Keyless Entry Issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRD Taco Loco, Jan 12, 2018.
  1. Jan 12, 2018 at 2:10 PM
    TRD Taco Loco
    TRD Taco Loco [OP] New Member
    I have a 2015 TRD Off Road. My keyless entry has been acting funny for a couple of months. I would wake up in the morning and my remote would not work. I finally figured out that it would not work when it was cold overnight, mind you I live in Southern California. As soon as the day would warm up it would work just fine. This happens every cold morning without fail. Has anyone encountered this issue? Please help.
  2. Jan 12, 2018 at 2:17 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    To ask a very basic question, when was the last time you changed the battery?
    Have you opened the battery cover? I carry mine in my pocket and I have found lint in mine that has interfered with operation.
  3. Jan 12, 2018 at 2:19 PM
    sjwhitaker
    sjwhitaker Today Was A Good Day.
    Jake
    Berea, KY
    2010 DCSB TRD Offroad 6MT - Icon Stage 2 - 285/75/16 Falken AT3W
    I would definitely swap the battery out and see if that helps. Possibly carrying it around and shaking the battery gives it enough juice to work occasionally.
  4. Jan 12, 2018 at 3:00 PM
    TRD Taco Loco
    Thanks for the replies. I opened up both of my keyless remotes and changed the batteries on them and made sure they were clean. I even tried both of them one cold morning and neither of them worked. I'm wondering if it has something to do with the keyless remote receiver/sensor in the truck?
  5. Jan 12, 2018 at 3:24 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Isn’t your truck still under 3yr warranty since you have a 2015. Have the dealer check it out.
  6. Jan 12, 2018 at 3:27 PM
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    You don't know what Cold morning is California. It's currently -4 here right now, that's cold.
  7. Jan 12, 2018 at 3:42 PM
    sjwhitaker
    Jake
    Berea, KY
    Where is the receiver on these trucks? Under the dash? Other than the key fob I can't thing of what the issue would be aside from something blocking the receiver or a issue with the connection.
  8. Jan 12, 2018 at 3:49 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Is there an aftermarket alarm? Usually dealer installed alarm are piggybacked from the oem keyless entry.
  9. Jan 12, 2018 at 4:37 PM
    Muddinfun
    Muddinfun Well-Known Member
    Does the dome light come on when you push the key fob button?
  10. Jan 12, 2018 at 7:04 PM
    TRD Taco Loco
    It obviously doesn't get that cold in So Cal which is why this is weird. I took it to the dealer and of course it worked that time. Prob take it back on a cold morning when it doesn't work. I'm thinking it may be a loose connection. It does have an aftermarket dealer installed alarm. It's just bizarre that's it's clearly bc of the cold. Annoying as hell. Thanks again for all the input.
  11. Jan 12, 2018 at 11:11 PM
    JoefromPTC
    JoefromPTC Well-Known Member
    Joe
    Atlanta Georgia metro
    2005 Tacoma TRD Sport 4X4 6MT
    ^^^ This is probably the issue. My guess would be an inexperienced tech did a poor job with the wiring/splicing causing the intermittent issues.
