Keyless Entry Keypad review
Discussion in 'Product Reviews' started by Hardcorehehaw, Mar 1, 2009.
  1. Mar 1, 2009 at 7:02 PM
    Hardcorehehaw
    Hardcorehehaw [OP] 1 man wolf pack
    Evan
    09 Magnetic Gray PreRunner
    Debadged, 20" Liquid Metal Magmas, Yokohama Parada Spec x 285/50/20, Llumar clear bra, Fold-A-Cover G4, Weathertech liners, Wet Okole seat covers, JBS technologies keyless entry keypad.
    Here is my review of the JBS technologies Keyless Entry Keypad.
    I bought this item on eBay, they go for about $40 shipped. Not to shabby. :cool:
    http://cgi.ebay.com/ebaymotors/Wire...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
    Installation time: Under 2 hours
    Installation difficulty: Moderately easy, if you can use a test light, splice and make wire connections, you can do this.
    The hardest part is working in such a small area on the driver's floor board.
    Ease of use: A caveman can do it ;)
    The keypad itself comes with a 1 year warranty, is weather resistant and also completely wireless. JBS claims the batteries for the keypad will last over 5 years with normal use.
    It basically works like any aftermarket keyless entry system, except instead of a key fob, it uses the keypad with a 5 digit pin code.
    It is compatible with any vehicle that has power door locks and it does not interfere the stock keyless entry system.
    This unit is pretty much exactly like the keypads that come on some fords. It is capable of having 2 personalized 5 digit codes and it can both lock and unlock the doors.
    Free technical support is available as well as wiring diagrams and vehicle information for many different vehicles including 1st and 2nd gen Tacomas.
    I didn't use any of these and just sort of winged it and everything worked out great.
    After I installed the wireless receiver I took the keypad about 30 feet away to test it's range and I WAS able to lock and unlock the doors from that distance but not much further.
    Installation was fairly straight forward. There are really only 4 wires to hook up.
    Of course determining which wires are for the door lock switch may take a little bit of time. (The wiring diagram on bulldogsecurity's website was incorrect, they gave the wrong color code of the lock switch, however my truck is an 09 and my be different.) The locks are also reversed polarity which requires a different type of installation for the wireless receiver. Also the keypad needs to be reprogrammed before use for dual pulse locks. It's pretty easy to do and all the necessary information is in the instruction manual. Again start to finish installation and programming of the keypad took less than 2 hours.
    If anyone else is interested in the keypad I will do a complete write up on installation with pictures if it will help. But I didn't take any as I went because it was getting dark out.
    I have not yet mounted the keypad because I was trying to figure out the best location for it, I didn't want to put it on my door and take the chance of it messing up the paint so I'm thinking I will either put it on the inside of the gas tank lid or on the back of the hood near the windshield wipers. I'll post back with pics when I get the keypad mounted.
    The keypad works great and I highly recommend it. I'll never have to worry about getting locked out of my truck and if I want to go to the beach or somewhere and don't want to carry my keys I can just lock them safely inside the truck. It beats hiding them in the bed or gas tank lid, right?
    Here are some pictures of the wireless receiver installed:
    It's a pretty clean install, most of the wires stay hidden behind the kick panel. The yellow wire is the antenna.
    Here are a few possible locations for the keypad:
    I just put some scotch tape temporarily on the back. The keypad looks like it will sit flush when installed using the double sided tape.
    Backside of the hood:
    Inside gas cap, I didn't take the time to make it look good, but you get the idea:
    On the door, which I probably won't do:
    A few more locations...
    Behind the rear window:
    In the bed compartments:
    And very top secret, in between the cab and bed, you can't see the numbers so you gotta do it by feel, you really can't see anything:
    In plain sight on the mirror base, probably not smart, lol:
    HawkShot99 likes this.
  2. Mar 1, 2009 at 7:42 PM
    tacoholic
    tacoholic Well-Known Member
    East Bay, CA
    Can we get some pics of it on the truck? I'd like to see it "in action."
  3. Mar 1, 2009 at 8:12 PM
    trdracing5
    trdracing5 Well-Known Member
    Elizabeth City, NC
    2003 Tacoma SR5
    You can't get us all excited about this project and then not show us some pictures!!
  4. Mar 2, 2009 at 8:15 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    Definitely need to see some pictures but it appears the pad can be placed ANYWHERE. That is a great feature as I wouldn't want it on my door. I'd rather hide in a more inconspicuous spot, like inside the gas door or on the back of the cab (above the bed).
    I may have to drop the $40 to try this out.
  5. Mar 2, 2009 at 9:14 AM
    Hardcorehehaw
    Evan
    OK guys I added a few pics. Sorry if the quality isn't all that great, all I had available was my iPhone.
  6. Mar 2, 2009 at 10:10 AM
    weihenstephaner
    weihenstephaner Well-Known Member
    Atlanta, GA
    2009 4x4 TRD OR DC SB Mag Grey (SOLD)
    Bought a Tundra
    Nicely done. I'd mount it in one of the bed cubbies over the wheelwells.
