Keystone State Thread
Discussion in 'North East' started by Tatts521, Jun 20, 2008.
  1. Jan 19, 2018 at 5:13 PM
    Gr8fl
    Gr8fl Some rise, some fall, some climb.
    JK
    Central Bucks, PA
    17 Cement Pro, 20 MGM Land Cruiser
    Lurker here... I saw you on the 611 bypass Thursday and just have to say, rip or no rip, your truck looks awesome.
    HomerTaco and Aztec.Taco[QUOTED] like this.
  2. Jan 19, 2018 at 5:27 PM
    Aztec.Taco
    Aztec.Taco Well-Known Member
    Dave
    2017 Tacoma TRD 4x4 Off Road MGM
    Morimoto Elite HID and XB Foglights, etc...
    I wrapped it in late early November while in Texas. The entire bedside is wrapped not just passed the trim. The grey your seeing is the wheel arch trim and the adhesive gasket that adheres the trim along the edge. I don’t like to primer the whole area, especially since this is textured plastic (that’d be a PITA to get off and possibly ruin the finish). Primer 94 Was on the sharp corner that once existed .
  3. Jan 19, 2018 at 5:29 PM
    Aztec.Taco
    Dave
    Thanks man! I recall seeing a Cement Grey Pro. Easy fix, just sux ya know.
    Gr8fl[QUOTED] likes this.
  4. Jan 19, 2018 at 6:03 PM
    Cazzwell
    Cazzwell The Circuit Rider Signman
    2018 Silver Sky DCSB TRD Sport
    Stock.
    If it is a molded plastic piece (like 4 wheeler/dirt bike shrouds) you have to flash them with a propane torch to get anything to stick to the mould release they use on the parts, followed by plenty of 94 (especially if it is not a smooth glossy surface).
    Primer 94 (even 5+ years old) usually comes off pretty easy with adhesive remover but even denatured alcohol and a little elbow grease works well.
    You only have to be careful if its on flat-paint, soaking it and keeping it wet in the alcohol usually softens it so it doesn't take as much rubbing (which could shine up the paint).
    Aztec.Taco[QUOTED] likes this.
  5. Jan 19, 2018 at 6:08 PM
    Aztec.Taco
    Dave
    Thanks for the tips Cazzwell. Maybe it’s the adhesive remover I’ve been using that gives me issues on textured plastic. I wrapped the truck in a climate controlled shop. I didn’t preheat it, but I used a new type of film that had a slightly different adhesive compared to most ink jet film. It requires quite a bit of post heat and can take quite a bit of heat too. I forget the post heat temp and times on it off the top of my head. I can’t complain much since it was free film from the rep. I like and have been using it on a commercial fleet I’m doing.
  6. Jan 19, 2018 at 6:32 PM
    Cooktop86
    Cooktop86 Well-Known Member
    Jeff
    Hatfield, Pa
    2017 Tacoma TRD sport MGM
    Bullshit why would someone feel the need to do that.
  7. Jan 19, 2018 at 6:55 PM
    Aztec.Taco
    Dave
    Idk, maybe they looked at it and peeled it up and panicked and said to Hell w it and ripped it or they did it to be an ass. Either way it sucks, but good thing is I can have a section printed and re wrap it while it’s somewhat fresh.
    Redmann and Cooktop86[QUOTED] like this.
  8. Jan 19, 2018 at 8:19 PM
    Cazzwell
    Stock.
    We use orange peel adhesive remover. But cleaning surfaces and allowing to dry after using any adhesive remover before reapplying is one of the hardest, since it can lead to failures later on if not done properly.
    Our bucket truck and F-150 are usually testing grounds for a couple different wrap materials the reps try to pawn off on us, but we usually stick to 3M IJ180mc-10 + 3M 8518 for vehicle decals and wraps.
    The only time we use anything else is if the customer specifies, or when we do concession trailers. Then we'll use orajet 3561 + oracal 210 since it seems to hold up to the road chips and people picking at it a little better, but its a little finnikey and only good for flat panels.
    Most vinyl wraps don't need preheat, unless there are a lot of tight compound curves like a around a side mirror or if its cold where you're working, but do need to be post heated (IJ180 needs to be 180°F/90°C)
  9. Jan 19, 2018 at 8:32 PM
    Cazzwell
    Stock.
    I wrapped a truck around a desk once.
    :anonymous:
    Grand dude, wdb, P2W and 2 others like this.
  10. Jan 20, 2018 at 3:33 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    :rimshot:
    Nice one. ;)
    Cooktop86 likes this.
  11. Jan 20, 2018 at 3:35 PM
    steele-taco
    steele-taco Well-Known Member
    james
    Jersey shore
    17 TRD OR DCSB white
    Fresh fries and reasturant style chicken fingers.
  12. Jan 20, 2018 at 3:37 PM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    I'm so hungry
  13. Jan 20, 2018 at 3:45 PM
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    I just had sausage, peppers and onions.
  14. Jan 20, 2018 at 3:57 PM
    El Dahs
    El Dahs I am DTF. Down To 'Froad
    The Real Slim Shadle
    2000 Ford Ranger
    Dents and scratches
    How did you do with the bumper today?
    Blackout14 likes this.
  15. Jan 20, 2018 at 4:00 PM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    Not bad. Still working on it. Well, working on @TacoTim64 sliders right now. Here's where we're at right now.
  16. Jan 20, 2018 at 4:06 PM
    El Dahs
    2000 Ford Ranger
    Dents and scratches
    Looking good. You moving that spare from under there?
    Redmann[QUOTED] and Blackout14 like this.
  17. Jan 20, 2018 at 4:27 PM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    Yeah, I want to make a different kind of tailgate. I don't want a swing out tire carrier because I use my truck like a truck and haul shit all the time. I've been thinking about a tailgate that has a spare tire mount and that I can still fold it down.
  18. Jan 20, 2018 at 4:29 PM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    Saw this for sale on here as a custom one of a kind thing. It doesn't fold down though. I want to do basically this but will still operate like a tailgate.
    WBF610 likes this.
  19. Jan 20, 2018 at 4:30 PM
    Chrysoprase
    Chrysoprase Active Member
    Amish Country, PA
    2017 Cement TRD PRO
    Hey guys! New TRD PRO bought about 3 weeks ago - it's my first truck.
    THATCH11B, ROCdermody, Bumble and 4 others like this.
  20. Jan 20, 2018 at 4:32 PM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    Hey! Welcome. Great people here.
    Chrysoprase[QUOTED] likes this.
