Keyless entry on SR
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dayriesw, Oct 3, 2016.
  1. Oct 12, 2020 at 6:21 PM
    #61
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    I had no idea this resource existed! This is awesome. I'll see what I can do. I might have to hold-off on the project for a bit (work is picking up), but will loop you in with my rough draft. I'm not very good at reading circuits, but will give it a shot.
    I am assuming these blue lines mean to bridge these connections (circled in red):
    What is the black bar those blue lines are connected to?
  2. Oct 12, 2020 at 6:24 PM
    #62
    caribe makaira
    Caribbean, Puerto Rico
    You are correct. Diode between the relay pins.(Black bars)
  3. Oct 12, 2020 at 6:30 PM
    #63
    kmorgan3
    Kyle
    PNW
    So a diode between each bridge? One diode between my bridge of 85 to 87 and then the same for the other side?
  4. Oct 12, 2020 at 6:33 PM
    #64
    caribe makaira
    PM ya...it's not what's required...
  5. Oct 12, 2020 at 8:24 PM
    #65
    caribe makaira
    After knowing the HORN tap only allows for a brief honk, the sane n cheap solution is to use same tap for flashing the turn signals tapping the Hazard switch.
    Edit: The brief honk is NOT enough time to activate the hazards...and especially if the headlights are aftermarket...:boom:
    I think that having the rear illuminated for as long as the low beams (30 sec) are isn't that bad.
    kmorgan3 likes this.
  6. Oct 12, 2020 at 8:25 PM
    #66
    kmorgan3
    Kyle
    PNW
    Thanks for helping me hash it out! I’ll give it a shot tomorrow.
  7. Oct 12, 2020 at 8:29 PM
    #67
    caribe makaira
    No problem...:thumbsup:there might be others with same issue...:burp:
  8. Oct 12, 2020 at 8:42 PM
    #68
    kmorgan3
    Kyle
    PNW
    Perhaps we would want to use a diode to prevent the hazards from turning on when honking the horn and vice versa?
  9. Oct 12, 2020 at 8:59 PM
    #69
    caribe makaira
    Yes indeed...:frusty:
