degrees and right 90 degrees.
    Let me know if you have any questions!
  2. Nov 8, 2017 at 4:46 PM
    Dr. Mantis Toboggan
    Dr. Mantis Toboggan Well-Known Member
    2017 TRDOR 4x4 & 2000 TRD TACO 4x4
    I’m strongly considering giving this a shot. Wiring is not my strong suit though.
  3. Nov 9, 2017 at 2:04 PM
    mmatheny
    mmatheny Well-Known Member
    Dickinson, Tx
    2017 SR5 DCSB Magnetic Gray Metallic
    BakFlip MX4
    I'm confused - your SR5 didn't come with keyless entry?
    TacoCon and synaps3 like this.
  4. Nov 9, 2017 at 5:14 PM
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
    Does your horn beep when you lock and unlock your car? Or do you get that audible beep?
  5. Nov 11, 2017 at 2:46 AM
    HarlanBFlorida
    Clearwater
    2017 Tacoma
    Dr Mantis Toboggan definitely consider it, made my life a whole lot easier. I can help you along the way if need be.
  6. Nov 11, 2017 at 2:49 AM
    HarlanBFlorida
    Clearwater
    2017 Tacoma
    My taco is an SR, I had a buddy work out a stellar deal for me and the truck didn't have the convenience package. Although it didn't matter, i was able to add key-less entry, cruise control, and intermittent.
  7. Nov 11, 2017 at 2:51 AM
    HarlanBFlorida
    Clearwater
    2017 Tacoma
    It sounds like the horn but a different tone, for example it sounds like the factory alarm system, along with the tone, the lights blink as well etc. etc.
  8. Nov 30, 2017 at 8:15 PM
    schultzj01
    schultzj01 Well-Known Member
    San Diego
    2017 DCSB SR 4x4 MGM
    Parts are in and will be installing it this weekend. Not having a remote to unlock the doors was a big inconvenience. Still surprised that a 2017 car doesn't have this as a stock, from the factory, item.....
    Does anyone have pictures of the completed install? I am curious to see were you tapped into the wires from the car's harness.
    HarlanBFlorida [OP] likes this.
  9. Dec 2, 2017 at 10:46 AM
    schultzj01
    San Diego
    Installed today. Pretty straight forward job and it works like a champ!
  10. Dec 2, 2017 at 8:02 PM
    HarlanBFlorida
    Clearwater
    2017 Tacoma
    Awesome! sorry i wasn't able to respond in a timely fashion. glad it worked out for you!
  11. Dec 2, 2017 at 9:23 PM
    schultzj01
    San Diego
    Actually just noticed the high beams kick on and not the tail lights. Verified the connection is in accordance with the instructions. Did you have this issue too?
  12. Apr 14, 2018 at 6:33 PM
    Mojlnir
    Mojlnir Well-Known Member
    Parker, CO
    2018 SR ACLB Utility Pkg
    Just finished my 2018 SR w/ Utility Package - everything works as advertised, no changes from the 2016 SR instructions provided.
    A big Thanks to the OP!
    Claudiomartinof likes this.
  13. Apr 14, 2018 at 9:19 PM
    schultzj01
    San Diego
    Do your high beams turn on when locking/unlocking?
  14. Apr 15, 2018 at 5:44 AM
    Mojlnir
    Parker, CO
    No. I deliberately left the headlight/taillight wires unconnected...never have been a fan of letting everyone know when I lock or unlock my vehicle. I did hook up the horn and it's about half the volume of when I press the horn button ( not sure why) so I don't mind.
  15. May 11, 2018 at 3:54 PM
    brodys16sr
    brodys16sr Well-Known Member
    Brody
    Charlotte, NC
    2016 metallic tacoma sr double cab
    Thank you mod! Just installed on my 2016 sr works perfectly!
  16. May 24, 2018 at 6:33 AM
    skaufma0
    skaufma0 Member
    Rock Hill, SC
    2018 Silver Tacoma SR
    Looking at doing this with my 2018 SR. How do I know if I need to install the whole module or just have to program a remote?
  17. May 25, 2018 at 4:31 PM
    brodys16sr
    Brody
    Charlotte, NC
    I did this on my 2016 SR and bought the part that is linked by the OP and followed the directions in the other link, worked perfectly. No extra programming.
  18. May 26, 2018 at 6:07 PM
    beartrap
    beartrap New Member
    2017 Tacoma SR Access Cab
    Does anyone have a photos of the install? I'm mostly curious about the locations of where the wires get tapped/spliced.
    This will be for my 2017 SR Tacoma it just drives me crazy that you can't unlock the door(s) from the passenger side. Thanks to other posts I've already installed the intermittent wiper and cruise control switches.
  19. Jun 5, 2018 at 12:10 AM
    dxlusby84
    dxlusby84 Member
    I just ordered this kit for my new 2018 Tacoma SR Utility. I will try to record my installation when it gets in. I'm also going to try integrating a flip key that shares the FCC ID of the kit so i dont have a separate fob. I'm an amateur, though, so don't expect greatness :)
    magicgus323 and Claudiomartinof like this.
  20. Jun 5, 2018 at 8:25 AM
    facefirst
    facefirst Well-Known Member
    Geoff
    Cleveland, OH
    2017 MGM TRD Off Road DCSB
    So you still need to put the key in the ignition to drive, correct?
    Do they make a keyless entry push start aftermarket option?
    Why I ask is that my wife has an ‘18 4Runner OR that doesn’t have keyless entry or push start. I figured if there’s an option for he Tacoma then there’s probably one for the 4R. I found one option but after a month they still never replied back. I hate to think what will happen if I buy it and have an issue.
