Kill switch placement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bmanjr, Jul 3, 2025.
  1. Jul 3, 2025 at 12:46 PM
    Bmanjr
    Bmanjr [OP] Member
    2023 Tacoma
    Where would the best place to mount a kill switch for maximum concealment in a gen 3 interior?
  2. Jul 3, 2025 at 2:04 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Get creative. A lot of users here are super secretive about their kill switches. I always thought an unused OEM switch would be the best. Wireless charging button or auto hi beams for example
    yoeltimeisup likes this.
  3. Jul 3, 2025 at 3:37 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Careful with those switches, they may not be able to handle any current at all. Many of the switches are only delivering a signal voltage level or signal ground to an ECU, not turning anything on with power. Perhaps not even good enough to drive a relay. Replacing those switches with something a bit more capable is a good idea.
    EDIT: See post #19.
    musicisevil[QUOTED] likes this.
  4. Jul 3, 2025 at 4:13 PM
    musicisevil
    Alaska
    2019 TRD Sport
    Great to know! I would have figured they’d work with a relay but I’m an electrical idiot so this is extremely helpful.
    Thanks so much!
    Toycoma2021[QUOTED] likes this.
  5. Jul 3, 2025 at 5:05 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    my parents old suburban, my dad mounted the kill switch in part of the dash/gauge trim that was flexible. just had to press the trim to close the switch. it was entirely invisible.
    Lugnutz and musicisevil like this.
  6. Jul 3, 2025 at 9:23 PM
    nds0000
    nds0000 Well-Known Member
    I mounted it in the middle console vault. No safer place for it, I guess.
  7. Jul 3, 2025 at 9:33 PM
    Toycoma2021
    Well, we don't "know" anything, it's only a suspicion I have as everything today is made only to do the job as intended - nothing more.
    musicisevil[QUOTED] and TACOTU3 like this.
  8. Jul 3, 2025 at 9:37 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    Mount it in the tailpipe, no one will look in there.
  9. Jul 4, 2025 at 9:34 AM
    InfernoTacoCO
    InfernoTacoCO Well-Known Member
    Hannah
    Denver, CO
    2017 Inferno Orange Toyota Tacoma TRD Offroad
    Westcott Design 0° Sliders, Falken Wildpeak AT3’s, OTT Tune, Interior/Exterior LED lighting, Raptor Lights, WeBoost 4G-M Signal Boost Amp, Trail Grid Pro Front/Rear Anytime Camera, OEM Tailgate Actuator & Wiring, 20% Ceramic Tint.
    All a kill switch does is interrupt the power.
    It's placed inline between a device and a source of power.
  10. Jul 4, 2025 at 9:44 AM
    musicisevil
    Alaska
    2019 TRD Sport
    Again I’m no electrician magician, but when the switch is open closed, isn’t the full current of whatever you are interrupting flowing through it?
  11. Jul 4, 2025 at 9:48 AM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    No
    If the switch is open then current cannot travel through the switch. Close the switch and the current will flow.
  12. Jul 4, 2025 at 9:51 AM
    TheWildMan
    TheWildMan Well-Known Member
    3rd Gen 23 Tacoma OR
    Scrubbed some tires, and knocked a dent out.
    Absolutely
    You know what he meant though!
    musicisevil likes this.
  13. Jul 4, 2025 at 5:30 PM
    Toycoma2021
    Correct. My comment(s) is on just how much power a switch can handle.
    A solenoid or contactor may be able to handle 100s of Amps while a keyboard switch the type I am typing on on my laptop keyboard may only be able to handle milliamps (0.001 amps). The point being is that the switch needs to be able to handle whatever current it interrupts.
  14. Jul 4, 2025 at 6:48 PM
    soundman98
    NW Indiana
    typically, the switch will control a relay, so the switch handles low power, with the relay carrying the larger burden of the load.
  15. Jul 4, 2025 at 8:17 PM
    nds0000
    Lets start here: the 41.22 is delivered with a switch and deemed safe. The question here is if the switch can be exchanged with a different one? My uneducated take: yes, as you are just replacing one switch with another. The current should be so low that the switch can handle it safely. Just compare the switches and make sure the new switch meets the 41.22 switch specs in terms of current permissible.
  16. Jul 5, 2025 at 5:17 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I let a homeless man sleep in my truck every night.... It's like a free security guard!
  17. Jul 5, 2025 at 3:47 PM
    Phlogiston
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    That's genius!
    Tocamo[QUOTED] and musicisevil like this.
  18. Jul 5, 2025 at 7:32 PM
    soundman98
    NW Indiana
    the convenience stores in really rough chicago or gary neighborhoods will usually hire the local homeless guy to stock shelves. it works as cheap shop help, and also prevents them from getting robbed as much because the neighborhood usually respects the homeless guy more than the shop owner.
  19. Jul 5, 2025 at 9:45 PM
    Toycoma2021
    To get this thread back on track, I took apart my "Auto Hi Beam" switch to investigate its capabilities as @musicisevil suggested its possible use. Found the contacts to be ample for energizing the coil of a relay. They had silver coated contacts, I suspect the silver is for longevity in the automobile environment for corrosion, not for conductivity, although silver is great for that too. If I find my "Wireless Charging" switch I will investigate it as well.
    EDIT: Found the Wireless Charging switch and it is likewise as capable as the Auto Hi Beam switch.
  20. Jul 5, 2025 at 9:57 PM
    musicisevil
    Alaska
    2019 TRD Sport
    Stoked! Added to the list of things I want to do and will probably never get around to because I hate electrical lol
