Kicker ZX 400.1 Subwoofer - $150 (Raleig
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by stewmasta, Feb 27, 2012.
  1. Feb 27, 2012 at 2:14 AM
    stewmasta
    stewmasta [OP] Member
    Ian
    Hometown:Boone,NC; Current Resident of Raleigh, NC
    2005 Tacoma TRD
    17 inch KMC XD black rims wrapped in BFG's All-terrains, Flowmaster Dual Exhaust, 15% tint all the way around, Xm Radio, Spyder Black Headlights, UWS toolbox
    If you love bass, you'll love Kicker's ZX mono amplifiers. These high-end amps set the standard for powerful sound, with a distinctive look that'll make your installation stand apart from the crowd.
    The ZX400.1 mono subwoofer amp will drive your subs with up to 400 watts of power. No inflated "peak power" ratings here -- you can trust that this amp's CEA-2006 compliant rating reflects a true measure of its capabilities. The efficient Class D design draws less current and produces less heat than traditional amps, for reliable operation that won't strain your car's electrical system.
    The built-in variable low-pass filter adjusts the amp's output to get the most out of your subwoofer, while a subsonic filter removes the extreme low bass that hampers system efficiency. Use the bass boost control to dial in the exact amount of low-end bump you're looking for, then use the included wired bass level remote control to pump up the volume right from the driver's seat.
    Highlights:
    mono subwoofer amplifier
    200 watts RMS x 1 at 4 ohms (400 watts x 1 at 2 ohms)
    variable low-pass filter (50-200 Hz at 24 dB per octave)
    variable bass boost (0-18 dB at 40 Hz)
    subsonic filter (12 dB at 25 Hz)
    wired remote bass level control
    Class D design
    CEA-2006 compliant
    speaker-level inputs
    preamp inputs and outputs
    fuse rating: 40A x 1
    4-gauge power and ground leads recommended -- wiring and hardware not included with amplifier
    10-1/4"W x 2-5/16"H x 9-5/8"D
