Killer chiller on 1grfe supercharged
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bfz777, Apr 25, 2021.
  1. Apr 25, 2021 at 12:36 AM
    Bfz777
    Bfz777 [OP] Active Member
    Alistair
    Melbourne
    2009 hilux trd
    Haltech elite 2000, Bosch 1100cc injectors, turbo smart regulator, ceramic coated headers, 2.5 catless free flowing exhaust, rebuild engine kelford cam , kelford valve springs 460ls wilbro pump , rebuild auto with stage 2 valve body, gauges boost afr , 2.5 lift kit with over sized upper arms, trd cai.
    Hi all
    Has anyone installed one of the chiller units that connects to ac to run lower temps through the heat exchange?
  2. Apr 25, 2021 at 12:41 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Pointless as it requires to run the AC to reap the benefits. Running the AC while you are attempting to get more juice out of the truck also robs you of some power as the AC system requires horsepower to run.
    Also, there currently is no killer chiller offerings which directly bolt up to the 1GR motor, only Tundra 5.7.
    You are better off with Meth/ water injection.
    SUMOTNK and crashnburn80 like this.
  3. Apr 25, 2021 at 12:45 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    12TRDTacoma likes this.