  7. Mar 2, 2009 at 10:12 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Definitely hide the keypad...
  8. Mar 2, 2009 at 10:36 AM
    Hardcorehehaw
    Evan
    Anywhere in the bed is out for me because I'm getting a fold-a-cover that I intend to keep locked.
    I am still trying to figure out the best place to mount it.
  9. Mar 2, 2009 at 5:52 PM
    Buzzoff
    Buzzoff Don't go ninja'in nobody don't need ninja'in
    The Nickel/5th Ward
    09 Tacoma DC TRD Speedway Blue
    Blacked out windows, 5100's@1.75", KMC XD Hoss795 16x8
    Niiiiice!!!! You can beat a $40 mod!!!! How about putting the keypad under the rear window (drivers side)?
  10. Mar 2, 2009 at 6:20 PM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    I wonder if this can be used with the motorized pop n lock
  11. Mar 2, 2009 at 8:15 PM
    Hardcorehehaw
    Evan
    I thought about that but like I said I will be getting a fold-a-cover tonneua and don't know what kind of clearance that will have. Hopefully a lot because the cover is supposed to be very low-pro. I'll check that out tomorrow and post a pic.
    Anyone have any other possible ideas?
    It has an output wire for a trunk release, not sure what it would take to get it working though.
  12. Mar 2, 2009 at 8:18 PM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    Yes you can. My last aftermarket alarm had a trunk button that i made turn the lights off and on. as long as it needs an electric pulse, an alarm can do it for the most part.
  13. Mar 3, 2009 at 3:14 PM
    Hardcorehehaw
    Evan
    Added a few more pictures as well as a warning to those buying this...
    I'm going to have to send my keypad back to the company for replacement, I called tech support and they think my keypad is defective because it won't let me program a new replacement code in. I'm not sure if this is a common problem or not, but just thought I'd let everyone know.
  14. Mar 8, 2009 at 7:08 PM
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    any update for the company? are they sending you a new one? i really like this product but want to make sure its worth the money.
  15. Mar 8, 2009 at 7:26 PM
    Hardcorehehaw
    Evan
    I mailed the keypad back on Friday. I should know something in a few days and will post back when I do.
  16. Apr 6, 2009 at 6:38 AM
    Hardcorehehaw
    Evan
    Updated the the main post.
    The company sent me back the keypad and claimed there was nothing wrong with it. They left me a note and asked that I call them and they would walk me through the reprogram steps.
    I called them, they walked me through it and I was able to program a new code into it. The written directions weren't very clear.
    The keypad is working fine now with my new code. I still haven't mounted it on the truck yet, but I think I've decided inside the gap cap may be the best place for me.
  17. Apr 7, 2009 at 1:34 PM
    tacoholic
    East Bay, CA
    Cool! Good to know they cared enough to write a note.
  18. Apr 22, 2009 at 12:44 PM
    sapper987
    sapper987 Well-Known Member
    Seattle, WA
    2008 TRD SPORT DCLB Silver Streak
    3" Revtek with AAL 17' MotoMetal 955's 265/70 17 Nitto TG's Bed Mat
    So what's the new code? :gossip:
    (I'll be in Orlando this weekend on vacation)
    doublethebass likes this.
  19. May 5, 2010 at 11:41 PM
    joes06tacoma
    Joe
    Central Coast, CA
    How about an update on this product? Looks like it's been a year. Any problems to report?
  20. May 20, 2010 at 1:12 PM
    Chilli Taco
    Chilli Taco Senior Member
    NC
    2010 4x4 SR5 V6
    Toyota Front Bug Guard, Vent Shades, UWS Low profile Toolbox, Husky Floor Liners, Tacoma Rubber Bed Mat, 3 ball with tow hook trailer hitch, Nerf bars, EZ clamp on tailgate, overhead console with compass and temp, Transmission smoothness TSB, Rear 4 leaf spring pack TSB with 4 new Bilstein TRD shocks, Back up camera, JBS Keypad Entry, 2" blind spot safety mirrors, Leaf spring squeak TSB spacer discs,TSB AC/Heater Blower motor 04043, aFe Pro-Dry S Air Filter, Toytec AAL for TSB leafs, TSB redesigned headlights, GMC 5702KA Bulbs in DRL's, DRL switch mod, Illuminated 4x4 switch mod, 2010 4runner heated signal mirrors with puddle lights and 2013 Tacoma color matched mirror covers, bed lights, NOS GMC under hood reel light, TacomaWorld.com sticker on back window,fog lights on anytime mod, hidden ignition kill switch, TRD Skid plate painted black, TRD front recovery hook, console vault, Avid Off-road Light bar, 6" KC Daylighters
    Hey Hardcorehehaw,
    You posted that The wiring diagram on bulldogsecurity's website was incorrect, they gave the wrong color code of the lock switch, however my truck is an 09 and my be different.
    I just got one of the key pads and I have a 2010 doublecab. What did you find was the correct color code for your truck? I'm pretty sure an 09 and 10 would be the same.
