Kicker hideaway- final upgrade to the $250(+) 3rd gen premium upgrade (+Kicker Key 180.4 amp)
Discussion in 'Audio & Video' started by Exracer2, Mar 29, 2018.
  1. Feb 7, 2019 at 4:56 PM
    #341
    Cardsallday13
    Cardsallday13 Well-Known Member
    2017 DCSB TRD Sport 4x4
    Ok. It could also be the led lights I installed too
  2. Feb 8, 2019 at 9:33 AM
    #342
    Cardsallday13
    The place that did the amp thinks they found it. They found that the amp was back feeding power and staying on about 15 seconds past the time of turning the truck off. they put in a relay to cut it off and the issue went away.
  3. Feb 8, 2019 at 10:02 AM
    #343
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Yeah different amps act different ways. Some of them (kicker cx amps, for example) always try to use auto-turn-on even if you dont want it to. When its using the auto, the remote input between the power and ground wires actually becomes an OUTPUT you can use to turn on addition amps. This causes an issue when using the accy wire for the radio to turn on the amp because now it's backfeeding power to that accy wire, thus keeping the radio on. And as long as the radio is on, the amp is on, which keeps the radio on, and it's just an endless loop.
    Glad they got it taken care of!
  4. Feb 8, 2019 at 12:50 PM
    #344
    Cardsallday13
    Just got it back. that was it. the relay fixed all issues. whew
    destin_meeks[QUOTED] likes this.
  5. Feb 8, 2019 at 5:30 PM
    #345
    skierd
    skierd Well-Known Member
    David
    Fairbanks, AK
    2021 F150 XL STX Screw 4x4 2.7
    I’m going to try to set my Key amp up next week and wanted opinions on how I should set my dip switches. I’m going to be powering my front and rear speakers and want to use the auto EQ.
    I’m going to be using a remote wire, so I want the 12V not DC correct? I know I want the EQ set to EN and bi-amp off. Fader should be on too right?
    What about compression? What does that do exactly? And I think I want to leave time delay on too correct?
  6. Feb 8, 2019 at 6:30 PM
    #346
    destin_meeks
    Destin
    Tuscaloosa, AL
    If you’re not running a subwoofer, you want the dip switches all up.
    If you do have a sub, you might want to set the last two down.
  7. Feb 9, 2019 at 4:43 PM
    #347
    COdude3
    COdude3 Well-Known Member
    Colorado
    2017 SR5 Access Cab 4x4
    Pro Grille, Pro Whls, King Shocks, 265/75R16 A/T3
    Finally hooked up my Key, everthing sounds great except I get a slight pop from the speakers when I turn on or off the truck. Is this normal?
  8. Feb 9, 2019 at 4:48 PM
    #348
    Exracer2
    Exracer2 [OP] Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    Might try turning down the gain a tiny bit. I believe mine makes a small noise when it first powers up or maybe it’s the Hideaway. Can’t remember.
  9. Feb 9, 2019 at 4:48 PM
    #349
    destin_meeks
    Destin
    Tuscaloosa, AL
    Are you using the 12v or DC offset for turn on?
    Either way, try the other option. That’s normally my first try just to see.
    And yes, make sure the gains aren’t too high as well. I’ve found the limiter light to be a huge over-exaggeration and I tend to set the gain a good bit lower. As long as you get good volume with the radio at 75%, the gains are good there
  10. Feb 9, 2019 at 5:28 PM
    #350
    COdude3
    Colorado
    I'm running DC offset. I tried the 12v, but could not get it to work. I connected the remote turn on wire to the blue wire on the metra harness 71-1761. Measured a constant 5v. When I connected the metra wire to the key my volume controls on the HU would not work and the key did not power up.
  11. Feb 9, 2019 at 5:53 PM
    #351
    destin_meeks
    Destin
    Tuscaloosa, AL
    That’s... odd.
  12. Feb 9, 2019 at 5:57 PM
    #352
    Exracer2
    Colchester Ontario
    Check if it is the right blue wire. Also check if the dc offset is on.
    I had an issue like this and it was something silly.
  13. Feb 9, 2019 at 6:05 PM
    #353
    Exracer2
    Colchester Ontario
    I went back and checked a few PM’s between @destin_meeks and I. Make sure you grab the right blue remote turn on wire and from the right end of the harness.
    At one point I had the dead volume knob on the head unit. I believe that was from output from the Key making the head unit go into “safe” mode. I believe Destin said the remote turn on goes hot in a certain situation. I’ll let him chime in because I don’t remember the details.
    In the end it was my mistake and incorrect wiring. I have been using remote turn on and zero issue once I fixed my wiring mistake.
  14. Feb 9, 2019 at 7:11 PM
    #354
    COdude3
    Colorado
    So I disconnected the remote turn on wire and made sure DC offset switch was turned on. Turned the gains to 0 and I still get a pop when I turn the truck off - regardless if the HU is on or off. If the HU is off (and the amp is off because I'm not hearing any white noise), why would I get a pop?
  15. Feb 10, 2019 at 1:01 PM
    #355
    COdude3
    Colorado
    I figured it out - connected the ignition power to the key (red harness wire), corrected the mistake by connecting to the constant power source (yellow wire on the metra harness). I can't believe how awesome the key is. My stereo sounds amazing. I'm glad I went with the key first, instead of the hideaway. The key really brings the front 6x9 bass alive. Plenty of bass for me, no need for the hideaway.
  16. Feb 10, 2019 at 1:07 PM
    #356
    destin_meeks
    Destin
    Tuscaloosa, AL
    wait... please clarify what you wired where.
    I read that as "I originally wired the Key's blue wire to the metra red wire, but moved it to the metra yellow wire"
    but I am hoping you meant you originally contacted the Key red wire to the Metra red wire, but moved it to the metra yellow wire
    If the Key's blue wire is on the metra yellow, you'll be in for a dead battery pretty soon!
    northtorrey likes this.
  17. Feb 10, 2019 at 1:08 PM
    #357
    Exracer2
    Colchester Ontario
    IF you add the Hideaway to it you will have that little bit of extra bass for those tunes that need it. I found I could turn down the bass on the head unit and let the hideaway do more of the bass.
  18. Feb 10, 2019 at 1:33 PM
    #358
    COdude3
    Colorado
    Originally was Key red to Metra red, than changed to Metra yellow and Key red. I'm not using the remote turn on (using DC offset) from the key, so nothing is connected to the blue wire from Key and nothing is connected to blue or blue/white from harness. No more pop, just a slight click when the amp turns off. Man am I glad I came across this thread, that little amp rocks!
  19. Feb 10, 2019 at 1:34 PM
    #359
    destin_meeks
    Destin
    Tuscaloosa, AL
    Ok great, just making sure you didn't have the key blue to metra yellow! That would keep the amp on constantly and that would create a problem!
  20. Feb 10, 2019 at 1:36 PM
    #360
    COdude3
    Colorado
    I must be getting old because there is a crap load of bass. My side mirrors rattle, my door windows rattle, and I can feel a good thump next to my leg. I only have the gain set at 10 o'clock rear and 9 o'clock front - very little gain with barely any white noise.
