Keys
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoma1965, Sep 21, 2019.
  1. Sep 21, 2019 at 4:35 AM
    Tacoma1965
    Tacoma1965 [OP] Active Member
    Anthony
    98 tacoma 4x4
    3 inch lift. 2857017
    I have a 98 tacoma, it has 2 keys . 1 for door and 1 for ign. Are they anyway to have 1 key cut to do both?
  2. Sep 21, 2019 at 4:38 AM
    medic2230
    Murph
    Bama! Roll Tide
    You must have had either the ignition or the door locks replaced on your truck then.
    cruxofthebisquit likes this.
  3. Sep 21, 2019 at 11:36 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    yes pull the ignition cylinder have it rekeyed to fit the key for your door.
    Does the door key unlock both doors?
  4. Sep 21, 2019 at 11:37 AM
    Da Boogie Man
    Da Boogie Man Purple Nurple
    Seymour
    Also have your house keyed to match your truck doors.
    970btu, cruxofthebisquit and henryp like this.
  5. Sep 21, 2019 at 11:44 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I did just this built a custom lock for the house .
    The looks it gets is well worth all the fabrication when you hand them the key with only a Toyota key and say unlock the door
  6. Sep 21, 2019 at 1:32 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    This, a locksmith can rekey the locks.
    But keep in mind that the key a dealer would cut you from your vin would no longer work. So make spares.
  7. Sep 21, 2019 at 4:45 PM
    Tacoma1965
    Anthony
    98 tacoma 4x4
    Yes the key will unlock both doors. And the look alike..
  8. Sep 21, 2019 at 5:11 PM
    Vann
    Vann Well-Known Member
    Garth
    Weisenburg, PA
    '04 x-cab 4x4, 2.7 5sp. "The Black Pearl"
    stock
    Shoot, I thought this was about Florida
    970btu likes this.
  9. Sep 22, 2019 at 10:23 PM
    970btu
    970btu Well-Known Member
    Ty
    Las Vegas
    99 Tacoma 3.4 5spd ext limited TRD 55K and counting
    OME, SPC UCA, ARB w/warn 10K winch, TG Rock Defense Rear, Marlin Clutch, Custom hi clearance under bed spare mount. 285/75/16. A ton of repairs done and a list up to come modifications.
  10. Sep 22, 2019 at 10:56 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Go to a locksmith. They can rekey your ignition or door key to operate both locks.
  11. Sep 23, 2019 at 7:49 AM
    oogielaflick
    oogielaflick Well-Known Member
    Keith
    2019 Toyota Tacoma TRD Sport 4-door; Prvious 23 year owner of 1996 Tacoma
    Quicksand with hood protector, color matching decals on tailgate latch, mudflaps, glovebox, and tailgate hitch cover.
    Yes, obviously somebody changed either the door lock, or most likely, the ignition cylinder and did not bother to have it keyed as original. I had a 96, and I had the ignition cylinder replaced once, and my wife had her 96 RAV4 ignition cylinder replaced twice. Both times, we had the choice of a cylinder with a different key, or for about $30 more, we could get a keyable ignition cylinder that could be keyed to match the original. It was a no brainer to go ahead and get the keyable ignition cylinder because otherwise, we would have had to carry two keys around, for the door and ignition! And I had always kept an ORIGINAL key from when I bought the truck new, in a drawer, just so if I ever needed to make replacement keys, they could be cut from an original unused key, so I just had the mechanic use the original key to key the new ignition cylinder lock. The keyable ignition lock cylinders run around $180, with a locksmith charging around $50 to rekey it. All of this can be done at your local mechanic, will probably charge about $150 labor including the locksmith charge. At least, that is what mine charged in the past. I would recommend, as others here have done, that you go ahead and replace the ignition lock cylinder and have it keyed the same as the door. If you do not have a good original key, which it sounds like you won't, then I would get the dealer to key you an original key from the VIN#, and then keep that key in a drawer somewhere, only used for making copies.
