Kicker hideaway- final upgrade to the $250(+) 3rd gen premium upgrade (+Kicker Key 180.4 amp)
Discussion in 'Audio & Video' started by Exracer2, Mar 29, 2018.
  1. Dec 23, 2018 at 8:45 AM
    #281
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    One side is the power antenna connection and the other side would be the amp turn-on for the trucks that have factory amps.
  2. Dec 23, 2018 at 5:49 PM
    #282
    COdude3
    COdude3 Well-Known Member
    Colorado
    2017 SR5 Access Cab 4x4
    Pro Grille, Pro Whls, King Shocks, 265/75R16 A/T3
    Just to clarify, you are saying the blue wire from pin #8, right? The ECU wiring diagram does not say pin #8 is used - but from reading this thread it looks like it has been tested to put out +12v when the radio is on. So my plan is to cut blue wire and use pin #8 for remote turn on and de-pin the other end and use it for small rear harness.....am I on the right path?
    @destin_meeks, thanks for contributing to this thread. You have been a big help!
  3. Dec 23, 2018 at 5:57 PM
    #283
    COdude3
    Colorado
    So, I just reread the first post and feel stupid. Looks like amp turn on is blue/white. So I just need to de-pin blue loop wire and use it for small rear harness.
  4. Dec 23, 2018 at 5:57 PM
    #284
    destin_meeks
    Destin
    Tuscaloosa, AL
    the only wires used in the smaller rear harness are the purple and green speaker wires.
  5. Dec 24, 2018 at 4:17 AM
    #285
    LVLAaron
    LVLAaron Well-Known Member
    Aaron
    2018 TRD Off Road
    On my 2018, the "small rear harness" also had a dimmer wire in it. I cut and depinned the blue loop, to insert into the metra small rear harness. If you dont the lights on the radio will be OFF instead of Dim when the headlights are on. Again, for the new guys it'll make perfect sense once you're looking at it.
    My metra harness already had the blue/white wire for remote turn on.
    Hot Taco sauce likes this.
  6. Jan 1, 2019 at 4:59 PM
    #286
    kodaco771
    kodaco771 Well-Known Member
    So Cal
    2017 OR DCLB 4x4
    6112/5160's & Wheeler's Progressive 3AAL SCS SR8’s
    I just got done completing the Hideaway install. All of my truck’s speakers work and the power light on the Hideaway is on but there is no sound coming from the sub. I double checked my harness and the whites are spliced to the whites, whites/blacks together, and grey together and grey/blacks together. Any thoughts on what the problem might be would be greatly appreciated. The only thing I can think of is to cut the shrink tube and make sure the solders are good but looking at it they still look and feel strong.
  7. Jan 1, 2019 at 5:19 PM
    #287
    destin_meeks
    Destin
    Tuscaloosa, AL
    Step one, make sure your Hideaway fuses aren’t blown (at the battery and on the side of the enclosure)
    Step two, make sure auto turn on is set to dc and input level set to high.
    If you still have issues, you’ll need to run the blue remote wire to an accy source. The auto-turn on is hit or miss
  8. Jan 1, 2019 at 5:57 PM
    #288
    kodaco771
    So Cal
    2017 OR DCLB 4x4
    So both the fuses are good. I connected the blue remote wire from the Hideaway to the solid blue wire in the Metra harness. I used 16 gauge speaker wire that I had on hand for the remote wire. Could that be the problem? Does the wire type/gauge matter on the remote?
  9. Jan 1, 2019 at 6:03 PM
    #289
    LVLAaron
    Aaron
    2018 TRD Off Road
    Not really.
    Does the amp have a power/on indicator LED?
  10. Jan 1, 2019 at 6:10 PM
    #290
    kodaco771
    So Cal
    2017 OR DCLB 4x4
    Yes, blue light is on.
  11. Jan 1, 2019 at 6:13 PM
    #291
    destin_meeks
    Destin
    Tuscaloosa, AL
    Is the gain all the way down? Or the bass knob turned all the way down?
  12. Jan 1, 2019 at 6:31 PM
    #292
    kodaco771
    So Cal
    2017 OR DCLB 4x4
    Gain is halfway and I have the knob unplugged.
  13. Jan 1, 2019 at 6:38 PM
    #293
    destin_meeks
    Destin
    Tuscaloosa, AL
    Do you have an aux-to-RCA cable? If so, try hooking your phone up to the sub with it and see if you get any audio
  14. Jan 1, 2019 at 6:50 PM
    #294
    kodaco771
    So Cal
    2017 OR DCLB 4x4
    I have aux-RCA. How do I hook it up?
  15. Jan 1, 2019 at 7:08 PM
    #295
    destin_meeks
    Destin
    Tuscaloosa, AL
    Oh yeah, I forgot the Hideaway doesn’t have rca’s Like most amps.. do you have a multimeter?
  16. Jan 1, 2019 at 7:22 PM
    #296
    kodaco771
    So Cal
    2017 OR DCLB 4x4
    I just put wires into the harness’ plug where it connects to the sub then connected those to an old speaker. It played so the sub is receiving the audio. Could the ground be bad? I connected it to the factory ground under the driver’s seat.
  17. Jan 1, 2019 at 8:06 PM
    #297
    destin_meeks
    Destin
    Tuscaloosa, AL
    That should be fine for a ground. It’s best to sand down the paint but it’s probably not needed for just the Hideaway. Aside from what we’ve talked about, I’m out of ideas for right now
  18. Jan 1, 2019 at 8:28 PM
    #298
    kodaco771
    So Cal
    2017 OR DCLB 4x4
    Thank you for your help, much appreciated.
  19. Jan 7, 2019 at 9:17 AM
    #299
    Cardsallday13
    Cardsallday13 Well-Known Member
    2017 DCSB TRD Sport 4x4
    For those who added an amp like the key, after you did the upgrades with the sub...
    Did adding the amp make the door speakers drown out the sub volume?
  20. Jan 7, 2019 at 9:58 AM
    #300
    Exracer2
    Exracer2 [OP] Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    I turned the Hideaway up after the Key install to better match the sub. Those higher sub levels without the Key were overpowering the rest of the system. Once the system became more powerful with the Key installed the sub needed to be matched so I turned the sub gain up.
