kicker amp?
Discussion in 'Audio & Video' started by AJ4X4, Mar 23, 2012.
  1. Mar 23, 2012 at 10:48 PM
    AJ4X4
    AJ4X4 [OP] Well-Known Member
    White 2010 TRD Off Road Double Cab
    I am new to aftermarket audio systems and i want to add subs and amp to my truck. I found the Amazon box that i think i want sealed. I want kicker 10" compvr subs. What amp do y'all recommend? I've looked at the kicker zx 300.1 400.1 and 500.1
  2. Mar 23, 2012 at 11:29 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    First make sure before you order your box that it contains the correct air space for the subs if it does then how many subs do you want? What's your price range? For full power to one sub you're looking at the 500.1 for full power to 2 subs you want a 1000 rms amp.
  3. Mar 24, 2012 at 3:40 AM
    Tidrow
    Tidrow Well-Known Member
    Austin
    PreRunnin' 08
    BHLM, All Black grill, Fog light Mod, AFE pro dry, 20% tint, Weathertechs, Kenwood deck, Bridgestone AT Revo 2
    I have a kicker 700.5... it's bad ass
  4. Mar 24, 2012 at 8:07 PM
    AJ4X4
    I want kicker compvr. 2 10's. They are 140 for two at sonic electronix. I haven't been able to find the dimensions of the box. The reason i asked about those amps are because i have a friend with a 300.1 with two kicker compvrs 12's in a sealed box and it sounds good. Hits really hard to only be 300w. Also can anybody refer me to a place to find a good cheap box for my 2010 double cab?
  5. Mar 24, 2012 at 8:09 PM
    Warhorseforever
    Will
    Sand Lapper
    Supercrewsound.com
  6. Mar 24, 2012 at 9:21 PM
    AJ4X4
    Those subs wont work with the box that goes behind the seat. What subs do y'all recommend for the box. Its got 0.75 cubic foot per sub
  7. Mar 24, 2012 at 9:51 PM
    Warhorseforever
    Will
    Sand Lapper
    This box? It'll work just fine but will want to stuff the box a little bit.
  8. Mar 24, 2012 at 10:07 PM
    AJ4X4
    Stuff it? The subs are rated for 1 cubic foot
  9. Mar 24, 2012 at 10:11 PM
    Warhorseforever
    Will
    Sand Lapper
    With Polyfil it's the stuff that they put in pillow's when you put it in sub boxes then it makes the air move slower and the speaker "thinks" it has more space than it actually does. Kicker's website has the minimum air space for the subs at .8ft^3 if you put in 2-3 handfulls of polyfil then it should simulate a .8 or bigger box.
  10. Mar 24, 2012 at 10:32 PM
    AJ4X4
    Will it hit pretty hard? I found a kit on hifi sound connection. The kit has 2 cvrs kicker dx1000.1 amp and a 600w wiring kit. Is this a good set up? Is this website a good place?
  11. Mar 24, 2012 at 10:42 PM
    Warhorseforever
    Will
    Sand Lapper
    I'm sure it'll sound good and hit but how hard I don't know but I'd be willing to bet that it'll suit your needs because finding 1 cubic foot of air space for 2 subs is going to be hard even though at .75 it is close. I have no experiance with HiFisoundconnection but if you're buying an amp kit for a 1000w amp look for one that has a power wire gauge of at least 4 gauge and around 80 amp fuse.
  12. Mar 24, 2012 at 10:54 PM
    AJ4X4
    The kit is 319. Seems like a good deal. Can you tell a difference in a 2 or 4 ohm sub?
  13. Mar 24, 2012 at 11:05 PM
    Warhorseforever
    Will
    Sand Lapper
    As in sound quality? Not really but it makes a huge difference when it comes to wiring it to an amp.
  14. Mar 24, 2012 at 11:22 PM
    AJ4X4
    So what do you recommend?
  15. Mar 25, 2012 at 12:01 PM
    Warhorseforever
    Will
    Sand Lapper
    That package you're looking at with the subs and DX1000.1 will be fine but make sure that the subs are dual 2 ohm voice coils so that you can wire it for a 2 ohm final load which you will do like this.
  16. Mar 26, 2012 at 11:17 PM
    sun
    sun Well-Known Member
    Memphis
    2011 PreRunner
    Pioneer avic-z130bt with axxess aswc and rear cam mod, audiovox 10 flip down monitor, Pyle pl76d headrest monitors, kicker cvr tens wired down to one ohm with hifonics Brutus 1200.1, Clazzio seat covers, 20% tint on front windows, polished factory exhaust, peragon retractable bed cover, pop n lock tailgate handle with dei actuators for automatic lock, viper 5901 alarm remote start with viper smart start, hid bixenon 4500k headlights with 4500k fog lights, led map license plate lights and dome lights
    I got the cvrs and I like em I running them on a hifonics Brutus 1200 I got my stuff with wil polyfil but I made my box
  17. Mar 27, 2012 at 7:01 PM
    AJ4X4
  18. Mar 28, 2012 at 7:39 AM
    Warhorseforever
    Will
    Sand Lapper
    Again a DX1000.1 will work great for those subs but to get full power to them you would want something around 1,600w rms which you could get a Kicker ZX1500.1 to run them right at that rms range.
  19. Mar 28, 2012 at 9:18 AM
    sun
    Memphis
    2011 PreRunner
    Actually those amps won't work because when u wire them up they will be either 1 ohm or 4 ohm together
  20. Mar 28, 2012 at 9:24 AM
    Warhorseforever
    Will
    Sand Lapper
    Yikes you're right I was thinking they were 1ohm ratings on the website. Forgive me my brain ain't working to good today, midterms are frying it up.
    Edit: You could do a JL 1000/1 but that's a little up there in price and size but it'll do 1000w no matter how you wire it up to 8 ohms and down to 1.
