Keyless remote stolen want to disable keyless entry
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thermann, Jan 27, 2018.
  1. Jan 27, 2018 at 4:44 PM
    thermann
    thermann [OP] New Member
    Tim
    2006 Tacoma TRD Sport
    Stock
    Sob story...I used just my key to get in and out for the last 10 years. The week I used the keyless remote I left it in the truck and that was the first time someone stole stuff out of my truck. They got my wallet, my garage door opener and my keyless remote.
    Is there a way to disable the factory keyless entry?
  2. Jan 27, 2018 at 4:52 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Should be a datalink pin connector under the dash, I believe if you reset it, it’ll clear all the remotes that have previously been programmed to it. Don’t have the details but should be link two of the pins together (ground pin and one other pin - not sure which one though) with a wire should reset it.
  3. Jan 27, 2018 at 8:59 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I would worry more about them having my wallet and garage door opener.
    Address and entry through garage...
    Why would you leave your wallet in the truck?
    CurtB likes this.
  4. Jan 28, 2018 at 8:32 AM
    thermann
    Tim
    Stock
    Tcomaboy Thanks, I will give that a go if I can figure out which pins
  5. Jan 28, 2018 at 8:34 AM
    thermann
    Tim
    Stock
    I don't take my wallet or things with batteries in them when I go surf. 1st time its happened in 12 years with the truck, so I guess my luck ran out
  6. Jan 28, 2018 at 8:35 AM
    VTard
    VTard Well-Known Member
    2016 TRD Sport
    Definitely need to change garage code also! Sucks that some jackass stole from you...
