Keystone State Thread
Discussion in 'North East' started by Tatts521, Jun 20, 2008.
  1. Sep 27, 2019 at 7:12 AM
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    Hockey is the only sport that takes skill.
    WBF610, P2W, johneman and 4 others like this.
  2. Sep 27, 2019 at 7:21 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Me either. It was just something to do and I look foolish if I am unable to speak intelligently about it with customers at work.
    Working with contractors in Philly EVERYONE talks sports. -_-
    I used to really like NASCAR but then they started changing the rules so frequently I lost all interest. Also helped when HD used to sponsor it & I got free trips. :oops:
  3. Sep 27, 2019 at 7:27 AM
    Grand dude
    Grand dude Well-Known Member
    Dave
    lehigh valley, PA.
    2016 trd or dcsb & 2002 trdor exclb
    cool stickers and a baseball card With clothes pin, sounds awesome ! wicked
    What is that?
    Taco critter likes this.
  4. Sep 27, 2019 at 7:30 AM
    Grand dude
    Dave
    lehigh valley, PA.
    Lots of skill :D
  5. Sep 27, 2019 at 7:33 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I still like it but I don't follow it actively like I used to. Once upon a time I went to 5-6 races a year and watched all of them on TV... :oops:
    Taco critter and skatefreak282 like this.
  6. Sep 27, 2019 at 7:54 AM
    Tatts521
    Tatts521 [OP] Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    If we are talking sports I'm a big fan of motogp. I'll watch that over anything. I also record the isle of mann tt every year so there's that.
  7. Sep 27, 2019 at 7:55 AM
    testelle
    testelle Well-Known Member
    Todd
    Oley, PA
    2003 Red 3.4L 4WD DCSB
    OK, so you're saying the holes that Toyota designed into the frame are not enough and you like extra holes? Wouldn't I rather patch up and cover/seal over all holes in the paint coat with bedliner so that the only entry/exit of water is just what Toyota designed? I'm somewhat confused. How is the bedliner different than paint? If water enters a scratch/ding in the paint somewhere, it will seep as far as it can and rust forms underneath paint. Are you implying that you'd rather have rust hiding under normal paint than the bedliner paint? I'd make the assumption that if you put on a harder more durable coat like a bedliner then you'll have less chips where water can enter. Now I'm not talking about willy nilly slapping bedliner over everything at this moment. It would be a matter of grinding down to bare metal on the existing spots of corrosion, rust inhibitor, primer, then bedliner.
    Is that wrong? Everyone chime in who has ever put on bedliner and regretted it. Ultimately I'll go with what y'all say. So far it looks like 3 votes against bedliner, none for it.
  8. Sep 27, 2019 at 8:01 AM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    Several things. You can't coat the inside of the frame with bedliner, which is where most frame rot starts. You'll never get the pockets of moisture out from between the layers of the frame without hooking it up to a welder and heating the entire frame up for a good duration.
    The problem with bedliner is it's a solid plastic that is not self-healing. Anywhere moisture already exists, or anywhere that in the future you get a ding will retain the moisture against the metal for much longer than, yes, paint. If you want to coat your frame it should be with a rust inhibitor, a-la fluid film, or amsoil's heavy duty rust preventative. Something that is self healing and water displacing.
    testelle[QUOTED] and Bastek like this.
  9. Sep 27, 2019 at 8:10 AM
    FreshOldTaco
    FreshOldTaco Well-Known Rider
    kevin
    2003 Tacoma
    MotoGP is awesome, those guys are insane. Also love watching IOM TT.
    I prefer motorsports and action sports - anything X-Games, racing, etc. I do find Nascar a bit boring though, prefer circuit style races.
    Tatts521[QUOTED][OP] likes this.
  10. Sep 27, 2019 at 8:10 AM
    PCTaco
    Adam
    New Columbia, PA
    Working on it
    I like weird sports where you know no one is being paid a fortune just for showing up.
    johneman and Grand dude like this.
  11. Sep 27, 2019 at 8:16 AM
    Grand dude
    Dave
    lehigh valley, PA.
  12. Sep 27, 2019 at 8:17 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    What is being said in different ways !1
    Any coating but paint allows moisture to be held between the coating and the frame !!
    Moisture also including all or lovely mix of winter chemicals!!
    testelle[QUOTED] likes this.
  13. Sep 27, 2019 at 8:18 AM
    19taco4x4
    19taco4x4 Well-Known Member
    Jesse
    21 Silver SR
    I have dealt with corporate plenty, plenty of times. Message me.
  14. Sep 27, 2019 at 8:21 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I am not spectator I get bored to easy!
    Then not having TV since 1999 I am sure helps The world slowest internet helps as well
    I can watch a Rodeo but only from the chutes
    johneman and BlackWagon[QUOTED] like this.
  15. Sep 27, 2019 at 8:40 AM
    loosnut
    jerry
    feasterville pa
    06 dbl cab long bed
    Baseball=throw,catch , hit the ball
    Easy you learned that in diapers
    Soccer= kick the ball, learned after you learned how to walk.
    Football = throw,catch, run the ball, try to tackle the other guy with the ball.learned that if you had a sibling.
    Basketball = throw ball through hole, learned that throwing trash away.
    All the above done while running on your feet, learned that after you master walking.
    Hockey= here is a stick,hit this little black disk made of solid rubber and frozen,put it into the goal that is 4ft by 6ft. While on ice.
  16. Sep 27, 2019 at 9:00 AM
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    That's a cool explanation :thumbsup:
  17. Sep 27, 2019 at 9:09 AM
    Tatts521
    I do plan on going to isle of mann to watch one of these races. Now that's a dream vacation for me.
  18. Sep 27, 2019 at 9:13 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    I got into watching F1 racing and GT racing but stopped a year or so ago
  19. Sep 27, 2019 at 9:19 AM
    testelle
    Todd
    Oley, PA
    Thanks for the tips guys. You've convinced me.
  20. Sep 27, 2019 at 9:20 AM
    testelle
    Todd
    Oley, PA
    (though I still don't see the difference with that mentality for the frame in contrast to why we all think bedliner on the bed or the rocker panels is somehow better in those circumstances)
