Kicker L7T and pre-made enclosures
Discussion in 'Audio & Video' started by JCTacoma330, Apr 3, 2020.
  1. Apr 3, 2020 at 4:59 PM
    JCTacoma330
    JCTacoma330 [OP] Well-Known Member
    Justin
    2019 Black Tacoma DCSB OR MT
    None
    Has anyone had any experience with the new Kicker L7T subwoofers yet in their Tacoma Double Cabs? For those that don't know, they look like this:
    https://www.crutchfield.com/p_20646LT122/Kicker-46L7T122.html
    Besides their pre-made enclosures that sound like they are suspect in fitting, I was thinking about taking something like this
    http://www.audioenhancers.com/vehiclespecific/tac140.php
    cutting the holes so they fit the square L7T's and installing behind the seats.
    I have the comprt 10 with passive radiator now behind the passenger seat in the bin (with some modifications) and it is great with kick drum, rock, and some bass heavy songs with an alpine 500 watt amp, but like anything else would like more output. I would also upgrade my amp if I went with something like I described above, but does anyone have any input?
    Rockoma5 likes this.
  2. Apr 3, 2020 at 5:36 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    The 8” fits, the 10” and 12” do not.
    I currently have the 12” version of the compRT loaded that you have. I have the bin fully removed, and also have the plastic seat backing removed. I got my hands on the 10” L7 and did a test fit and the seat would not lock back into place and the speaker surround was completely compressed into the back of the seat.
  3. Apr 3, 2020 at 6:07 PM
    JCTacoma330
    Justin
    None
    Thanks Destin, I was hoping you would comment. Its good to know the 10 and 12 options are off the table to hopefully save others the headache.
    What do you think of the idea of loading a prefab box like the AE I posted and putting the l7s in after cutting the proper size holes? Do you think roughly .7 cubes gross for the l7t10 or 12 would be enough for decent deep bass?
  4. Apr 3, 2020 at 6:27 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    I think if I had to pick an option, I would reach out to MrMarv and ask him if he could do a PORTED box for the 10 or 12. With a large sealed box, you may notice a slight increase in bass for the L7 10 vs your current setup. But I have heard the l7 10 in a custom ported box and it DESTROYS my 12” compRT with the same amount of power.
  5. Apr 3, 2020 at 6:29 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Or buy that box and chop it up and be a guinea pig :D
  6. Apr 7, 2020 at 3:23 PM
    Rockoma5
    Rockoma5 Well-Known Member
    St Louis
    2019 TRD Sport Lifted
  7. Apr 7, 2020 at 3:24 PM
    Rockoma5
    St Louis
  8. Apr 7, 2020 at 3:25 PM
    Rockoma5
    St Louis
  9. Apr 8, 2020 at 9:37 PM
    fake4x4
    fake4x4 Well-Known Member
    Los Angeles, California
    3rd Gen Tacoma TRD Off-Road DCSB
    Cool stuff
    How do you pop off the plastic on the back of the seat?
  10. Apr 9, 2020 at 4:30 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    If I remember correctly, pop off the corners on both bottom sides (where the main bolts are) and there should be 3 screws (one on each corner, one in the middle) and then the whole seat back slides down and pops off
    fake4x4[QUOTED] likes this.
  11. Apr 9, 2020 at 9:21 PM
    Doobfucious
    Doobfucious I get it. It ain't makin' me laugh but I get it.
    Doobie
    WNC -> Midwest
    2020 TRDOR DCSB 6MT
    Stock AF. My 68 Bronco and 2000 2.5RS get the mods.
    I have an L7 8" sitting in the garage at the moment, along with a mountain of other stuff including the new kicker key 500.1. The L7 8 does fit as Destin stated, I had to razor out the rib in the middle of the bin (non-jbl) but it fits decently. There is access to the hooks if that's something you want to keep, btw. You'll have to put a little something against the front edge of the storage bin, the speaker surround is right on it. I have a grill on the way so I won't be worried about woofer excursion. Anyway, for $250, I think it fits great.
    How it sounds? No idea, it's not in yet. The focals, two keys- 200.4 & 500.1, lc6i, sound deadening, full t-harness (radio to LR cubby where the rack is going and back) and power distribution box are a sizable task that I just started this afternoon.
    I set the pics to thumbnail, how do I make them not so damn huge? I'm not trying to steal the show, just show a pic!
  12. Apr 10, 2020 at 1:44 PM
    Rockoma5
    St Louis
    Awesome man....thinking about getting two of these. Keep us updated on this build and sound.
  13. Apr 12, 2020 at 5:23 PM
    stec06
    stec06 Well-Known Member
    How do you think this would fair with about 320 RMS?
  14. Apr 12, 2020 at 6:03 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    What sub?
  15. Apr 12, 2020 at 6:31 PM
    stec06
    The 8" L7T in the Kicker prefab box. I have a CX600.5 amp and the sub channel is rated at a smidge over 300 RMS. Wondering if this is a better option than the 8" Comp R I have in a .5 cu sealed box.
  16. Apr 12, 2020 at 6:52 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    I personally wouldn’t swap them out unless you just want to. Both sealed boxes, and both will be getting the same amount of power. I wouldn’t expect much (if any) difference
  17. Apr 12, 2020 at 7:26 PM
    JCTacoma330
    Justin
    None
    I mostly agree with Destin. However, you are getting more cone area, little higher sensitivity, and a bigger box that is probably optimized size for sealed. My guess is it’ll be a little noticeable, but for the couple hundred bucks... I’m not sure it’s be worth it.
    In some ways I’m kind of in the same boat, I’ve considered options that would probably net me a little more volume/frequency, but to really see a significant increase I’d have to drop more than I’d want to at the moment (like my original idea). Although with that stimulus money coming and all...
  18. Apr 13, 2020 at 12:45 AM
    JCTacoma330
    Justin
    None
    destin_meeks likes this.
  19. Apr 13, 2020 at 5:08 AM
    Rockoma5
    St Louis
    Wondering if you cut in the plastic shelving if you’re sub would be have more clearance room to backseat.
    Doobfucious[QUOTED] likes this.
  20. Apr 13, 2020 at 8:54 AM
    Doobfucious
    Doobie
    WNC -> Midwest
    2020 TRDOR DCSB 6MT
    It would and it wouldn't be bad to do but the grill should sort it all out. I'd rather not cut it, to do so would defeat having gone with the 8" preloaded box, I would have gone much bigger. I should be able to make and run the harnesses and finish the install tomorrow, ill post up whenever I get around to the sub and definitely when the grille finally shows up.
    Dude that seems pretty substantial, provided you're willing to cut the ISO-Fix brackets out. (I want mine, I'll still have the carseat for a couple more years.)
