Keyless entry on SR
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dayriesw, Oct 3, 2016.
  1. Oct 11, 2020 at 6:23 PM
    #41
    caribe makaira
    Caribbean, Puerto Rico
    Usually an unlock/lock signal is tied into the Hazard switch so the turn signals flash (front & rear) not the tail/parking ones...
  2. Oct 11, 2020 at 6:28 PM
    #42
    caribe makaira
    Yes #18 it TAIL (green).
  3. Oct 11, 2020 at 6:30 PM
    #43
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    I thought so as well but they want #18 to flash. Is there a pin for the hazards? I’d assume not but there might be a pin that corresponds to turn signals.
    Here’s how they instruct me to tap:
  4. Oct 11, 2020 at 6:37 PM
    #44
    caribe makaira
  5. Oct 11, 2020 at 6:44 PM
    #45
    caribe makaira
    @kmorgan3 , tomorrow when you remove the terminal from the tap crimp, place a jumper to crimped T -tap ground to test. Maybe the remote key module is not providing the required ground.
  6. Oct 11, 2020 at 6:49 PM
    #46
    kmorgan3
    Kyle
    PNW
    Excellent. I’ll try to tap one of these. I’m not familiar with this plug - do you generally know where it’s located?
    edit: actually I think it’s just the hazard switch running to the dash display. Sorry it’s kind of hard to decipher.
    I will give that a shot tomorrow. I definitely think it should be flashing the hazards and not my tail lights. Never seen a truck flash tail lights. I tested my girlfriend’s 4runner and it flashes the hazards.
  7. Oct 11, 2020 at 7:14 PM
    #47
    caribe makaira
    If you remove the radio, it's below
    upload_2020-10-11_22-12-14.jpgupload_2020-10-11_22-14-4.jpgupload_2020-10-11_22-14-15.jpg
    kmorgan3[QUOTED] likes this.
  8. Oct 11, 2020 at 7:17 PM
    #48
    kmorgan3
    Kyle
    PNW
    Will report back tomorrow. Thank you so much for the help!
  9. Oct 11, 2020 at 7:18 PM
    #49
    caribe makaira
  10. Oct 12, 2020 at 9:02 AM
    #50
    kmorgan3
    Kyle
    PNW
  11. Oct 12, 2020 at 11:10 AM
    #51
    kmorgan3
    Kyle
    PNW
    An update: I got the low beams to turn on when I unlock the truck, but the light stalk must be in the "off" or fully "on" position. If the stalk is in "DRL" the low beams won't turn on. I think this is now working as designed because on other vehicles the lights don't turn on with OFF/ON keyless inputs unless the lights are toggled by the stalk.
  12. Oct 12, 2020 at 11:47 AM
    #52
    kmorgan3
    Kyle
    PNW
    Does A33 connect directly behind the 4WD shifter? I don't see a connector directly behind the hazard switch. The connector behind the 4x4 selector is black but doesn't seem to match the pin-out map you provided.
  13. Oct 12, 2020 at 4:31 PM
    #53
    caribe makaira
    No...to opposite side...
  14. Oct 12, 2020 at 4:39 PM
    #54
    kmorgan3
    Kyle
    PNW
    :facepalm:found it thanks. I’m going to try the hazard light tap here in a second.
  15. Oct 12, 2020 at 5:01 PM
    #55
    kmorgan3
    Kyle
    PNW
    Alright I tapped into pin 4 and it looks like this project is a wash. The module does not pulse as described. Rather, it sends a constant signal for 30 seconds so the hazards are on for 30 straight seconds. I tested the module independent of a wire tap and can’t seem to get it to pulse - just straight signal for 30. What a bummer! Thank you for your help, but short of getting a new module I’m not sure what can be done here.
  16. Oct 12, 2020 at 5:15 PM
    #56
    caribe makaira
    Maybe they skimped on programming. Tied it into the same pin to maintain headlights ON, so you can walk away with illumination. That sucks:(.
    So back to TAILS/PARKING. (with Stalk on ALL OFF). Illumination for 30sec in the rear also...:bored:
  17. Oct 12, 2020 at 5:17 PM
    #57
    kmorgan3
    Kyle
    PNW
    Well at least now it’s just low beams and tails on for 30 sec and not high beams that will melt me as I walk away. Thanks again! :cheers:
  18. Oct 12, 2020 at 5:21 PM
    #58
    caribe makaira
    :thumbsup:
    they sell relays that can provide a timed connection with a steady input...but that's adding a feature the module should've had...
  19. Oct 12, 2020 at 5:31 PM
    #59
    kmorgan3
    Kyle
    PNW
    Can you recommend one that might work for this application? I was already thinking perhaps I should find a way to put an inline module there.
  20. Oct 12, 2020 at 5:34 PM
    #60
    caribe makaira
