KickerCS Upgrade with Kicker Key amp Install Assistance
Discussion in 'Audio & Video' started by siKjiTz, Sep 18, 2018.
  1. Oct 21, 2019 at 8:10 PM
    #221
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Damn. I knew that’s what I should do but has hopping to hear different. Thanks man.
  2. Oct 28, 2019 at 11:32 PM
    #222
    TacoMex85
    TacoMex85 Well-Known Member
    Mark
    2017DCLB
    Anyone ever installed the key by splicing I to this harness? I used it to install a amp and it made the quick and easy. 287B3906-1BE6-423C-8CA7-C2048DD93161.jpg
  3. Oct 29, 2019 at 4:27 AM
    #223
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    That harness only contains the front speaker channels, and is a pass-through harness meaning the speaker wires would have to be cut apart, not spliced in to. Good thought though
    TacoMex85[QUOTED] likes this.
  4. Oct 29, 2019 at 6:29 AM
    #224
    TacoMex85
    Mark
    2017DCLB
    Could a T harness be made using this or is it possible to make a T harness that would also send signal to the sub amp?
  5. Oct 29, 2019 at 8:03 AM
    #225
    destin_meeks
    Destin
    Tuscaloosa, AL
    it is absolutely possible to make one that sends signal to the sub. If you already have this particular harness, you can utilize the LOC from it. If you do not already have this, I wouldn't purchase it.
    you wouldnt be able to make a t-harness with this product because no rear channels. It's also just really short for the work that needs to be done.
  6. Nov 23, 2019 at 12:55 PM
    #226
    wolfman00
    wolfman00 Well-Known Member
    matt
    Gambrills/Crofton MD
    '16 dclb
    sortof stock. 6112/5160, pro wheels and a tune.
    not to revive a dead thread- i got a kicker key and built my harness exactly like above. i went through the whole process and did the auto set up, got the happy tones and the end, all is good. but- when i turn the truck off, the optimized tune is gone. i have to plug the mic in and give it a tap to switch it over. it will not hold the tune. any ideas?
  7. Nov 23, 2019 at 1:07 PM
    #227
    destin_meeks
    Destin
    Tuscaloosa, AL
    Did you do the Key’s red power wire to the red Metra wire, or the yellow
  8. Nov 23, 2019 at 1:49 PM
    #228
    wolfman00
    matt
    '16 dclb
    yes, i did. so i think i was getting crossed up with the before/after sounds after the auto tune. seems kinda muddy?
  9. Nov 23, 2019 at 1:56 PM
    #229
    destin_meeks
    Destin
    Tuscaloosa, AL
    Wait, you hooked the key red to which Metra wire
  10. Nov 23, 2019 at 2:02 PM
    #230
    wolfman00
    matt
    '16 dclb
    it’s all behind my dash now. i don’t remember. but it built it exactly how the above harnesses are made
  11. Nov 23, 2019 at 2:30 PM
    #231
    wolfman00
    matt
    '16 dclb
    red to yellows
  12. Nov 23, 2019 at 3:05 PM
    #232
    destin_meeks
    Destin
    Tuscaloosa, AL
    if the amp is resetting every time the radio turns off, my first guess is that you did the key's power wire to the red accessory wire and not the yellow constant power wire
  13. Nov 23, 2019 at 3:52 PM
    #233
    wolfman00
    matt
    '16 dclb
    well, i’m an idiot. too many Carbon monoxide fumes i guess. it was working fine the whole time.
    so since i’m using the oem speaker configuration, i turn bi-amp off correct?
  14. Dec 3, 2019 at 11:00 AM
    #234
    roth_nj
    roth_nj Well-Known Member
    2017 DCLB trd off-road bbp
    i recently upgraded to the kicker speakers in all 4 doors plus the subaru tweeters and am thinking of adding in the key.....
    this thread has some great info in it for how to hook that up...
    anyone add the hideaway sub too?
  15. Dec 6, 2019 at 3:45 PM
    #235
    tpp4
    tpp4 Well-Known Member
    Memphis
    2018 DCSB SR
    @destin_meeks
    So I just wanted to get clarification before I plugged it all up. I'm 99% sure that I got it wired correctly, even though I had to rewire it probably 5 times because I wasn't paying attention.
