Keystone State Thread
Discussion in 'North East' started by Tatts521, Jun 20, 2008.
  1. Nov 7, 2021 at 12:11 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I have no idea what gamey meat tastes like unless it is not having all the added chemicals then the package says may contain real meat.
    The taste of Wild Turkey they forage some times are good others are not.The fat content is much lower as well.
    Commercial Birds pretty much a 24x7 all you can eat buffet Birds raised at home don`t go hungry either .
    Though it is rough feeding the bird all year long when your young seeing Mom put it in the oven .
  2. Nov 7, 2021 at 12:36 PM
    MoneyMan55
    MoneyMan55 Licensed Master Electrician
    Doug
    South Central PA
    2017 DCSB SR5 Blazing Blue Pearl
    Afternoon Pa. Getting ready to put fresh loin in the oven.....250627877_4832773126754251_5277843211824_5b08e093395865cd2b57457b889806516aaa80a8.jpg
  3. Nov 7, 2021 at 1:06 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Grilling London Broil this evening. :D
  4. Nov 7, 2021 at 1:09 PM
    BlackWagon
    BlackWagon Well-Known Member
    Ronju
    South East PA
    2018 Black TRD Off Road DCSB MT
    Just did my plugs a few weeks back, the drivers side is the hardest so thats what I started with, got to remove the top two bolts on the metal brackets and loosen the bottom two. Luckly I have skinny hands and arms. Took a little over an hour to do the drivers side. The passenger side is easy, just remove the intake hose and connections and had that side done in 10 minutes, definitely not a 600 dollar job like the dealer wanted. Definitely easier than my old wrx plugs, and even they weren't hard just had to remove alot more to get access
    Bastek, RustyGreen and steelcity2 like this.
  5. Nov 7, 2021 at 1:10 PM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    It's Friday, so probably Marie Callender's finest, with a side of knob creek.
  6. Nov 7, 2021 at 1:10 PM
    BlackWagon
    Ronju
    South East PA
    Thats why its so expensive at the dealer, they remove the whole intake, not worth the time in my opinion
  7. Nov 7, 2021 at 1:11 PM
    PCTaco
    Adam
    New Columbia, PA
    Working on it
    They say they remove the whole intake, then you have techs that have figured out they can pull something with 2 universals and 3 extensions to save an hour and since they're paid rate, they make bank.
  8. Nov 7, 2021 at 1:15 PM
    BlackWagon
    Ronju
    South East PA
    Yep, they really are not that hard, just need a few wobble extensions and your golden. Maybe I need to start a side 3rd gen spark plug service for 350. :rofl:
  9. Nov 7, 2021 at 1:31 PM
    98tacoma27
    Ben
    Not Beech Creek
    '12 outback. I'm hoping it's easier than it looks.
    RustyGreen, steelcity2 and BlackWagon like this.
  10. Nov 7, 2021 at 1:40 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I don't know much about the Subi world that one place I never desired to enter, hopefully it's not too hard for your sake. Maybe put some POR-15 on the new pan. I got my new pan from Moroso which was thicker than OEM and better coating too.
  11. Nov 7, 2021 at 1:55 PM
    BlackWagon
    Ronju
    South East PA
    Don't know much about the newer subies, but it didn't look so bad to replace my 06 wrx pan, but I also had valve cover leaks so my pan was caked in oil for a while.
  12. Nov 7, 2021 at 2:01 PM
    JoeySauce
    JoeySauce Well-Known Member
    Joe
    Eagle PA
    11 DCSB
    Harvested my fall chicken today 25 in the freezer and one less chore tomorrow morning
  13. Nov 7, 2021 at 3:22 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    So not even 24 hours later and it's already serving as a storage bench :rofl:
  14. Nov 7, 2021 at 3:24 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  15. Nov 7, 2021 at 3:26 PM
    steelcity2
    steelcity2 Well-Known Member
    Pittsburgh Pa
    2013 MGM DCSB TRD sport
    Bilsteins 5100's all 4 corners 1 inch rear spacer
    Wow, how big is that thing ? 20 lbs ?
  16. Nov 7, 2021 at 3:29 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    :laughing: actually it’s about 2 1/2lbs. pre-cooking weight.
  17. Nov 7, 2021 at 7:19 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    I had an old 302 power F-150 years ago. Ford used a plastic like paint that cracked and made pockets to hold water... :annoyed:
    The pan had several pinholes that I fixed up with small self tapping screws with a piece of Gore-Tex behind the head.
    To change the pan the exhaust had to come off -- no thank you.
  18. Nov 7, 2021 at 7:20 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    From Saturday's hike with @Gwyns04
    SaturdayNovember6th2021 033.jpg SaturdayNovember6th2021 034.jpg SaturdayNovember6th2021 035.jpg
    RustyGreen, Charlie Too and Devious6 like this.
  19. Nov 7, 2021 at 7:25 PM
    PennSilverTaco
    Charlie
    RustyGreen and Devious6 like this.
  20. Nov 7, 2021 at 7:28 PM
    PennSilverTaco
    Charlie
    RustyGreen, disconnected and Devious6 like this.
