Keystone State Thread
Discussion in 'North East' started by Tatts521, Jun 20, 2008.
  1. Jun 27, 2019 at 10:07 AM
    P2W
    P2W Whut?
    Whodatsville
    '13 Tacoma DCLB
    Somstuff
    Here’s an install video in an 06 shortbed, looks like he left the bed track rails in place
    https://youtu.be/Y_xRW--jN4E
    I have a hard cover so I didn’t Velcro mine in, makes it easy to take it out to clean underneath
    Blackout14 likes this.
  2. Jun 27, 2019 at 10:13 AM
    Armyhater458
    Armyhater458 Well-Known Member
    Clarion, PA
    2012 TX Pro
    OME 887, LR UCA, Dakar 095 (medium duty), Dick Cepek Extreme Country 255/85/16
    I would go with the hitch or a shackle personally, but anything that won't bend or break with you ass hanging will suffice. I didn't have a tree or anything once and used the truck. I will always suggest scaffolding even with set-up and tear down. It is just easier to work off of and move about most of the time.
  3. Jun 27, 2019 at 10:13 AM
    Armyhater458
    Clarion, PA
    2012 TX Pro
    best networked TW member I've seen
    johneman, HomerTaco and Taco critter like this.
  4. Jun 27, 2019 at 10:36 AM
    Armyhater458
    Clarion, PA
    2012 TX Pro
    Does anyone have a Dakar leaf to convert it to HD before I order one? Also, what else would I want to get for this conversion? I'm considering new bushings (20K on them), Dakar anti squeak pads, center bolt, U-bolts? I am ignorant so any real advice is most definitely appreciated.
  5. Jun 27, 2019 at 10:38 AM
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    I was told not to worry about that. The part that seals is down under the screw head and should do its thing for quite a long time. We've had a corrugated steel roof since 1988. Had it "tuned up" a couple of years ago including replacement of those screws. A standing seam roof might not need a "tune up", ever.
    Our springhouse had cedar shakes. When I took them off the were mostly dirt. Only a few were even remotely intact. I'd never, ever do a cedar shingle roof after seeing that. I used to think they were long lasting; no more.
  6. Jun 27, 2019 at 10:57 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I’ve seen cedar roofs that were over 40 years old in great shape. :notsure:
  7. Jun 27, 2019 at 11:00 AM
    testelle
    testelle Well-Known Member
    Todd
    Oley, PA
    2003 Red 3.4L 4WD DCSB
    Too much shade and moss up on that hill? I wouldn't trust wood worth a darn either though, unless they dipped it in metal. (though the physics of that would not work, I know, nobody be a stickler... instant combustion, etc.)
  8. Jun 27, 2019 at 11:06 AM
    FreshOldTaco
    FreshOldTaco Well-Known Rider
    kevin
    2003 Tacoma
    Looks great! What are the dimensions?
  9. Jun 27, 2019 at 11:15 AM
    wdb
    Dave
    the perimeter
    plain jane
    I know right.
    Could have been. The springhouse is pretty much in shade all day, and as for moisture, well, it's a SPRINGHOUSE. :rofl: There was a lot of moss on them too. So maybe cedar is great so long as it gets a lot of sun?
    It's 800 sq. ft. exactly. Township says so. 23'4" by Iforget'Idunno".
    FreshOldTaco[QUOTED] likes this.
  10. Jun 27, 2019 at 11:27 AM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    It's super easy, I just did it a month or so ago. You will need a center pin, and probably should get new u-bolts if they've been on for a while. Everyone really recommends never re-using u-bolts but I've never had a problem. Everything else is up to you.
    All you need other than that is 2 c-clamps. Just pull them off the truck, replace the bushings, clamp pack, cut or remove center pin, put new leaf in place and reassemble.
    Also standing seam is the way to go but it will look like dogshit if your sheathing is anywhere near not perfect.
  11. Jun 27, 2019 at 11:34 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    D8AEC5AA-AC5A-45FC-AA52-91835688800A.jpg 68A3F760-594C-4E46-BCC1-2B9584AF8947.jpg A12648F4-4C89-4EA4-A53D-E7E4B28C9BE9.jpg
    Hello from King of Prussia
    johneman, Tatts521[OP], wdb and 6 others like this.
  12. Jun 27, 2019 at 11:35 AM
    testelle
    Todd
    Oley, PA
    That's good to know... considering I just re-did my OE leafsprings job with my original U-bolts. Were a pisser to remove with all the rust and corrosion. Torch almost didn't work they were so bad.
    Are you implying a home job of standing seam is gonna look like turd? :poking:
    Taco critter likes this.
  13. Jun 27, 2019 at 12:08 PM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
  14. Jun 27, 2019 at 12:27 PM
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    Not everything. Comes in handy sometimes. I needed a new roof on my house a couple years ago. Was gonna hire someone. Was talking to a buddy who loves construction stuff. He said get the shingles and we will do it.Made a call to a buddy with a dump trailer, he came over Friday after work we ripped the old roof off Friday night. He took trailer to the dump got rid of old stuff. Had 4 other friends come over Saturday morning. Laid the last few shingles by drop light.Its good to have friends. I think I touch about 20 shingles that day.
    johneman, Grand dude, Redmann and 5 others like this.
  15. Jun 27, 2019 at 12:35 PM
    PCTaco
    Adam
    New Columbia, PA
    Working on it
    Actually what I'm implying is that every single imperfection in your roof will reflect through the final material. It doesn't hide anything. So if you have wavy sheeting, bowing rafters, etc, it will be extremely visible on the final product.
  16. Jun 27, 2019 at 12:46 PM
    Nimble9
    Nimble9 visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Lotta money there. Color matched steel rear it looks like!
  17. Jun 27, 2019 at 1:02 PM
    testelle
    Todd
    Oley, PA
    Yeah... the guy that came to estimate today said that if I wanted standing seam he'd advise we rip off all tiles and get a full out layer of plywood up over top of the existing boards (this roof itself is like 70 years old on the dormers and maybe up to 160yrs on the other portion). That way the metal wouldn't have as much bulges and sags over time. If I do corrugated I can go straight over the existing shingles.
    Taco critter and Blackout14 like this.
  18. Jun 27, 2019 at 1:14 PM
    Grand dude
    Grand dude Well-Known Member
    Dave
    lehigh valley, PA.
    2016 trd or dcsb & 2002 trdor exclb
    cool stickers and a baseball card With clothes pin, sounds awesome ! wicked
    awesome, ill keep my eyes open for him !
  19. Jun 27, 2019 at 1:18 PM
    Grand dude
    Dave
    lehigh valley, PA.
    dam im jealous !
  20. Jun 27, 2019 at 1:24 PM
    Grand dude
    Dave
    lehigh valley, PA.
    I see your working out again Reds "la fitness "
    Redmann[QUOTED] likes this.
