Kicker Hideway Stays On
Discussion in 'Audio & Video' started by grubburg, Feb 10, 2019.
  1. Feb 10, 2019 at 4:13 PM
    grubburg
    grubburg [OP] Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    Running remote cable to fuse box. Fuse says 30 on it. Fuse says radio # 2, 30 amp.
    When i turn The truck off the hideaway stays on???
    :confused:
  2. Feb 10, 2019 at 4:15 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Does it eventually shut off?
  3. Feb 10, 2019 at 4:19 PM
    grubburg
    2019 TRD OR MT
    Nah. I had it on 12v not dc too.
  4. Feb 10, 2019 at 4:27 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    The 30amp fuse you're talking about is normally for the JBL amp, and it has constant power. You need to find a circuit that turns off with the truck, or grab the accy wire behind the radio.
    since you already have the wire run to the fuse box, try one of the fuses for cig lighter.
    What year is your truck?
  5. Feb 10, 2019 at 4:35 PM
    grubburg
    2019 TRD OR MT
    2019 Ted off road
  6. Feb 10, 2019 at 4:44 PM
    grubburg
    2019 TRD OR MT
    I dont know which is cigarette?
  7. Feb 10, 2019 at 4:45 PM
    tcjacado
    tcjacado Well-Known Member
    The outlet next to the USB port below climate controls.
  8. Feb 10, 2019 at 4:47 PM
    grubburg
    2019 TRD OR MT
    Yeah what fuse goes to that though
    tcjacado likes this.
  9. Feb 10, 2019 at 4:48 PM
    tcjacado
    Yeah I am not sure on that... hopefully someone else can chime in.
  10. Feb 10, 2019 at 4:48 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    The cig lighter fuses are in the interior fuse panel. up under the drives side dash.
  11. Feb 10, 2019 at 4:51 PM
    grubburg
    2019 TRD OR MT
  12. Feb 10, 2019 at 4:52 PM
    grubburg
    2019 TRD OR MT
    Never mind wrong box!!!
  13. Feb 10, 2019 at 4:54 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    yeah, unfortunately you'll have to go to the interior fuse box. nothing under the hood will work for this particular use. you can use "poutlet1" or "poutlet2" or "ecuacc"
  14. Feb 10, 2019 at 4:55 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
  15. Feb 10, 2019 at 4:56 PM
    grubburg
    2019 TRD OR MT
    It has to be 12 V
  16. Feb 10, 2019 at 4:57 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    those are all 12v
    xxTacocaTxx and tcjacado like this.
  17. Feb 10, 2019 at 5:45 PM
    grubburg
    2019 TRD OR MT
    Got it thanks!!!
