Keyless Entry Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by poornavyguy, Oct 2, 2009.
  1. Oct 2, 2009 at 2:14 AM
    poornavyguy
    poornavyguy [OP] Active Member
    Rich
    Great Lakes, Il
    07 Indigo DCSB TRD Offroad 6 Speed
    Hey fellas. Im kinda new to the site and I have searched with no joy. My question is...I just purchased a 2007 DC 4x4 6 speed trd offroad and it only came with one key and no keyless remotes. The dealership says that it doesnt have keyless entry but from all of the information I have been researching it has to have keyless entry. Is there anywhere I can look to confirm this? It has the overhead temp, cruise, intermittent wipers, and sliding rear window and according to the info I have found this is all part of the SR5#2 package along with the keyless system. There is a little red light that blinks next to the steering wheel also. Thanks in advance for the help!!! Rich :cheers:
  2. Oct 2, 2009 at 7:03 AM
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
    What fender flares do you have?
    In theroy, all that stuff COULD be added to a base - at a great expense, but still...
  3. Oct 2, 2009 at 7:10 AM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    If it's a TRD it should have key less remote.. As for what to do, You can go to the dealer and get a spare key from your Vin. But expect to pay $100 or so.
    but you can get the key fob, and key blanks here. https://www.ikeyless.com/vehicles/toyota?gclid=CNqtrKHfm50CFVRM5QodwDgT8A
    as for prgraming them, there are instructions soewhere on this site. But call a Toyota dealer, ASk tell them the situation, And see if they can tell if you have the key les entry option.
  4. Oct 2, 2009 at 9:38 AM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    if you have the overhead temp, you have keyless entry. go find a set of keyless entry fobs on ebay or somethin similar (doesnt need to be a Tacoma one.. Toyota uses the same one for a lot of cars) and i bet a bit of research could prove how to program it yourself
  5. Oct 2, 2009 at 7:08 PM
    poornavyguy
    Rich
    Great Lakes, Il
    sweet thanks guys I thought so. It just seems too loaded not to have keyless. It does have color coded fenders also. I bought a fob so I will try it out once it arrives. Thanks again fellas!!!! Rich
  6. Oct 2, 2009 at 7:31 PM
    06dak
    Central Ohio
    Also check the board here... I just bought one for $15!!!
  7. Oct 2, 2009 at 7:41 PM
    JeffRock
    Capital region, NY
    Found this on tundra solutions
    1. Driver door open and unlocked. Key out of the ignition
    2. Insert the key and remove 2 times in 5 sec.
    3. Close and open driver door 2 times in 40 sec.
    4. Insert the key and remove it again from ignition.
    5. Close and open driver door 2 times in 40 sec.
    6. Insert the key in ignition,
    7. Close the door,
    8. Turn to on and back to lock in 1 second intervals. 1 time for add, 2 times for rewrite, 3 for confirmation 5 for prohibition. (yes, there is no “4”)
    9. Remove the key
    10. Power lock will cycle to confirm
    11. For add or rewrite mode within 40 sec of the confirmation,
    A. press “lock” and “unlock” buttons of the FOB at the same time between 1 and 1.5 seconds.
    B. within 3 sec press “Lock” button for more than 1 sec and release.
    C. If it’s correct, the power door lock will cycle once. If it’s wrong the door lock will cycle twice.
  8. Oct 5, 2009 at 3:45 AM
    tateh
    tateh Member
    Georgia
    '05 Tacoma 4x4
    that code worked for my tacoma, 2005 model
  9. Oct 5, 2009 at 3:49 AM
    YaKkO
    YaKkO Active Member
    Tim
    Oklahoma City, OK
    08' Pre-Runner SR5
    Thats a good start point on figuring it out but I dont have over head temp and I have keyless entry?
  10. Oct 5, 2009 at 3:51 AM
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    I had to program my keyless remote, took a few tries but now all is good. Got the remote from ebay.
  11. Oct 5, 2009 at 2:04 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    I'm a prerunner SR5 with a v6, and i have keyless. If you have the SR5 package, you should have keyless.
  12. Jun 6, 2010 at 6:21 PM
    timothyvasquez
    timothyvasquez New Member
    timothy
    austin tx
    prerunner 08
    20 inch rims,side bars
    I just bought a used 2008 V6 Taco Pre-runner, it did not come with a keyless remote, I bought one from a site online, its the correct FDC code on the remote that matches the owners manual, but the instructions that it came with does not work, any sugguestions?
