Kicker hideaway- final upgrade to the $250(+) 3rd gen premium upgrade (+Kicker Key 180.4 amp)
Discussion in 'Audio & Video' started by Exracer2, Mar 29, 2018.
  1. Jul 25, 2018 at 9:12 PM
    #181
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    For the wires in your hand, connect all of the solid colors together, and all of the black striped wires together.
    Solid grey from radio side, solid grey from vehicle side, solid grey from sub, solid white from sub
    Striped grey from radio side, striped grey from vehicle side, striped grey from sub, striped white from sub
    Normally one would do the greys together and the whites together, but you’ve already soldered your whites in the main harness so no biggie
  2. Jul 25, 2018 at 9:27 PM
    #182
    Disco
    Disco Well-Known Member
    Diego
    San Diego
    2018 TRD Offroad 4x4 DCSB Cement
    Thanks, I just soldered the wires as shown in OP's post. Wife is putting the kids to bed so I'm gonna keep plugging away at this.
  3. Jul 25, 2018 at 11:00 PM
    #183
    Disco
    Diego
    San Diego
    Ok got it wired and just fired it up. It definitely packs some punch for such a small unit! Even at just halfway up on the bass remote, I'm getting quite a bit of rattling from the back though. I'm gonna have to figure out how to secure it so it doesn't rattle back there.
    Thanks guys for all your help getting it wired in!
    MolonLabeTaco and destin_meeks like this.
  4. Jul 25, 2018 at 11:24 PM
    #184
    Disco
    Diego
    San Diego
    I just stuck a couch cushion back there which actually made a huge difference, sounds great! I will mess with the settings tomorrow to fine tune it.
  5. Aug 4, 2018 at 4:42 AM
    #185
    Braves95
    Braves95 Go Clemson Tigers
    David
    Central PA
    17 MGM TRD Off Road DCSB P&T 6MT
    Fab Fours Bumper Block Heater Dual Exhaust Flow Master Smittybilt 12k Winch Synthetic Rope Bed Mat Roof Rack Puddle Lights 17" Rockstar Wheels NittoTerra Grapplers Power TailGate Lock Tonneau Cover w/lights Mobtown sliders MT Remote Start Tinted Windows Front And Rear Camera BRC Competition Diff Breather Bed Step Weather tech Floor Mats TRD Pro Tail lights TRD MT Shift Knob ARB dual compressor URD short shifter Kings 2.5 OEM W/remote resi. Click adjuster.
    Ok back to the taco tunes conversation! HAHA just kidding.
    But now seriously, I have the following:
    Tweeter upgrade
    The kicker front and tears
    JL Audio 10w6v3
    Alpine halo 9
    Rockford 5 channel amp
    Did you make the harness so that the tweeter upgrade can still be used with the fronts? Does it make it to HIGH with four tweeters in the mix up front? Does it drop the impedance?
  6. Aug 4, 2018 at 7:07 AM
    #186
    destin_meeks
    Destin
    Tuscaloosa, AL
    The tweeters will still work just using the 2 metra pieces listed in this thread. To me, it makes the highs a bit harsh (using the factory radio) but that HALO9 should give you enough EQ settings to fine tune it way more than the factory head unit. Put on a song with lots of highs (rock with lots of cymbals crashing, if thats your music) and pull uptake EQ and start playing with the upper bands till you get it where you want. Or just try some of the presets to see if they fit your liking
    Edit* they wont drop the impedance enough to matter with that rockford amp pushing them.
    Braves95 likes this.
  7. Aug 4, 2018 at 7:27 AM
    #187
    Braves95
    David
    Central PA
    So I need 2 of the adapters?
  8. Aug 4, 2018 at 7:32 AM
    #188
    destin_meeks
    Destin
    Tuscaloosa, AL
    You shouldnt actually need anything. You already have the metra harness connected to the halo.
  9. Aug 4, 2018 at 8:24 AM
    #189
    Braves95
    David
    Central PA
    Even if I want to run the wires to the Rockford amp?
  10. Aug 4, 2018 at 8:29 AM
    #190
    Braves95
    David
    Central PA
    I want to run heavier gauge wire to get the 100 watt to speakers.
  11. Aug 4, 2018 at 9:07 AM
    #191
    destin_meeks
    Destin
    Tuscaloosa, AL
    Factory wiring will handle 100w. And from personal experience, just because your amp CAN do 100w does not mean that’s what you’ll be doing. I’m running 50w per channel and my young ears can’t handle more than about 80% volume. I was running 75w per channel in my jeep and with the top down and doors off, I couldn’t hear a semi pass me on the highway.
  12. Aug 4, 2018 at 9:12 AM
    #192
    destin_meeks
    Destin
    Tuscaloosa, AL
    To get the amp wired up, get a roll of speedwire and run that from the amp back up behind the head unit. Then, where the halo speaker wires are spliced to the metra harness along with power, ground, and accy, cut off the halo speaker wires and now you have your inputs to the factory wiring. Connect your newly run speed wire to those and you’re all set
    Braves95[QUOTED] likes this.
  13. Aug 4, 2018 at 9:40 AM
    #193
    Braves95
    David
    Central PA
    Got it thanks.
    destin_meeks[QUOTED] likes this.
  14. Aug 4, 2018 at 2:25 PM
    #194
    destin_meeks
    Destin
    Tuscaloosa, AL
    Let us know if you need anything and how it sounds!
  15. Aug 4, 2018 at 7:22 PM
    #195
    irANTHONY
    irANTHONY Well-Known Member
    Ordered!
    destin_meeks likes this.
  16. Aug 4, 2018 at 9:46 PM
    #196
    MicrowaveKane
    MicrowaveKane Member
  17. Aug 4, 2018 at 10:05 PM
    #197
    Exracer2
    Exracer2 [OP] Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    I am sure you could. The metra harnesses were a solution @destin_meeks came up with so I could avoid doing business with a particular vendor who had a plug and play harness similar. Yes the metra harness involves soldering but it avoids any hacking of the stock wiring harness or having to resort to scotch-lock connectors.
    The advantage to soldering is the connections will never corrode or pull apart. It is 10-15 minutes work including shrink wrap. For those who can’t solder you could always connect the two harness halves with butt connectors. Less clean and tidy than solder but still effective but it can pull apart or corrode if pulled on or conditions allow corrosion.
  18. Aug 5, 2018 at 4:38 AM
    #198
    destin_meeks
    Destin
    Tuscaloosa, AL
    That would definitely work as a simple solution. A bit pricey at $30, and you still need RCA cables long enough to reach the sub. But gets the job done for sure.
    _Rusty_Shackleford_ likes this.
  19. Aug 5, 2018 at 8:27 AM
    #199
    Braves95
    David
    Central PA
  20. Aug 5, 2018 at 9:56 AM
    #200
    destin_meeks
    Destin
    Tuscaloosa, AL
