Keystone State Thread
Discussion in 'North East' started by Tatts521, Jun 20, 2008.
  1. May 6, 2016 at 4:02 PM
    zth25
    zth25 Well-Known Member
    Zach
    Atlantic County x Philly
    2005 DCSB TRD OR 4X4
    887 1.5 AAL JBA UCA's 285/70/17 Trail Graps 17x9 Fuel Hostage Custom Headlights
    On note of alignments, anyone here had any success with Firestone lifetime alignments? I'm thinking of getting one after I do my lift
  2. May 6, 2016 at 4:09 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I got a good set of guys at NTB that do mine. $179.99 three year plan. They dial it in right every time.
    Arailt and Blackout14 like this.
  3. May 6, 2016 at 4:15 PM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Oops. Brain fart
  4. May 6, 2016 at 4:18 PM
    zth25
    Zach
    Could you tell me which location it is? If it's reasonably close I may consider it just for the good reputation they have. It seems so many people get shafted with alignments
  5. May 6, 2016 at 4:28 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    It's the one at woodhaven rd and RT 13 in Bensalem - right off 95.
  6. May 6, 2016 at 5:45 PM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    I had great luck when I lived in southern VA, of course the boys who worked there all drove lifted trucks or aspired to do so.
    Here, not so much. The Admore and south Philly locations I went to are crap at Tacomas, probably great for dropped civics though...
    The Hunter likes this.
  7. May 6, 2016 at 6:23 PM
    Urineovrurhead
    Urineovrurhead Well-Known Member
    05 taco
    Feeler...might anyone have an interest in a set of 5 cooper at3's LT265/75R16 LR:C. Low miles (less then 10k)
  8. May 6, 2016 at 6:29 PM
    P2W
    P2W Whut?
    Whodatsville
    '13 Tacoma DCLB
    Somstuff
    :spy:
    How are the Cs?
    I had Es on my Dodge.
  9. May 6, 2016 at 6:39 PM
    Urineovrurhead
    05 taco
    I like them. As can be expected no where near as stiff. Handle weight well and arent bad as a daily driver tire with no weight.
  10. May 6, 2016 at 7:01 PM
    P2W
    P2W Whut?
    Whodatsville
    '13 Tacoma DCLB
    Somstuff
    :annoyed:
    no reason just cause,..
  11. May 6, 2016 at 7:59 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I know this feel.
  12. May 6, 2016 at 8:04 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I appreciate that Joe - I'll be ok if I can just get the weather to cooperate... Honestly this steering thing has me more concerned than the axle.
  13. May 6, 2016 at 8:18 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Honestly, it's just kinda wandering everywhere. Sometimes pulls left sometimes right. Mushy.
    I've got a feeling the 35's killed the steering rack.
  14. May 6, 2016 at 8:26 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Tie rod inner & outer are solid - no play. LCA's have all new shit. UCA's are lubed & tight. Unless I'm mistaken - and I certainly could be - I think the rack is just shot. :(
    I'm also clueless how to swap that myself.
    Good news is I can get a replacement for $150 - $200 so that's not too bad...
  15. May 6, 2016 at 8:31 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I know they had to pull the steering rack to get the oil pan off when I had that problem a while back...
    More than likely I'll have to get my father-in-law's shop to do it.
    I simply don't have the time.
    Blackout14 likes this.
  16. May 6, 2016 at 8:33 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    me too :fingerscrossed:
  17. May 7, 2016 at 4:51 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Is there play in the rack itself? If you pull the boots off the inners and jiggle the part the inners are attached to is there vertical movement? Can you throw a camera underneath and watch it when you rotate back and forth? Not sure how different it is on second gens but pulling the rack isn't bad, only dealing with the rusty input shaft is.
  18. May 7, 2016 at 7:01 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Can't answer that yet. Need moar investigation...
  19. May 7, 2016 at 7:29 AM
    Arcticelf
    Gladiator
    Even then, I can't get past 1.5 of Caster. That's with 2" of rake on the truck.
    I have a suspicion that the guys claiming 4deg of Caster have a bit of Bro-Dozzer going on.
  20. May 7, 2016 at 8:08 AM
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    @PSU Taco85 has around 3 almost 3.5 last I checked... I mean last time I got a pick of his alignment stats was like 2 years ago when I went to get mine done and asked what his were...
