Kicker 8" hideaway question
Discussion in 'Audio & Video' started by C4vettrn, Mar 26, 2022.
  1. Mar 26, 2022 at 12:48 PM
    C4vettrn
    C4vettrn [OP] Well-Known Member
    Randy
    Ft. Wayne IN.
    2015 trd 4x4
    17" SR8's
    I have the key 200.4 and used the Taco Bell wire harness. I kept the two purple wires tapped into the front left channel and ran the under my seat for a sub someday. I have a chance to get the 8" hideaway and was looking at it's wire harness which has provisions for wiring two front channel speakers. Question: Can I only use one channel and tape of the other ? Would this just make it a mono and still work or does it require both channels to be hooked up ?
  2. Mar 26, 2022 at 1:25 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    You can just use one if you want, but you can also use two. It just combines the two signals together.
    mad for using the rear wiring that came installed on the Taco Bell harness, prepare for disappointment if you don’t cut them and splice them to the front channels instead. The rear channels are super anemic and get very little bass signal. The hideaway will have a hard time performing the way it’s intended
  3. Mar 26, 2022 at 4:01 PM
    kzceh
    kzceh Member
    2007 Silver Tacoma TRD Sport
    Are you going to put the hideaway under the front drivers seat?
    I would like to know how well that fits on a 2nd gen once you get it installed. I am looking for a powered sub to put under the front drivers seat. I have done a ton of research on here but have not seen many pictures of how well it fits. I have WeatherTech floormats in the back of my DC and it looks like I may only have 8" of clearance from the Weather Techs to a hump past the vents under the seat. I think the Hideaway is about 9 3/8" deep (or wide) however you want to look at it.
  4. Mar 27, 2022 at 10:15 AM
    C4vettrn
    Randy
    Ft. Wayne IN.
    2015 trd 4x4
    17" SR8's
    Mr. Meek: just bought my harness from them a couple months back and it was tapped in to the front. There was another guy who mentioned this also. They must have figured this out and reconfigured it.
    Kzceh: sad story but no longer have the 2 nd gen. I have a 2020 OR but I can't figure out how to change it in my info.
