Killer Front End Knock? Help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Scoobarooo, Aug 16, 2015.
  1. Aug 16, 2015 at 8:56 PM
    Scoobarooo
    Scoobarooo [OP] Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    I have a knock that seems to be comi from the front right wheel well or somewhere around there. It goes with the speed of the truck. If you go slow it knocks slower, if you go fast it knocks faster. It stops at about 30MPH. I've taken my taco to the Toyota dealer and they can't seem to find anything BUT I did go for a ride along with the tech and he confirmed hearing the noise as well. Does anyone have any ideas on what's making this knock?
    If there's any other information that could help you guys get a better understanding let me know, I'm glad to answer all questions.
    -Casey
  2. Aug 17, 2015 at 7:37 AM
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    Nobody?
  3. Aug 17, 2015 at 7:43 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Check the heat shield mounted to the floor of the truck above the cat is secure.
  4. Aug 17, 2015 at 7:53 AM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    It sounds suspension related. It could be many things. Take the front wheel off and have a look. Take the shock and spring assembly off and move things around. If you don't have the tools or the time, take it to another shop to get another opinion. Sounds like the dealership you went to was lazy.
  5. Aug 17, 2015 at 7:56 AM
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    I dealt with the heat shield months ago. So it's not that.
    That's a possibility for sure, I had one of the guys at the Nissan dealership I work at put 5100 adjustables in the front. Maybe it was his fault?
  6. Aug 17, 2015 at 8:01 AM
    CD20H
    Ben
    North Texas
    It could be as simple as a shock mount bolt that came loose.
  7. Aug 17, 2015 at 8:02 AM
    BenJammn5
    BenJammn5 RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    How many miles on the truck? Any alignment issues? A knock could be worn LCA bushings, sway bar bushings, ball joints (look for tears in boots), tie rods, rack-n-pinion, UCA bushings.
    Park truck. Jack it up, wiggle the rim left-right, up-down, look for lateral and hop play.
  8. Aug 17, 2015 at 8:05 AM
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    122K Miles. Toyota did a recall on my ball joints a year ago, so I wouldn't think it could be that. When I get he chance though I'll put it on the lift.
