Kill Switch Installation Questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GrandiOdyssey, Jul 24, 2020.
  1. Mar 14, 2024 at 12:09 PM
    #41
    Seareef228
    Seareef228 Well-Known Member
    And method would that be ?
    Starter relay?
  2. Mar 14, 2024 at 12:21 PM
    #42
    Jakerou
    Jakerou Well-Known Member
    Jake
    MA
    2023 Celestial Silver SR5 DCLB
    My parents had a 1999 Chrysler Concorde they bought new. The UP mirror switch was wired in so that you had the press and hold it in order for the starter to crank. I am pretty certain that modification was done as a part of Lo-Jack installation.
    The beauty of this is that you are using an existing switch, nothing for a theif to find. When the mirror adjust selector was in the middle position, pressing the UP mirror switch wouldn’t actually move any mirrors.
  3. Mar 14, 2024 at 6:17 PM
    #43
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Brilliant.
  4. Mar 14, 2024 at 6:49 PM
    #44
    Seareef228
    My dad had an old 64 impala when I was a kid. He had a kill switch wired underneath the format. So when he got in, he just pressed on it with his foot ..
  5. Mar 26, 2024 at 1:09 PM
    #45
    Qbrute
    Qbrute Well-Known Member
    Ontario, Canada
    2023 Black Tacoma OR SB
    Would something like this work?
    I am mostly concerned about theft when I park my taco long term and away from home; airport parking, hotel, boat launch...
    I'm thinking if i have a "The club" on the wheel (backwards), a tile in the flooring, the fob turned off and the battery switched off, it would be too much hassle for most instances. i can't stop someone from towing it.
  6. May 10, 2024 at 1:05 PM
    #46
    Max8
    Max8 Thinking Outside The Box until they close the lid
    23 SR5 DCLB stock
    2012 ARE DCU contractor cap, Transmission aftercooler kit (Iconic Fabrication & Hayden 698), Bed Stiffeners (Kwikfab LLC), Firestone airbag leaf springs, wye connector and pressure gauge, Tailgate security mod (mfgr. by Christian06 on TW), OEM mud flaps, OEM tailgate electronic lock, Tow-Pro Elite Electric Brake Controller, Anytime Backup Camera hardwired 42 ft to camper, RCI Alum. Skid plates & cat covers, 2WD LO mod (BB Tuning), Fumoto oil drain, ECT Always-On Mod (hardness by Funman1steve), 6awg DC DC tow charger wiring, inline 60 amp breakers & battery terminals, Kill switch, KJTO driver side grab handle, Hood hold open gas struts, Scangauge III, Seat Covers (Seat Covers Unlimited... wearing poorly),
  7. Mar 5, 2025 at 8:07 PM
    #47
    OrbitalD
    OrbitalD New Member
    David
    Hi, can I ask what relay spot you installed this in? I have a 2020 TRD Pro and wondering if its the same spot. Thanks!
  8. Mar 5, 2025 at 9:20 PM
    #48
    Mr. Excitement
    Mr. Excitement Well-Known Member
    J
    Custom floormats, fuzzy dice
    There’s been a bunch of tacomas stolen this past week. I guess they are into swiping overland gear. Curios what product you got and if you had any installation notes. Their website seems pretty bare bones. Any advice would be great. Actually just found it. Thanks.
  9. Mar 6, 2025 at 8:28 AM
    #49
    Max8
    23 SR5 DCLB stock
    https://www.mobilistics.com/nostart...relay-w-remote-starter-fuel-pump-immobilizer/
    You just swap out your starter or pump relay under the hood. Could not be easier. Look up where yours is for your model, I am no expert.
    A spare keyfob well wrapped from EMF and well hidden, and retaining the original relay, are both good ideas.
    While it is a mild nuisance to whip out my belt keychain in the winter and press the button as I approach the truck from side or front (not behind..) it's well worth the peace of mind.
    I received helpful personal email responses to my queries from the vendor, and have been very impressed with his service and the product.
    Both are rare in my aftermarket dealings.
    Bear in mind, the more publicity kill switches receive the less useful they may prove.
  10. Mar 6, 2025 at 9:59 AM
    #50
    OrbitalD
    OrbitalD New Member
    David
    I contacted a local alarm company and they quoted $1500 for an iGLA immobilizer. Seems pretty sophisticated but very expensive. https://iglaglobal.com/
  11. Mar 11, 2025 at 12:29 PM
    #51
    Mr. Excitement
    J
    Is you’re automatic or manual? Installed mine in the ignition relay, but just read for manuals to use the EFI. Probably switch it around. Mine only started when the button was simultaneously pressed with the ignition. I’m guessing it has to do with the clutch sensor.
  12. Mar 11, 2025 at 5:39 PM
    #52
    RushT
    North Texas
    A nice solution for this challenge would be to use an inline switch controlled by Bluetooth. Switch remembers its state. Leave it normally closed, then switch it to open with your phone when parking somewhere sketch.
    I suppose if that’s all the time, it might become tedious. You’d also want a manual bypass I suppose.
  13. Mar 16, 2025 at 4:32 PM
    #53
    Mr. Excitement
    J
    Just a follow up on Mobilistics imobilizer. On the 2019 MT Tacoma the ignition relay would only work with the button simultaneously pressed while turning the ignition. The EFI relay caused it to throw a code P2610. Switched it back to the ignition and it seems like it fried my trucks keyless entry.
    10/10 would not recommend.
    snickers and 02Duck like this.
  14. Mar 18, 2025 at 7:22 AM
    #54
    Mr. Excitement
    J
    So a quick follow. Mobilistics is going to take back my imobilizer and today while getting ready to call the dealership, my fob started working again. Totally strange but I’ll take it.