    Do I have the correct understanding that the jumper pin from the large female connector (aka 70-1761) is cut and depinned from its slot next to the orange/white wire?
    The pin and rest of the blue wire is then inserted into the small female connector (aka 70-1761) beside the green/black wire. The unused tail remaining in the jumper pin is just heatshrunk alone so it doesn't short.
    Am I also correct that in the instance of powering the amp from the factory HU wiring that both yellow metra harness wires and both red amp wires are connected together, making a bundle of four? Additionally, all four black wires from the respective harnesses are connected together? And all four blue wires (one of which has a white stripe) are all connected together?
    That said, I'm half way through a full wiring schematic for the T harness, provided that mine is correct. I wanted to make a no-nonsense guide since there are several pictures of harnesses with errors.
    Yann likes this.
  16. Dec 6, 2019 at 4:00 PM
    #236
    destin_meeks
    Destin
    Tuscaloosa, AL
    All looks great to me!
    And yes, Kicker red to Metra yellow.
    cant wait for your write up! That will help tons of people take on this project! I wanted to make one when I did @ArmandHammer83 install but I can’t take pictures due to our Client Data Privacy policy.
  17. Dec 7, 2019 at 8:18 AM
    #237
    CowtownKTM
    CowtownKTM New Member
    2019 TRD Offroad
    Hi, I'm new to the forum but have been lurking this very helpful thread as I'm making a t-harness for my DSP amp install into a 2019 DCSB without JBL.
    Had a question I'm hoping someone can answer - I want to use a remote to turn on the amp, but I'm not sure why I need to use the blue wire on the female 10 hole metra socket. Can't I just use the blue wires on the male side and de-pin the blue wires (the single wire and the loop) on the female side? Or does the female side need to connect for some reason (it looks like people are removing the blue looped wire from the female side and salvaging that pin for the dimmer in the six hole plug, but leaving the other blue wire in the female plug intact, and I'm not sure why it's needed to leave one of the blue wires on the female side).
    Thanks for any help.
  18. Dec 7, 2019 at 8:26 AM
    #238
    CLVol1255
    CLVol1255 Well-Known Member
    Tennessee
    2017 TRD Sport DCSB
    Bilstein 8112/8100 ICON RXT Stage 2 JBA UCAs Archive Garage HH w Shackles Archive Garage U Bolt Flip kit Nitto Ridge Grapplers 255/80/R17 TRD Front Skid and RCI Transmission Skid Kenwood DMX 1057XR Head Unit Focal Utopia WM 3 way plus WM10 Sub Mosconi 5/30 and Genesis Dual Mono Amp
    A635AFBC-41EC-48A9-AFF9-9D20BEB5A47F.jpg FA63D689-D33E-4E4D-B52D-1444DE2A6726.jpg AE66E611-0050-4171-9163-8D6166D60AD7.jpg Do i need the T harness for a 125w powered subwoofer install. I’ve got the infinity basslink sm which is very similar to the jbl basspro and kicker hideaway in every way is my understanding. I’ve bought the line converter and the Toyota female Metra harness so far. These are pics of the back of the sub and the wire harness that came with it if this helps. Thanks I appreciate the input if you can help it’d be greatly appreciated. I just want to be sure I’ve got everything I need before I begin tackling this task and I’m very anxious to get it done once and for all @destin_meeks or anybody else with experience and knowledge of this. This is my first time to ever install a subwoofer or amp and I’m hooking up to factory head unit non jbl but it’s the 7” touchscreen for 3rd gen and I’ve upgraded door speakers and tweeters thus far. I’m looking for the low end bass fill mainly with this compact powered sub. This is everything I’ve bought for hookup so far. I’ve also got some 16 gauge oxygen free speaker wire
  19. Dec 7, 2019 at 9:16 AM
    #239
    destin_meeks
    Destin
    Tuscaloosa, AL
    Will reply shortly once I get to the computer.
    CLVol1255[QUOTED] likes this.
  20. Dec 7, 2019 at 9:22 AM
    #240
    destin_meeks
    Destin
    Tuscaloosa, AL
    check your factory wiring and see if anything is pinned where those blue wires are. I've seen some trucks with and some trucks without wires in those spots. If something is there, just make sure its got a blue wire to connect to. If there is nothing there, by all means remove them :thumbsup:
