Kicker hideaway- final upgrade to the $250(+) 3rd gen premium upgrade (+Kicker Key 180.4 amp)
Discussion in 'Audio & Video' started by Exracer2, Mar 29, 2018.
  1. Apr 26, 2020 at 1:52 PM
    #501
    CXYyuppie
    CXYyuppie Sarcasm Master
    Craig
    SE.LA
    2019 TRD Sport DCSB - Cement
    Stuff with some other black things
    Ok, I finally had time to get back to working on the amp combo.
    I have pulled the HU out and this seems to match up to what I have.
    Would this color code be correct for 2019?
  2. Apr 26, 2020 at 2:04 PM
    #502
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Yep
  3. Apr 26, 2020 at 2:08 PM
    #503
    CXYyuppie
    Craig
    SE.LA
    So would you say I could tap in this with T-taps? I would use the front right speaker and the gray for the switched ignition power to the “blue” remote wire to the amp.
    Sorry to be PITA.
  4. Apr 26, 2020 at 2:31 PM
    #504
    destin_meeks
    Destin
    Tuscaloosa, AL
    Yeah that will work. Just make sure the hideaway switch is set to 12v
    CXYyuppie[QUOTED] likes this.
  5. Apr 26, 2020 at 3:34 PM
    #505
    CXYyuppie
    Craig
    SE.LA
    Holy cow it works. It has everything to do with the remote wire. I ended up connecting everything behind the HU. Now I just have to put it all back together.
    :yay:
    Thank you so much for answering my questions.
    siKjiTz and shane100700 like this.
  6. Apr 26, 2020 at 4:12 PM
    #506
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Woop woop!! Congrats Craig! Did you just t-tap then?
  7. Apr 26, 2020 at 4:56 PM
    #507
    CXYyuppie
    Craig
    SE.LA
    Thanks. Yes, that’s what I used. I could not get the harness delivered in time before I went back to work. Honestly, it was crazy to try the other way first but others seemed to get it to work. I may try to order the harness and swap it over in a couple of weeks when I get home.
    I had to take a break to eat supper. Now I just have to finish putting in the back panels and secure the amp. But it works good. Yahooooo!
    siKjiTz and shane100700[QUOTED] like this.
  8. Apr 27, 2020 at 11:40 PM
    #508
    Hot Taco sauce
    Hot Taco sauce Well-Known Member
    WI
    Dclb lover
    Just starting out, give me time
    This needs to be added in original post for 2018+ years trucks
  9. May 5, 2020 at 9:53 AM
    #509
    Hot Taco sauce
    WI
    Dclb lover
    @destin_meeks or anybody else that has ran 4 gauge wire through firewall how and where did you do it? I watched a YouTube video from oem audio that he ran 8 or 10 gauge through the passenger side that had two nipple looking things and cut one off. I did that to run my 10 gauge to my small Alpine amp behind the deck but I also have a bigger Rockford amp to run sub or subs that is running 4 gauge. I tried to push it through the other nipple unsuccessfully and am about to give it up for awhile. Any advice would really make my day. Thanks
  10. May 5, 2020 at 10:17 AM
    #510
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    I haven’t run amp power yet but did several switch wires through the firewall. There is more then enough room to add a 4 gauge if needed. I know people don’t like to drill into their vehicles but it really is a great location. If I ever need to plug it, the right sized panel clip will work just fine.
  11. May 5, 2020 at 3:10 PM
    #511
    destin_meeks
    Destin
    Tuscaloosa, AL
    If you don’t have the big booster there, there is a factory grommet in the red circle, or you can easily drill a hole in the kidney-shaped area in the green circle. Both are completely safe spots. You will need to cut through the insulation material on the inside of the cab. I suggest poking through it from the engine side with a pick tool or long nail or something so you can see where to cut the material (cuts decent with a razorblade)
    shane100700 likes this.
  12. May 5, 2020 at 4:31 PM
    #512
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Green spot is where I drilled in the post right above. Like @destin_meeks says, just cut a slit into the insulation with a razor blade. I used a fish tape I have to pull the wires. Woke great!
  13. May 5, 2020 at 10:20 PM
    #513
    Coolfinedonewicked
    Coolfinedonewicked Well-Known Member
    Kaua’i, Hawai’i
    2019 Cement Tacoma TRD OR DCSB
    Can anyone point me in the right direction as to the closest ground I can use for the hideaway from under the driver’s seat? I read OP extended to chassis ground, but I’ve no idea where that is. I also did a search of the thread and google, but to no avail really... atleast visually. Seems like either way I’ll need to extend ground wire, just like to get an idea of how much extra length I’ll need.
  14. May 5, 2020 at 10:26 PM
    #514
    CP40
    CP40 Well-Known Member
    Toyota Tacoma TRD off-road 2020
    Have you got the hideaway under the driver's seat yet? Did you have to move the vents?
  15. May 5, 2020 at 10:58 PM
    #515
    Coolfinedonewicked
    Kaua’i, Hawai’i
    I just slid it under there, I wasnt sure it would fit with the vents and my floor mats (double cab) but it seems like no problems. Pretty much like OP’s pics.
  16. May 5, 2020 at 11:04 PM
    #516
    jurassicmark1
    jurassicmark1 Well-Known Member
    Chula Vista
    2016 TRD Sport 4X4 6MT, KINGS, OVTuned
    King Suspension F&R Total Chaos UCA’s ICON RXT Leaf Springs 4Runner TRD Pro Wheels BFG KO2’s 265/70 R17 OV Tune 2.0 SFOB
    Has anyone upgraded from the 8” hideaway to the 10” one? I’m wondering if it’s even worth it?
  17. May 6, 2020 at 3:26 AM
    #517
    Hot Taco sauce
    WI
    Dclb lover
    There is supposed to be a ground under the carpet under the driver seat. I can't guarantee that but from other videos that I have seen that's where it's at
  18. May 6, 2020 at 5:43 AM
    #518
    Homiec
    Homiec Well-Known Member
    2020 TRD Sport Access Cab 4X4 MT
    MGMDesertTaco and shane100700 like this.
  19. May 6, 2020 at 8:38 AM
    #519
    Coolfinedonewicked
    Kaua’i, Hawai’i
    Ace’s! Thank you both!
  20. May 7, 2020 at 2:45 PM
    #520
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    @destin_meeks
    Any confirmation on my T-harness would be greatly appreciated. I’m confident enough that I have already soldered and wire loomed everything, but wanted a thumbs up before doing my install next week.
    If I want speaker level inputs, front only, then below is how I would make (made) the harness...
    Yellow- yellow
    Red-red
    Black-black
    Orange/white-orange/white
    Blue-blue
    Blue/white- extended (did not tie to any other wires from female harness) and ran as a stand alone remote wire. Not needed for high level but makes sense to run it for future proof.
    Gray (+)/ gray/black (-) both tapped as right front input
    white (+)/ white/black (-) both tapped as left front input
    Again, my intent is a line out harness for high level inputs to an amp/DSP.
