Keystone State Thread
Discussion in 'North East' started by Tatts521, Jun 20, 2008.
  1. Aug 12, 2019 at 5:37 AM
    Armyhater458
    Armyhater458 Well-Known Member
    Clarion, PA
    2012 TX Pro
    OME 887, LR UCA, Dakar 095 (medium duty), Dick Cepek Extreme Country 255/85/16
    Seems unlikely, but does anyone have a 255/85/16 around 1/2 tread to use as a spare? I don't know anyone else in this thread running them. I want to go to 285 real directly, so really don't care to spend much money.
  2. Aug 12, 2019 at 6:55 AM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    I run them, unfortunately I don't have any spare. You can get a maxxis bighorn from 4wheel parts for like 190.
  3. Aug 12, 2019 at 7:02 AM
    testelle
    testelle Well-Known Member
    Todd
    Oley, PA
    2003 Red 3.4L 4WD DCSB
    Thinking caps on my friends...
    1st gen. Tacoma, "Load Sensing and Proportioning By-Pass Valve". Its a part of the brake system in the rear, attached to the driver side frame under the bed, and has a load sensing "spring" that attaches to the axle.
    Mine is rusty as ___ and I figured when I go and swap my bed out next month that I might as well repair/replace the thing when the bed is off and access is super easy. (Rather than wait till the rusty brake lines leading to the thing just blow and I'm going highway speed with less braking power.) Didn't pay mind to what this rusty doohicky even was until this morning when I sat down to look up a part number.
    Anyone ever replace one of these? Anyone have a used one just sitting on a shelf they'd like to sell me on the cheap? How important is this doohicky if I would rather just choose to go redneck and bypass the entire rusty mess by connecting the incoming brake lines directly to the outbound lines to the rear brakes?
    Thanks!
  4. Aug 12, 2019 at 7:06 AM
    PCTaco
    Adam
    New Columbia, PA
    Working on it
    There's a bunch of people on Marlin crawler's forums that run without it.
    https://board.marlincrawler.com/index.php?topic=70441.0
    Looks like pros and cons, your choice.
    RobP62 likes this.
  5. Aug 12, 2019 at 7:49 AM
    testelle
    Todd
    Oley, PA
    Thanks for the link. I read through that, and I just spent some time reading other threads here on the boards that came up when I searched "LSP & BV". Note my system is not lifted. So it looks like 1.) bypassing the valve will make my rear brakes always engage (whereas they usually don't unless under load as controlled by the OE sensing system). Leads to potential downfalls of rear lockup under heavy braking, and replacing your rear brake shoes more frequently. Or 2.) simple aftermarket ($35) valve needs to be manually adjusted, so that I'd need to take a quick crawl under when I know the back is loaded (ex. firewood, towing the trailer, etc.) and allow the rear brakes to be engaged.
    I'll think all that through till I get my bed off and see just how bad (or maybe not quite so bad) my parts are and make the decision then.
    Meanwhile... please shout out if you've got a used LSP & BV to send my way!
  6. Aug 12, 2019 at 8:21 AM
    PCTaco
    Adam
    New Columbia, PA
    Working on it
    Sometimes I forget that some people on this forum are stock.
  7. Aug 12, 2019 at 9:24 AM
    Armyhater458
    Clarion, PA
    2012 TX Pro
    I have a set of 4 285s, that i plan to pick up and I'd rather put the money towards them and find a spare(should be easier to locate), then buy a new one for a size i won't be running again. Appreciate the info though.
    Grand dude and Nimble9 like this.
  8. Aug 12, 2019 at 10:11 AM
    Grand dude
    Grand dude Well-Known Member
    Dave
    lehigh valley, PA.
    2016 trd or dcsb & 2002 trdor exclb
    cool stickers and a baseball card With clothes pin, sounds awesome ! wicked
    U Arts fartsy ! what did you do with the real chainsaw ?
  9. Aug 12, 2019 at 10:19 AM
    Grand dude
    Dave
    lehigh valley, PA.
    If you run into two more 285 I'm looking for two for spares
    Taco critter likes this.
  10. Aug 12, 2019 at 11:01 AM
    PCTaco
    Adam
    New Columbia, PA
    Working on it
    Why the change to 285s? I've had no problems with my 255s on anything stupid I've done.
  11. Aug 12, 2019 at 11:07 AM
    Armyhater458
    Clarion, PA
    2012 TX Pro
    My plan is to eventually run 35's, but re-gear, lockers, OBA are going to hold that up for a while. If i could find a spare for now, I would just run them until they are out. I don't want to buy new tires until i leap to 35's, so I'm just thinking 285 will be much easier to locate a set for cheap to get me through.
  12. Aug 12, 2019 at 11:31 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    @cynicalrider
    Thoughts?
  13. Aug 12, 2019 at 11:38 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    A popular modification is to remove the LSPV and add a manual valve. Might be something to consider. Also I will hopefully be removing mine this winter to do this swap, how much of a rush are you in to replace it? @testelle
    RobP62 likes this.
  14. Aug 12, 2019 at 12:02 PM
    testelle
    Todd
    Oley, PA
    Simply that its going to be SOOOO convenient to do it next month when I have the bed off. I'm going to do something then rather than the shenaniganz of crawling around barely being able to fit a wrench up in there while upside down with rust and crap falling all over my face, etc.
    Makes me wish I would have made the decision to swap my bed out this past winter when I replaced my gas tank. Daggone that would have been easier with the bed off.
    Taco critter and RobP62 like this.
  15. Aug 12, 2019 at 12:38 PM
    Ridleyguy13
    Ridleyguy13 Active Member
    2019 Cement Tacoma TRD Off-Road
    Hope everyone has a positive start to their week! Threw a TRD Pro grille on over the weekend!0.jpg
    RobP62, Grand dude, Delta09 and 10 others like this.
  16. Aug 12, 2019 at 12:42 PM
    Ridleyguy13
    those jersey's are sick!!!
    skatefreak282 likes this.
  17. Aug 12, 2019 at 12:45 PM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    Almost done with yet another 12 hour day. Unfortunately this was 8 straight hours and 4 overtime hours.
    We're ripping out a hand throw switch and replacing with an electric one, getting new rails and ties, and that grey box I posted a pic of last night. These pictures and video are when they weld the rails together.
    https://youtu.be/YRw_T3SMTJU
  18. Aug 12, 2019 at 12:48 PM
    PCTaco
    Adam
    New Columbia, PA
    Working on it
    Thermite welding is so neat.
  19. Aug 12, 2019 at 12:52 PM
    MagtechPA
    MagtechPA Thor
    Pittsburgh, PA
    That welding is intense! :bananadead:
  20. Aug 12, 2019 at 12:57 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Exothermic welding is so fucking cool.
