Killing carrier bearings
Discussion in '1st Gen. Tacomas (1995-2004)' started by BayStateTaco, Mar 21, 2014.
  1. Mar 21, 2014 at 7:20 AM
    BayStateTaco
    BayStateTaco [OP] TOYOTA<><>JEEP<><>TOYOTA
    Ocean State
    360 MOPAR, DT Headers, 300 wet, 4:56 spooled rear D44A, B&M line-Lok, Infinti Kappa speakers (10), Borla XR1, Purple Cam, Built upper
    My truck keeps killing center support bearings and I can not find the cause. Toyota doesn't know and it's not like they are cheap. I never had this issue until after I was lifted.
    The lift I had has 5100 @ ZERO with allpro standard leafs. 2 OEM units went bad from July-September 2013. Removed my lift and installed all OEM shocks, struts, leaf packs and had an alignment. Truck has no vibes and drives fine but every 1000-1500 miles a carrier bearing is COOKED. Since November 2013 I have replaced 4 bearings and the entire drive shaft which snapped in half at the carrier bearing.
    Why do they keep going bad? I replaced the entire drive shaft with one out of a 1997 and that one went bad today...What is going on?
    Recent work
    Solid Engine and Transmission mounts
    drive shaft
    rear end straight
    drive shaft balanced
  2. Mar 21, 2014 at 8:39 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    All I can think of, is over-lubing the drive shaft at the "spline zerk" near the rear-most u-joint.
  3. Mar 21, 2014 at 5:35 PM
    gearcruncher
    Canadain bumper technician
    Is your driveshaft able to plunge or slip in and out with changes to the suspension ?
    Sounds like forces are being applied to the carrier bearing with suspension travel .
    There may be room for the slip and stub to move while the truck is relaxed but have you accounted for weight in the box and suspension travel ?
    If i had to guess , the slip and stub doesnt have enough travel
    Have you cancelled your drive line angles ?
  4. Mar 21, 2014 at 5:41 PM
    Vann
    Vann Well-Known Member
    Garth
    Weisenburg, PA
    '04 x-cab 4x4, 2.7 5sp. "The Black Pearl"
    stock
