Kicker amp SMOKED
Discussion in 'Audio & Video' started by Squeakytaco2019, Oct 31, 2024.
  1. Oct 31, 2024 at 8:04 PM
    Squeakytaco2019
    Squeakytaco2019 [OP] Active Member
    Andrew
    2019 TRD off-road
    Fabtech Dirtlogic 2.5 front and back Icon leaf pack option 1
    Well my Kicker 660.5 smoked!
    I’m taking this chance to upgrade to dual amps. For mids and highs I’m running Polk DB’s,100w rms @ 4 ohms. With a Polk d4000.4, 125w rms @ 4 ohms. For my sub I’m running 10” RF P3S 4ohm dvc.
    Here’s where I need a little help. Can I get away with using my existing 4awg copper power cable to split between the Polk 4000.4 and a RF p300.1, 300rms at 2ohm?
    If I have to upgrade the cable size I’m thinking I will change my amp to a Polk d1000.1 and either turn the gain down low or run the sub as a 8 ohm load. This will give me room to upgrade my sub later if I want. Does this sound like it will work?
  2. Nov 1, 2024 at 3:41 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Yeah you should be fine
    the Polk has 75A worth of fuses.
    The RF doesn’t have onboard fuses, but 300w amps don’t have a ton of draw.
    good quality 4awg is good for 100A so you’ll be fine unless you run your system maxed out for an hour straight, which will permanently damage some hearing
  3. Nov 1, 2024 at 6:04 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    ^+1.
    but i'd also seriously investigate why the amp went up in smoke. typically it's installation or settings related. the importance is to try to fix the issue so the new amp doesn't meet the same end.
    Stevie17 and Squeakytaco2019[OP] like this.
  4. Nov 2, 2024 at 5:32 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Yeah definitely find the source of the problem. Those C-series amps have some decent protection features so if it literally smoked, something ain’t right.
