Keystone State Thread
Discussion in 'North East' started by Tatts521, Jun 20, 2008.
  1. Sep 24, 2022 at 7:59 PM
    VXEric
    VXEric Well-Known Member
    Eric
    Worcester, PA
    07 ACS V6 6 Spd TRD Sport
    265/70/17 ATs on 17x8"wheels and 0 offset Morimoto XB LED Fogs Reinforced tailgate 2011 Honeycomb grille URD Short Shifter and cue- ball style knob
    Have you heated the knuckle? Obviously be really careful of the boot and other stuff in the area. If you're replacing the ball joint, put the nut back on until it's flush with the end of the threads and hit directly on it to drive it out
    steelcity2 likes this.
  2. Sep 24, 2022 at 8:14 PM
    Armyhater458
    Armyhater458 Well-Known Member
    Clarion, PA
    2012 TX Pro
    OME 887, LR UCA, Dakar 095 (medium duty), Dick Cepek Extreme Country 255/85/16
    Tried heat. Didn't think about the nut until I already messed the threads up.
    Taco critter and steelcity2 like this.
  3. Sep 24, 2022 at 9:11 PM
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    Generous coatings of PB blaster and let sit for a week, if you can. Maybe that will do it and maybe not. I have tried different things and found there really is no replacement for a pickle fork, though you may tear the boot. You can rent them from AutoZone for free. I wound up buying my own set which has one fork for as 3/8" air chisel and that thing is a life saver.
  4. Sep 25, 2022 at 2:48 AM
    dwcfastrice
    dwcfastrice Bacon makes everything better.
    David
    Southeast PA
    2007 Silver Mica DCSB
    So far: 2.5" Icon Lift, Steel Front bumper, steel rear bumper, Cali Raised Bed Stiffener, 12Volt.Solutions remote start, Stereo upgrade, A Pillar Ram Mounts, BAMF Behind the grill light mount with Sylania 20" bar; KB Voodoo Max 22" Rack, CVT Awning, Decked drawer system, pod lights
    GOod morning, All. Heading to CP Tacitcal in Sinking SPring for the day. Have a good one!
  5. Sep 25, 2022 at 5:34 AM
    Tatts521
    Tatts521 [OP] Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    Good morning Pennsylvania
  6. Sep 25, 2022 at 6:38 AM
    steelcity2
    steelcity2 Well-Known Member
    Pittsburgh Pa
    2013 MGM DCSB TRD sport
    Bilsteins 5100's all 4 corners 1 inch rear spacer
    Good morning all. Little bit of rain here. Got the DD in the garage for a quick waxing. Also going to tackle cleaning up the work bench since my son moved out, maybe now it will stay clean lol.
  7. Sep 25, 2022 at 6:39 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Morning Pennsylvania :hattip:
  8. Sep 25, 2022 at 6:54 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Take the knuckle off and press it out, soak in Kroil for a couple days and then heat it up right before it's time to press it out. During the pressing, give a few "shock loads" with a ball peen hammer as pressure is applied.
    lynyrd3 likes this.
  9. Sep 25, 2022 at 7:09 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Burned what was left of the old porch last night and did some taco and garage mods. UG mount and some footwell LEDs, eastwood can mount to try and clean up my mess here LOL, it was a good night.
  10. Sep 25, 2022 at 8:20 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Let me know how that works out for you :anonymous:
  11. Sep 25, 2022 at 12:49 PM
    Cavmedic
    Cavmedic Well-Known Member
    Pottstown PA
    It ALMOST makes me wanna go out for a run. Emphasis on the almost part. I’ll live vicariously through my wife on that part.
    As usual, just rained here. the storms usually split off when they cross the mountains between Berks/Montco
  12. Sep 25, 2022 at 1:04 PM
    Armyhater458
    Clarion, PA
    2012 TX Pro
    Got a front end service kit today the ball joint separator tool was no dice. New tuning fork with a pissed off mini sledge and it finally gave. My buddy messed up the inner wheel seal trying to drive it in. So it is still sitting. What is the best way to get them in square and not bend them? It is such thin metal it doesn't take much. I'll get parts at noon tomorrow and start again. Got the other side done, but didn't have to replace the hub on that side. At this point everything is reassembling mostly new stuff so it shouldnt be too bad. I have to bend a little z shaped line for the new caliper which should be the only issue. Then to wire the cap. Get it realigned and hope to pass inspection.
  13. Sep 25, 2022 at 1:09 PM
    steelcity2
    Pittsburgh Pa
    Old timers would put it in the freezer to shrink it ? Then maybe she will go in easier , square even blow with socket or piece of wood to ensure even pressure. May want to use some lube. Good luck and keep us posted.
    lynyrd3 likes this.
  14. Sep 25, 2022 at 1:18 PM
    Armyhater458
    Clarion, PA
    2012 TX Pro
    Got a piece of steel with a bolt to pull it through flat. Thought about a piece of PVC since it'll be about 3" diameter and I dont have a socket.
    lynyrd3 and steelcity2[QUOTED] like this.
  15. Sep 25, 2022 at 1:27 PM
    steelcity2
    Pittsburgh Pa
    Nice. I've used pvc coupling to set my needle bearing. However it doesn't take much to boger up the pvc. U need some device to even the pressure.
    lynyrd3 likes this.
  16. Sep 25, 2022 at 7:03 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I'd just use the old seal to drive it, otherwise a 2x4 and a steady hand to get it started even is key. Make sure you add some grease to the garter spring so it doesn't go a flying.
    Spotted a hawk today shopping for lunch in the back field
    I got my new floodlights wired up today and tested them out tonight, let there be light out back!
  17. Sep 26, 2022 at 3:18 AM
    Charlie Too
    Charlie Too Well-Known Member
    Western PA
    2021 Army Green Tacoma TRD Off Road
    Good morning PA. Happy Monday.
    spentshells, Delta09, lynyrd3 and 3 others like this.
  18. Sep 26, 2022 at 3:19 AM
    Tatts521
  19. Sep 26, 2022 at 4:02 AM
    BkerChuck
    BkerChuck Well-Known Member
    Chuck
    Etters, PA
    2017 Tacoma TRD Sport Blazing Blue Pearl
    Good morning and welcome back to work for those of us still doing so. Hope everyone had a safe and pleasant weekend.
  20. Sep 26, 2022 at 4:04 AM
    lynyrd3
    Bill
    Morning Pennsylvania :wave:
