Keyless entry install help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iitywygms, Apr 7, 2013.
  1. Apr 7, 2013 at 11:10 AM
    iitywygms
    iitywygms [OP] Well-Known Member
    Norcal
    4x4
    Hi All:
    I will be installing a keyless entry into my 2011 base soon. I have been searching for clues. Basically which colour wire I should tap into for flashing the lights, dome light, and horn.
    No luck so far. Can anyone point me toward some post that contain clues?
    Does anyone know for sure which wires I should use?
    If there is a how to somewhere that would be great. If not, I will take some pics and post up what I find.
    Thanks to all.
  2. Apr 7, 2013 at 11:24 AM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Any instructions? It should be in the directions.
    I installed an alarm(in the past).PAIN IN THE ASS-LOL.
    The alarm website was VALUABLE-had all the info that was needed.
    Never installed the "horn" Just the engine disable.
    HAVE FUN.
    Just keyless entry? Check the manufactures website.
  3. Apr 7, 2013 at 1:26 PM
    iitywygms
    Norcal
    4x4
    The instructions I have say "attatch to vehicles horn wire, or dome wire, but do not specify which wire colour it is or where.
    The keyless system I purchased is a Avital 2101L keyles entry system, if that helps.
    One reason I am asking is because I know the Tacoma has a delayed dome light, which could cause issue with the install.
    edit
    I did find this.
    http://wiringinstructions.com/v2/wiresprint.asp?recnum=10339&printsubmit=PRINT
    2009 should be the same as the 2011?
  4. Apr 7, 2013 at 2:38 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    If it is keyless only and not an alarm, are you sure you REALLY want the horn honking at 5am when you leave to go to work? Nothing like announcing your arrival and departure to everyone.
    IMHO, the stock Toyota beep can be a bit annoying, but at least it's not going to bother the neighbors.
    For the dome light, there is a blue wire in the A-pillar. Ground it and the light will come on.
    Parking lights can be accessed on the back of the fuse box behind the change pocket.
  5. Apr 7, 2013 at 6:19 PM
    iitywygms
    Norcal
    4x4
    True. I may not hook up the horn.
    I will trace the blue wire to a location behind/near the dash and use that.
    Thanks for the help.
  6. Apr 8, 2013 at 4:34 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    GOOD POINT!!!
