KickerCS Upgrade with Kicker Key amp Install Assistance
Discussion in 'Audio & Video' started by siKjiTz, Sep 18, 2018.
  1. Aug 10, 2019 at 9:37 AM
    #161
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    I always like to go separate components if I can. The popularity of the 3-ways is because those members are typically doing the plug-and-play subaru tweeters in the dash.
    I personally don't much care for the Kicker CS line. Titanium tweeters are way too harsh on my ears, especially once you add power. I run the Kicker KS line and am very pleased. I also run the JBL GX line in my wife's car and am very pleased for the price.
    Getting components installed in our trucks takes a little more work, but is definitely worth it to me. There is some cutting/splicing of the tweeter harness, or purchasing the tweeter harness from *********. I run these harnesses and they work fine, just pricey. I didn't want to cut the wiring in my 2 month old truck at the time. Their install videos on youtube are helpful to see if it's work you want to tackle.
  2. Aug 10, 2019 at 11:02 AM
    #162
    MaHoTex
    MaHoTex Well-Known Member
    2019 Silver Tacoma TRD Sport
    Thanks again. I am not sure what the **** mask is for. Anyway, what about using a Kicker Key for the front and rear doors, and then connect the tweeter directly to the Front L/R pair coming out of the Entune deck w/o an amplifier? I just can't see a need to amplify the tweeters.
    If I were to go Kicker KS line and a separate 8" powered sub (already got the house named unit from Crutchfield), what speaker pair for components would you recommend for the front and rear pairs?
  3. Aug 10, 2019 at 11:25 AM
    #163
    destin_meeks
    Destin
    Tuscaloosa, AL
    Oh, not sure what happened there? T a c o T u n e s
    If you're doing a component set, it will come with the woofer, tweeter, and a crossover. That crossover is very important because it keeps bass signals from being sent to the tweeter. The factory tweeters have those built in, so if you were to just wire up a tweeter straight to the head unit, it would be fried pretty quick, and sound terrible the whole time.
    Typically if I'm adding an amp, I dont like to leave anything on the radio power. Plus, aftermarket tweeters can handle (and need) more power than the radio can put out. I would just do it right the first time :thumbsup:
  4. Aug 10, 2019 at 11:44 AM
    #164
    MaHoTex
    Fair enough. So for the Front Doors it seems simple: Get a component set that will cover the tweeter and woofer (mid) for the door. The rear aren't you stuck since there is not a tweeter in the rear? What about get a component set for the rear and don't use the tweeter; trash it and just use the lowpass filter for the rear Woofer or leave the rear woofer as full range?
  5. Aug 10, 2019 at 11:49 AM
    #165
    destin_meeks
    Destin
    Tuscaloosa, AL
    You'll pay more for the component set than a coaxial set for the rears. I'd just go coaxial (2way) and call it a day. Pretty much every component set available will have a matching coaxial set
  6. Aug 10, 2019 at 11:52 AM
    #166
    MaHoTex
    Ok, still with Kicker KS I'd assume. Seems simple to install the components with tweeter harness you pointed me to. I also have a new truck and don't want to cut my factory harnesses.
  7. Aug 10, 2019 at 11:53 AM
    #167
    destin_meeks
    Destin
    Tuscaloosa, AL
    Yep, KS as well as nearly ell other brands and price levels. Those just happen to be what I run
  8. Aug 10, 2019 at 12:39 PM
    #168
    MaHoTex
    It seems all of the component sets I find says the tweeter has to be surface mounted. Certainly that can't be right.
  9. Aug 10, 2019 at 12:56 PM
    #169
    destin_meeks
    Destin
    Tuscaloosa, AL
    Tweeters dont "have" to be mounted any specific way.
  10. Aug 17, 2019 at 6:55 AM
    #170
    Slickestwilly
    Slickestwilly Well-Known Member
    Will
    NH
    2016 TRDORDCSBMTBBQ
    I think I got a bum amp. The rear channels are not getting nearly as much power and sounds kinda crappy. Will the key still pass signal through blown channels? I switched the fader to off and the signal was cut and then came back when it switched to on. I double checked my harness and all looks fine there.
  11. Aug 17, 2019 at 11:21 AM
    #171
    destin_meeks
    Destin
    Tuscaloosa, AL
    Can you go into a bit more detail?
  12. Aug 17, 2019 at 1:59 PM
    #172
    Slickestwilly
    Will
    NH
    2016 TRDORDCSBMTBBQ
    Hahah yup. I installed the key in my double cab using the Metra harnesses. I already have the CS and tweeter upgrade. The front channel sounds loud and clear, but the rear still sounds like it did stock.
    Not sure what to do for troubleshooting but when I switched the fader switch to off on the key all the sound to the rears cut off as it should.
    It’s like the key is just passing signal from the head unit through without amplifying it.
    Thank you!!!
  13. Aug 17, 2019 at 2:52 PM
    #173
    MaHoTex
    I have the kicker key amp on order and I am considering 2 sets of the 44KSS6704 speakers. For the rear door, couldn't I just use the crossover and Woofer and just not use the tweeter? Would that mess up the impedance?
    plasticsnaks likes this.
  14. Aug 17, 2019 at 2:55 PM
    #174
    MaHoTex
    Have you tried to increase the gain on the rear channel? It should be able to increase the gain. I am not sure how much gain can be applied, but the silkscreen says 0-11; perhaps 10dB
    Also, did you follow the gain matching instructions in the manual?
  15. Aug 17, 2019 at 3:25 PM
    #175
    Slickestwilly
    Will
    NH
    2016 TRDORDCSBMTBBQ
    Hahah I’m an idiot. I thought the gain was left and right channels. Thanks!!!
  16. Aug 17, 2019 at 3:46 PM
    #176
    destin_meeks
    Destin
    Tuscaloosa, AL
    So you got it cleared up? The output from the factory radio is much lower on the rear channels, so the gain on the amp for the rear channels needs to be higher to make up for that lower input signal
  17. Aug 17, 2019 at 5:22 PM
    #177
    Slickestwilly
    Will
    NH
    2016 TRDORDCSBMTBBQ
    Yea the low output to the rears and all the sound coming from the dash tweeters was messing with me. That and I thought the gain was L/R so I had it same between the two. Thanks again for all the info in this thread. I managed to learn a few things including how to solder.
    destin_meeks[QUOTED] likes this.
  18. Aug 17, 2019 at 8:02 PM
    #178
    destin_meeks
    Destin
    Tuscaloosa, AL
    Great skill to know! Biggest tip I can give is be sure not to use too much solder. That’s the mistake I see most. People put in so much that you can’t even see the wire strands anymore
  19. Aug 17, 2019 at 8:37 PM
    #179
    MaHoTex
    Destin,
    I posted a question above that I was hoping you could answer:
    "I have the kicker key amp on order and I am considering 2 sets of the 44KSS6704 speakers. For the rear door, couldn't I just use the crossover and Woofer and just not use the tweeter? Would that mess up the impedance?"
    Also, about the crossover dB settings for the tweeters, what is the ideal setting on that? I would assume it's best to leave it at 0dB.
  20. Aug 18, 2019 at 6:00 AM
    #180
    destin_meeks
    Destin
    Tuscaloosa, AL
    The KS can actually be mounted in a coax configuration which would be handy for your scenario
    As for the dB setting for the tweeters, that’s a personal taste. I believe mine are set to 0
    There aren’t really “ideal” setting for audio equipment. Everyone’s ears are different so do what sounds best to you. I set them all at 0 in my shop and no client has come back yet asking to change them
