Keystone State Thread
Discussion in 'North East' started by Tatts521, Jun 20, 2008.
  1. May 27, 2021 at 5:51 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Thanks for calling the Rain every bit as good as a Rain Dance.
    Devious6, T-yoda, DoVeR TaCo and 5 others like this.
  2. May 27, 2021 at 7:17 AM
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    Its nothing special. Just a 240V plug next to my meter and a really crude mechanical device that keeps the meter feed and gen feed from being turned on at the same time. Highly recommend Honda gens, though. Mine can be loaded up and you can still have a conversation standing right next to it.
    Devious6, T-yoda, RustyGreen and 2 others like this.
  3. May 27, 2021 at 7:20 AM
    9mmMike
    9mmMike Well-Known Member
    Michael
    SE PA
    2019 TRD OR 4x4 DCLB - Cement
    My hood. Watch for my cement DCLB with a backrack. I am sure we will pass each other sooner or later. :)
    Devious6, T-yoda, RustyGreen and 4 others like this.
  4. May 27, 2021 at 7:31 AM
    steelcity2
    steelcity2 Well-Known Member
    Pittsburgh Pa
    2013 MGM DCSB TRD sport
    Bilsteins 5100's all 4 corners 1 inch rear spacer
    Sounds legit, code and power company want to see a disconnect like that , no way to feed back to the grid , safety #1. Mine on the other hand is similar to urs but I have to kill the main before I connect generator, I dont have the mechanical interlock. Feed the panel with this outlet. 20210526_163206.jpg
  5. May 27, 2021 at 7:35 AM
    steelcity2
    Pittsburgh Pa
    Also ur right on with that honda generator, been looking at new and used and boy do they hold there value. I have an older Coleman that has no idle down control, loud and hard to start ...... but it was a barter on a side job years back. Some day I'll upgrade. Knock on wood we don't loose power here all that often. Good luck and hope u loose power lol.
  6. May 27, 2021 at 7:52 AM
    VXEric
    VXEric Well-Known Member
    Eric
    Worcester, PA
    07 ACS V6 6 Spd TRD Sport
    265/70/17 ATs on 17x8"wheels and 0 offset Morimoto XB LED Fogs Reinforced tailgate 2011 Honeycomb grille URD Short Shifter and cue- ball style knob
    I have been using Kasa for my home automation in general. I have 6 indoor/ outdoor cameras plus about a dozen lights throughout the house all run off the their software. Video quality is pretty good and really convenient to have it all integrated so that I can automate lights,motion sensing, alarms etc all from one place.
    Devious6, wdb, T-yoda and 6 others like this.
  7. May 27, 2021 at 7:56 AM
    9mmMike
    Michael
    SE PA
    I had an outside hookup as well. Disconnect from the street inside. The problem was that when I lose power, we flood...and I am never home to connect and fire-up the generator. I did the "dash home" thing for about a year before I pulled the trigger on a house generator that autostarts. We lose power all the time.
    Devious6, wdb, T-yoda and 5 others like this.
  8. May 27, 2021 at 7:58 AM
    steelcity2
    Pittsburgh Pa
    Oh no doubt that was the right move. Plus added value to ur house. Generac setup?
  9. May 27, 2021 at 8:01 AM
    9mmMike
    Michael
    SE PA
    Yes, a generac on propane. No gas lines up here.
  10. May 27, 2021 at 10:44 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I have a similar setup to plug in my 9000kw Rigid Generator in the event of power outage. I learned my lesson after Hurricane Sandy and being without juice for 5 days. :(
  11. May 27, 2021 at 4:25 PM
    TOYTONKA
    TOYTONKA Well-Known Member
    Dennis
    Hatboro, Pa.
    2015 tacoma trd sport dclb
    Borla cat back exhaust "touring", K&N cold air intake, weather tech digit fit floor liner front & back, A.R.E. cap w/ bed rug, Redline hood struts, Slow drop tailgate strut, tow hitch d-ring, Transformer badges, window tint
    Any one on here or know of someone able to diagnose and repair a warn wireless remote? Apparently it has a parasitic draw designed into them and it kills the battery. Im on my second remote and 4th battery. Right now this winch is just a $2000.00 dollar boat anchor. Yes, I contacted Warn customer service and they asked me if I left the winch switch turn on. I said NO, and never heard back from them.:facepalm::frusty:
    RustyGreen, T-yoda and Taco critter like this.
  12. May 27, 2021 at 4:57 PM
    steelcity2
    Pittsburgh Pa
    Well with a known problem like that i would tie the winch power into a ignition relay. The winch would only have power when the ignition is on, so it would be dead when ignition is off and no chance of any current draw. Make sense ?
    RustyGreen, T-yoda, johneman and 2 others like this.
  13. May 27, 2021 at 5:08 PM
    MDFM31
    Chester Co, PA
    16 DCSBOR
    No power outage yesterday, but I still run the house off the gen once a month for about an hour. I had a hand me down 7.5kW generac that was in great shape with about 20 hours when it stopped producing voltage. The idle down also didn't work. It was a $600 or so costco/lowes etc special. It ran well but was loud as sin. We had an outage that lasted a couple days and I wound up running our fridge and freezer off my work truck which has a 2kW inverter. Couldn't run the well pump, though, so no water. The Honda was big $ but we sleep well knowing we will have water pressure and can save the $1000-1500 of food we have in our freezers. Az for the interlock, it is caveman simple-
  14. May 27, 2021 at 5:25 PM
    TOYTONKA
    Dennis
    Hatboro, Pa.
    Yes, but I should have more clear about witch battery I'm replacing. Not the truck battery, the wireless remote battery. sorry about that.
  15. May 27, 2021 at 5:40 PM
    steelcity2
    Pittsburgh Pa
    OIC. Yea that does seem like a Warn issue.
    johneman, RustyGreen, T-yoda and 2 others like this.
  16. May 27, 2021 at 6:18 PM
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
  17. May 27, 2021 at 7:11 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    @6 gearT444E
    Thoughts?
    This is definitely your department.
    RustyGreen, T-yoda and DoVeR TaCo like this.
  18. May 27, 2021 at 7:15 PM
    TOYTONKA
    Dennis
    Hatboro, Pa.
    Just to be more clear I'm talking about the remote battery not the truck battery.
  19. May 27, 2021 at 7:39 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    what model winch?
    RustyGreen, johneman and T-yoda like this.
  20. May 28, 2021 at 1:20 AM
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    Good morning fellow Pennsyltuckyvanians!!
    This is our 2d Gen system . The first was an Onan that we had put in when we built in 2004. It started automatically and switched over when we lost power and powered the important parts of the house. Lasted for 15 years with a Honda engine.
    The new B&S also starts/switches automatically. It was a much simpler install and didn't require a separate transfer panel like the Onan did. And, it is monitored wirelessly by our local installer in case it fails to start. Powers the entire house.
    Both systems ran/run off propane and are fed by the 1000 gal tank we have buried in the yard.
