Keystone State Thread
Discussion in 'North East' started by Tatts521, Jun 20, 2008.
  1. Oct 21, 2019 at 4:16 AM
    disconnected
    disconnected LOST
    Greg
    Pittsburgh
    19 TRD Off-Road
    Icon 2,5'' coilovers and rear springs, RCI full skids, caliraised sliders, Warfab hitch skid, UpTop roof rack, kb voodo bed rack, Diode Dynamis Pro fogs, Seat Jackers with Molle, taco garage mounts..... and other stuff
  2. Oct 21, 2019 at 4:24 AM
    MagtechPA
    MagtechPA Thor
    Pittsburgh, PA
    Mornin' PA folks! :playball:
    Taco critter likes this.
  3. Oct 21, 2019 at 4:43 AM
    El Dahs
    El Dahs I am DTF. Down To 'Froad
    The Real Slim Shadle
    2000 Ford Ranger
    Dents and scratches
    Does the NEC specify which is up or down?
  4. Oct 21, 2019 at 5:16 AM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    Nope. Either way is acceptable but the common idea now is that the ground pin should be up. If anything falls down and either jars the plug loose or it's already a little loose, contact is made with ground and not a line wire.
    stbear and 98tacoma27 like this.
  5. Oct 21, 2019 at 5:20 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Ok, who the heck is using a chainsaw at full RPM at 8am dammit!? It was all nice and quiet until now. Screw this, I'm moving out to the boonies!
    Wait, it's Monday. Think I'm just being a little too grumpy...
  6. Oct 21, 2019 at 5:22 AM
    PCTaco
    Adam
    New Columbia, PA
    Working on it
    8am is damn near lunch time for me.
  7. Oct 21, 2019 at 5:24 AM
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    So....Monday morning....we meet yet again....
    Taco critter, johneman and Delta09 like this.
  8. Oct 21, 2019 at 5:27 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Heh, I'm just extra grumpy this morning for some reason. I've been awake since 2:30am and a 4 shot espresso is doing nothing. Neighbor kid was blasting his boom box/stereo at 6am as usual so that didn't help.
  9. Oct 21, 2019 at 5:27 AM
    testelle
    testelle Well-Known Member
    Todd
    Oley, PA
    2003 Red 3.4L 4WD DCSB
    Ok... last time y'all chatted with me about not using bedliner on the frame. Point taken. The consensus I think I remember was plain old spray paint after knocking off the rust. What about Por-15 instead? Shall I NOT use Por-15?
  10. Oct 21, 2019 at 5:29 AM
    danteisme
    South Western PA
    I just used a bit of POR-15 this weekend to touch up two annoying spots on my frame. I think this stuff works great, but you have to prep the area properly and follow the instructions.
    Taco critter and testelle like this.
  11. Oct 21, 2019 at 5:36 AM
    PCTaco
    Adam
    New Columbia, PA
    Working on it
    I slept from 00:30 to 03:30 last night.
    Por-15 is okay. It's not UV stable but it should be fine under the bed.
  12. Oct 21, 2019 at 5:39 AM
    testelle
    Todd
    Oley, PA
    Me and spray paint never seem to go together. I don't know if I do something wrong but it always seems to forever stay somewhat gummy and easy enough to just peel off with your fingernail and within days you can see rust breaking out through the sprayed area anyway.
    Taco critter and stbear like this.
  13. Oct 21, 2019 at 5:44 AM
    JoeySauce
    JoeySauce Well-Known Member
    Joe
    Eagle PA
    11 DCSB
    Most unions install this way
  14. Oct 21, 2019 at 5:48 AM
    testelle
    Todd
    Oley, PA
    About 1/3rd of what you see of the exposed frame under the bed will get hit with sanding/grinding and some sort of rust treatment and top coat. Planning out my job, I figure 1 quart of Por-15 should do? (internet estimates 1 quart to cover about 100sq.ft)
    BTW... I'd think you crazy, but anyone is completely welcome to my rustbucket old bed for FREE if you'd like to haul it off. I cannot see it being good for literally anything other than maybe someone who smashed a corner and is looking for a cheap weld-on replacement. I'm just going to take a trip to a metal recycler when I'm done with the whole project and drop off much of my past year's rusted removed parts for the pittance loose change the scrap metal will get me.
    Taco critter and HomerTaco like this.
  15. Oct 21, 2019 at 5:49 AM
    FreshOldTaco
    FreshOldTaco Well-Known Rider
    kevin
    2003 Tacoma
    3 day work week for me :woot:
  16. Oct 21, 2019 at 5:57 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    :confused:
    johneman and Taco critter like this.
  17. Oct 21, 2019 at 6:23 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Right now, if you have something half plugged in and something conductive happens to fall on the prongs, you're going to have a surprise light show.
    With the ground prong up, less chance of that happening.
    johneman and 98tacoma27 like this.
  18. Oct 21, 2019 at 6:26 AM
    Pa_Slasher
    Pa_Slasher Well-Known Member
    2015 Double Cab Toyota Tacoma TRD Blue Ribbon Metallic
    17" Method Roosts on 265/75/17 Wildpeaks, 2.5 OME BP-51 suspension and UCA's.
    Only problem is if you squint you will see Canada!! :canada:
    testelle likes this.
  19. Oct 21, 2019 at 6:32 AM
    PCTaco
    Adam
    New Columbia, PA
    Working on it
    The opposing argument is if you grab a plug with the conductors exposed with ground up, your finger could make contact with a hot prong.
    Wyoming09 and johneman like this.
  20. Oct 21, 2019 at 6:38 AM
    Armyhater458
    Armyhater458 Well-Known Member
    Clarion, PA
    2012 TX Pro
    OME 887, LR UCA, Dakar 095 (medium duty), Dick Cepek Extreme Country 255/85/16
    Did you try the VSC recalibration? That got rid of those two lights for me after my lift and alignment.
