Kicker hs8 under driver seat install help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 82nate, Jun 5, 2020.
  1. Jun 5, 2020 at 12:12 PM
    82nate
    82nate [OP] Member
    Nate
    2020 Tacoma
    I'm trying to install my Kicker hs-8 hideaway sub under my driver's seat. No matter how I try to slide it in from behind it, it seems like it is half an inch too big to get past where the seat is bolted down. I hate to unbolt the entire seat for an experiment if it's not going to work. So, I thought I would ask here first if anyone was able to do it? Thank you.
    Hobbs likes this.
  2. Jun 5, 2020 at 12:27 PM
    YotalikesTacos
    YotalikesTacos Big Sexy Trail Limo
    Travis
    2017 Big Sexy Trail Limo TRD Offroad 4X4
    Add spacers and longer bolts to the back legs of the seat. I have the alpine sub under the passenger seat. If that doesn't work, in addition to the seat spacer you will need to flip a bar that is under the seat (at least on the passenger side).
  3. Jun 5, 2020 at 12:28 PM
    ExplorHer
    ExplorHer Question Authority
    Near Pittsburgh
    2016 4cyl, 5MT, 4x4, 2 seats, dents, & rust
    I have not done it, but I have unbolted my seat.
    Unbolting the seat is super simple, and it's pretty light too. I would suggest removing the rear bolts completely and loosening the front bolts. Then lift the rear of the seat, put a block of wood under one of the brackets for a spacer, slide your hs-8 under, remove the wood, and check for clearance.
  4. Jun 5, 2020 at 12:32 PM
    82nate
    82nate [OP] Member
    Nate
    2020 Tacoma
    I figured it out. I was so set on mounting it horizontally that I didn't even think about shoving it in their longways. I just assumed it was not long enough. Turns out, it works great.
    ExplorHer likes this.
  5. Jun 5, 2020 at 12:32 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    I recently installed a Kicker 8" Hideaway, but I removed the seat to do it. Didn't have to fight it this way. It takes about four minutes to pull the seat.
    Sometimes the shortcuts we take turn out to be long cuts.
    Pro Tip: install ground wire at front side of hump that the front of the seat bolts to. There is a 6mm threaded boss at this location.
    Good luck!
  6. Jun 5, 2020 at 1:24 PM
    jtc411
    jtc411 Active Member
    Justin
    2020 Tacoma TRD Sport 4x4
    can you take a pic? Also thoughts on sound?
