Keyless Entry Issue...Sort of...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by danteisme, Mar 14, 2017.
  1. Mar 14, 2017 at 6:53 AM
    danteisme
    danteisme [OP] Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    I've had an issue come up just recently with my keyless entry on my 06. It's very weird, i searched but i didnt find anything like what i am experiencing. 8 or 9 times out of 10, everything operates as it should. But that 1 or 2 times out of 10, my front drivers door lock only won't respond to the keyless entry. The other 3 doors operate exactly as they should, but for whatever reason, my door either won't lock with the rest of them or it won;t unlock with the rest of them. Any ideas?
  2. Mar 14, 2017 at 6:57 AM
    Clearwater Bill
    Billy
    Largo Florida
    Do you have the same issue working the locks from the inside switch?
  3. Mar 14, 2017 at 7:00 AM
    speedjunkie13
    speedjunkie13 Well-Known Member
    a work in progress
    If it's only the drivers door that is occasionally not responding, then I would say it's probably the drivers door latch assembly starting to fail. Could possibly be the wiring to it as well.
  4. Mar 14, 2017 at 7:05 AM
    danteisme
    South Western PA
    Thats the weird thing, it operates fine from the inside switch.
  5. Mar 14, 2017 at 7:17 AM
    speedjunkie13
    a work in progress
    According to the diagrams it's the same ouputs to the latches regardless of whether it's getting the signal from the inside lock sitches, or from the FOB. since the other locks are operating, obviously it's recieving the signal from the FOB. which leads back to being either that specific latch, or the wiring feeding it. technically it could be the driver inside of the body control module, since it has a seperate output for the drivers door for only unlocking that door first. That would be the least likely to fail though. check the wiring in the harness in the door jam. years of flexing back and forth makes things break eventually and you would be surprised how little contact a wire needs to still function. If it was me, I would be checking the wiring for obvious issues, if it looked ok I would probably just throw a latch in it if they arent very expensive.
  6. Mar 14, 2017 at 7:24 AM
    danteisme
    South Western PA
    thanks for the info. next warm day i'll check out the wiring first.
