Kicker speaker upgrade problem
Discussion in 'Audio & Video' started by 17Quicksilver, Jun 19, 2018.
  1. Jun 23, 2018 at 5:50 PM
    Deacon Blues
    Deacon Blues Well-Known Member
    Colorado
    2017 SR5
    That doesn't sound like clipping it sounds like a bad connection. Did it do the same thing sitting still?
    Not doing it at all with the stock speakers in?
    ManBeast and CoastieRon like this.
  2. Jun 23, 2018 at 6:09 PM
    CoastieRon
    CoastieRon Hammocking Fool
    Ron
    Nashua
    Lil' Silver
    Too much.
    Agreed. Clipping and cutting are two different things...
    ManBeast likes this.
  3. Jun 24, 2018 at 8:13 AM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    My 1998 yukon has a bad pin in the harness that the adapter harness plugs into, my front right will cut out over bumps or just not be playing and i have to wiggle it in dash for it to play. The pin its self is wobbly in the hole within the harness. Could maybe be something like that.
    Is it still happening with oem speakers in?
  4. Jun 24, 2018 at 12:17 PM
    17Quicksilver
    17Quicksilver [OP] Active Member
    Brent
    2017 White Tacoma TRD Sport DCSB
    Yeah I tried everything including putting the factory speakers back in. Sitting still, driving, doesn't matter.
  5. Jun 24, 2018 at 12:19 PM
    FourBanger99
    FourBanger99 4 Banger Taco
    Bayne
    Birmingham
    2012 Black Tacoma 2.7 AC SR5 4x4
    Full OME Suspension CB Diff Breather Duratracs
    Wiring. Check that nothing is being shorted and connections are secure
  6. Jun 25, 2018 at 5:29 AM
    17Quicksilver
    Brent
    Would a LOC lose cause it? I have had that in over a year. I have reinstalled the factory speakers too.
  7. Jun 25, 2018 at 7:29 AM
    badhabit2break
    badhabit2break Well-Known Member
    Stephen
    Houston, TX
    2018 Red Tacoma TRD Off-Road
    Stock
    You have to look at it from the Service side. You have aftermarket equipment (sub and amp) and are having radio issues. Dealership will almost always point the finger at the aftermarket equipment as it is the easiest thing to do.
    I would disconnect the sub and amp and test your OEM speakers again. This way your eliminating your aftermarket equipment. If it works fine, then put in your aftermarket door speakers and see if everything is still good.
    Did you use an Line Output Converter (LOC) to get RCA connections for your amp or did you use a high level connection on the amp?
    I am going to ask a stupid question here....did you get the correct ohm speaker to replace the OEM speakers? I know alot of companies are making more than 4ohm speakers to accommodate the OEM stereo upgrade options out there.
  8. Jun 25, 2018 at 7:44 AM
    ManBeast
    Zach
    Orange Park FL
    Loc might be doing it
    do all speakers cut out or just the one tapped.
    Check there are no loose wires anywhere or fuses. Make sure everything on the back of the radio is tight.
    If you have a freind with a tacoma swap in there entune and see if its isolated. Put yours in theres and see if it cuts out in theres.. if it does i would say its the radio
  9. Jun 25, 2018 at 7:46 AM
    17Quicksilver
    Brent
    All speakers cut out.
  10. Jun 25, 2018 at 7:53 AM
    ManBeast
    Zach
    Orange Park FL
    Yea id see if anyone you know can swap units for testing purposes
  11. Aug 20, 2018 at 11:23 AM
    krshome
    krshome The sale of the Porsche bought my Taco
    Kurt
    Virginia
    TRD Off Road DCLB
    stereo upgrade, LEER Cap
    You ever get this straightened out? I would like to know what caused it, Im doing the same upgrades now.
  12. Dec 25, 2018 at 2:30 AM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
