Keystone State Thread
Discussion in 'North East' started by Tatts521, Jun 20, 2008.
  1. Dec 27, 2015 at 3:20 PM
    Nimble9
    Nimble9 visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Oh my how embarrassing, thanks for the help but I had to give up. Assembled the old shock and spring and buttoned it up and drove it to the shop. Didn't have enough weight to keep it from lifting :( I got my butt handed to me lol thanks so much @igotalotofrice for staying with and helping till the bitter end!
    igotalotofrice likes this.
  2. Dec 27, 2015 at 3:50 PM
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Yeah, but I learned that ATF and Acetone work amazingly
    Blackout14 likes this.
  3. Dec 27, 2015 at 4:54 PM
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    If you need more than the 48, you're doing it wrong. Not popular, but true.
  4. Dec 27, 2015 at 5:07 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    i've used every bit of my 60" hi lift on the trails. But my truck is lifted on 36s with a shackle flip. Here's a situation where a 48" jack would have been useless
  5. Dec 27, 2015 at 5:16 PM
    silverpataco1968
    silverpataco1968 Tomorrow isn't Promised!
    Eric
    Eastern PA
    2007 DCSB and 2016 DCSB TRD Off-Road
    Plenty of great products so far !
    Hmm but the rear bumper hole and shackle were lower on that same side.
  6. Dec 27, 2015 at 5:17 PM
    silverpataco1968
    Eric
    Eastern PA
    That's what she said!
  7. Dec 27, 2015 at 5:18 PM
    PSU Taco85
    optional
    That's true but unfortunetly there was no flat surface to place the jack there so I had to use the side of the bumper.
    Tried here but the jack flew out LOL
  8. Dec 27, 2015 at 5:21 PM
    PSU Taco85
    optional
    sander1036 and Blackout14 like this.
  9. Dec 27, 2015 at 5:21 PM
    silverpataco1968
    Eric
    Eastern PA
    Well, you do like answering for others whenever I make a comment. I would used the top of it look how close it is duh!
  10. Dec 27, 2015 at 5:27 PM
    silverpataco1968
    Eric
    Eastern PA
    Give me a fucking break know it all? Were you their? Who cares ! You could've "jacked off" in a few spots around it!HaHa
  11. Dec 27, 2015 at 5:31 PM
    Fifthwind
    Murph
    Lehigh Valley, PA
    Scully
    Looks like you could have picked from your sliders too. It is obvious that with the taller lift that more pick points become avaliable, but if you only had the 48, you simply would've set the lift at a different point. The 60 is convenient, but not needed, and that extra foot of leverage is a double edged sword, increasing the risk factor faster than adding mechanical advantage. Craig's at least has an oversized metal pad for a better plant but the compression leg is only a 1x2 inch cross section, to balance three tons of truck.
    Littles likes this.
  12. Dec 27, 2015 at 5:48 PM
    LiveFreeOrDie2015
    LiveFreeOrDie2015 Well-Known Member
    York PA
    15 DCSB TRD OFFROAD
    3in lift,Fox suspension,chaos UCA,AAL,leer 180 topper,SilverStar zXe headlights & fog lights,BAMF kickout sliders,Mobtown full skids,Pelfreybuilt center hoop, Pelfreybuilt Gas Tank Skid,50" curved LED light bar, Hood scoop LED, Tran cooler and fan,Oil Catch can,LED Strip lights under hood & Bed,
    Damn guys I didn't know everyone felt so strongly about 48 vs 60 I wasn't trying to start a war.....:eek:
  13. Dec 27, 2015 at 5:56 PM
    Fifthwind
    Murph
    Lehigh Valley, PA
    Scully
    Not everyone needs or can use a 60, plus they can be a PITA to mount or have in the bed, not to mention that these things can quickly become a hazard when in use, and the bigger they are, the more damage they do. Opinions, opinions everywhere.
    Littles likes this.
  14. Dec 27, 2015 at 5:58 PM
    LiveFreeOrDie2015
    York PA
    15 DCSB TRD OFFROAD
    Now you fucked up a 60 is all you need 69 The only options you have is a D or P in your face.....you pick
  15. Dec 27, 2015 at 6:12 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    That's me on the far right. :D
  16. Dec 27, 2015 at 6:16 PM
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    ur a really good watcher,uh i mean superviser.:quickdraw:
    TinyTech626 and Blackout14 like this.
  17. Dec 27, 2015 at 6:17 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Not pictured is my truck as the anchor. :cool:
    Littles, TinyTech626 and Blackout14 like this.
  18. Dec 28, 2015 at 6:14 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Hi-lifts are dangerous as fuck on flat pavement, let alone in a rock garden where there is no flat surface.
    Can you make a 48" work? Yup.
    Will a 60" likely give you more, safer options? Yup.
    Is the $10 you'd save on the 48" worth less choices for a jack point? Up to the one buying...
    Also I'd recommend something like this..
    http://www.sierraexpeditions.com/index.php?l=product_detail&p=13418
    LiveFreeOrDie2015 and Blackout14 like this.
  19. Dec 28, 2015 at 7:16 AM
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    48, 49, whatever it takes.
    silverpataco1968 likes this.
  20. Dec 28, 2015 at 9:50 AM
    LiveFreeOrDie2015
    York PA
    15 DCSB TRD OFFROAD
    The price didn't have much to do with it. Mostly a storage question and how often they get used.
