Keystone State Thread
Discussion in 'North East' started by Tatts521, Jun 20, 2008.
  1. Jun 23, 2024 at 9:09 AM
    MidnightRebel07
    MidnightRebel07 If you're gonna be a bear, Be a Grizzly !
    Jerry
    Northside of Pittsburgh, Pa.
    2013 Tacoma BAJA T/X dcsb
    Ironman Foam Cell Pro suspension, Anso black headlight housings, l.e.d. headlights, black taillights, Demello steel front bumper with highlight 7" l.e.d. round lights, Diode Dynamics Amber SS3 Pro lights, Hooke Road steel rear bumper with Nighlight reverse lights, Hooke Road roof rack, Ultima Aluminum toolbox, Weathertech floor mats, EGR in channel ventshades, Snorkel, K&N air filter and cabin air filter, 265/75/16 Cooper ST Maxx, Firestone ride rite airbags, Bentrodders bed reinforcements, too many other things to remember.
    This is Swamp Ass and Bayou Balls weather. Gotta peel your balls off the inside of your legs every couple minutes. LMFAO !!!
  2. Jun 23, 2024 at 9:10 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Nah, just gotta break out the banana hammock style underwear. Although makes for an awkward situation changing in the locker room at work :anonymous:
    Tatts521[OP] and steelcity2 like this.
  3. Jun 23, 2024 at 10:18 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    yes and working good in this heat.
  4. Jun 23, 2024 at 10:33 AM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    This is what my backyard looks like…
  5. Jun 23, 2024 at 10:35 AM
    PennSilverTaco
    Charlie
    Front yard got it much worse…
    steelcity2 likes this.
  6. Jun 23, 2024 at 10:35 AM
    PennSilverTaco
    Charlie
  7. Jun 23, 2024 at 10:43 AM
    PennSilverTaco
    Charlie
    If it was straight-cool and propane, would you still do a 3-ton? Also, is it a 2-story house? If so, I would do a 1.5-ton on each floor or possibly a 1.5-ton and a 2-ton, rather than a single system; I would never build a 2-story house over 1,500 square feet with only one central A/C system. My parents’ townhouse in Furlong, PA was like 2,300 square feet not including the finished basement. It had dual 2-ton Carrier central A/Cs matched with 40,000 BTU gas furnaces. My parents bought the house brand new in 2007, they sold it in 2016, and the last time I drove by the house earlier this year both of the Carriers from 2007 (visible from the street) were still there!
    maxpower29[QUOTED] likes this.
  8. Jun 23, 2024 at 10:49 AM
    Tatts521
    Tatts521 [OP] Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    Range turned out pretty good. Besides my brothers socom both magazines blew out the bottom. So we ended up single chambering it. Than we switched out the ishmash 223 I guess that how it's pronounced.
  9. Jun 23, 2024 at 10:50 AM
    PennSilverTaco
    Charlie
    @maxpower29
    The EPA started the phaseout of CFCs in 2009-2010. Our house was built in 2007. Our house had R-22 in both systems and they likely performed better on hotter days! :cool:
    The oldest houses in that neighborhood were built in 2004 and the newest were built in 2009-2010, so out of 386 townhomes, I’d say that probably 10 to 12 houses had R410a systems. The oldest houses in that neighborhood are now approaching twenty years old and a good number of them have had the A/Cs replaced in the last five to ten years, so those are now R410a, but that neighborhood was truly the end of an era in my opinion! :(
  10. Jun 23, 2024 at 10:55 AM
    Glenny
    Glenny Well-Known Member
    Glenn
    penns valley PA.
    2023 LR trail edition
    none I still have a warranty ;-)
    I wish my yard looked like that then I wouldn’t have to cut it
  11. Jun 23, 2024 at 10:56 AM
    PennSilverTaco
    Charlie
    We don’t have to cut ours when it’s green. One of the few benefits of living in a neighborhood with an HOA is that they take care of mowing the lawns…
  12. Jun 23, 2024 at 10:57 AM
    Glenny
    Glenn
    penns valley PA.
    I was trying to work on some stuff out side but damn it’s so hot
  13. Jun 23, 2024 at 10:59 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Pretty darn dry here as well
  14. Jun 23, 2024 at 11:01 AM
    Glenny
    Glenn
    penns valley PA.
    I don’t think I could deal with a HOA other then someone taking care of cutting the grass
  15. Jun 23, 2024 at 11:26 AM
    Charlie Too
    Charlie Too Well-Known Member
    Western PA
    2021 Army Green Tacoma TRD Off Road
    Yeah, I have a propane furnace. It kicks in when the temperature gets to 35 degrees and under.
  16. Jun 23, 2024 at 11:29 AM
    PennSilverTaco
    Charlie
    What do you call a large group of Karens?
    An HOA!
  17. Jun 23, 2024 at 11:31 AM
    PennSilverTaco
    Charlie
    I personally don't think a heat pump is needed with gas heat, but if I had a house with propane I would want the heat pump just in case I run out of propane and the supplier can't come out in a timely manner. As for oil heat, I would want a heat pump just because heating oil is so expensive...
    :spending:
  18. Jun 23, 2024 at 1:52 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    Wow that seems way different than here. It's a 2 level plus basement. I can see putting mini splits in on the different floors but the ducted systems we never do more than one per house. Even in expensive 4000-5000 sqft houses they would do a single ducted 5ton and it would work fine. The difference is interesting
  19. Jun 23, 2024 at 2:15 PM
    Charlie Too
    Western PA
    The heat pump is more for the summer. It serves as my a.c. So it is necessary. Propane is cheap so you may have a point regarding the winter. I get a special rate from my electric provider for having a heat pump. There are many winter days where the temp is below 35, but I figure splitting the winter bewteen the 2 should make the furnace last longer.
  20. Jun 23, 2024 at 5:32 PM
    DetroitDarin
    DetroitDarin Specified
    York County PA
    Scratches and Whatnot
    hey folks - i'm trying to buy a small tractor this week; Any weird PA-specific taxes and fees I should know about before buying? Any dealer-add-ons that are easily recognizable as 'ways to get my money' and not actually required at point of sale? Not for farming - just for property up-keep.
