Kimbo Camper BS and Mods
Discussion in 'Tonneau Covers, Caps and Shells' started by Voltron4x4, Feb 5, 2020.
  1. May 19, 2023 at 8:35 AM
    #2021
    TaKimbo
    TaKimbo Active Member
    Have been obsessively watching the 4th gen thread, and now that it's finally revealed, I'm kind of leaning towards snagging one of the last 3rd gen ACs... Lots of cool tech on the new one, but the new extended cab not having doors for the pooch is a let down. How many people are running the Kimbo on a 5ft bed out of interest?
  2. May 19, 2023 at 8:40 AM
    #2022
    ENORD
    ENORD Member
    E
    2023 Ram 1500
    I know it's not the same, but I am running a Ram crew with a 6'4 bed and it is tight.
  3. May 19, 2023 at 12:53 PM
    #2023
    Voltron4x4
    Voltron4x4 [OP] Well-Known Member
    Denver, Colorado
    2014 Black Trail Limo
    This and that...
    It’s definitely not post worthy but if you really want one I can. It’s just 5-6 pallets stacked with for casters on the bottom one. Have a spare tire on top for extra height and a soft base. Built it in about 10min.
  4. May 21, 2023 at 8:01 AM
    #2024
    shawnMc
    shawnMc Well-Known Member
    Shawn
    Santa Barbara
    2009 Tacoma regular cab 4x4
    Are you able to get the propane storage as an option separate from the heater and ventilation system? I'm interested in "outside" storage options.
  5. May 21, 2023 at 11:40 AM
    #2025
    Voltron4x4
    Denver, Colorado
    This and that...
    The propane storage is standard. You’ll get it without the propane stove/heater.
    magunha likes this.
  6. May 21, 2023 at 11:58 AM
    #2026
    Voltron4x4
    Denver, Colorado
    This and that...
    We have an awning for summer. Pretty simple design and strong. I’m using a 6x8 heavy duty tarp attached to the Kimbo with stainless steel pad eyes sealed with Sika Flex 221. Also using some adjustable tent poles.
    This set up can be completely taken down and stored. If the tarp starts to age it’s an easy and cheap replacement. With multiple eye loops it’s easy to adjust the size and have options to tie to trees. It’s also capable of positioning it further away from the camper if wanted using some cams. I’ll be using the eye hook to hang gear too. All this came to under $100.
    And you can also see my 10min Kimbo stand in use. o_O
  7. May 22, 2023 at 10:12 AM
    #2027
    magunha
    magunha Active Member
    Ford F150 6.5 box, KIMBO #248
    love it
  8. May 22, 2023 at 6:49 PM
    #2028
    HunterArdrey
    HunterArdrey Well-Known Member
    Hunter
    Carrollton GA
    2020 White TRD Sport.
    I’m the 4door short bed and have put over 7000 miles on mine in a month. Works great, I have no complaints.
  9. May 24, 2023 at 1:43 PM
    #2029
    Profloundering
    Profloundering Well-Known Member
    2020 DCLBOR
    RideRite airbags
    That is a cool idea - and the price is right!
    Have you thought about putting a length of PVC pipe across the mounting points (held in with the carabiners) with a slot cut lengthwise and slide the tarp through to keep the tarp from sagging in the middle?
    magunha likes this.
  10. May 25, 2023 at 6:20 AM
    #2030
    Voltron4x4
    Denver, Colorado
    This and that...
    That would certainly work or clipping through the grommets. Right now it's pretty tight but we'll see if it stretches over the summer. I believe the main difference between this DIY style and the store bought is the rigidly of the sides. With the DIY you'll need to stake it down or use what you have to anchor the two supports which is easy enough. The store bought design you would be fine until the wind picks up and then you would need to do the same. I feel like its a good pay off for not having something kinda permanent attached to the Kimbo.
  11. May 27, 2023 at 12:00 AM
    #2031
    Mini
    Mini New Member
    Tom
    It appears the payload is greatly increased on the 2024. One statement by Toyota said the ‘24 TRD off-road was 1709 # of payload, while the spec on same for 2023 is only 1135 #. If confirmed as details come out, that’s a huge difference and would make me wait on a 2024!
    Voltron4x4[OP] likes this.
  12. May 27, 2023 at 9:59 AM
    #2032
    TaKimbo
    That and the 2400w inverter are going to make a hell of a package. Unfortunately [and of course fortunately!] it looks like I’ll be picking up a Kimbo next weekend, and I currently don’t have a truck. Trying to find a couple year old taco, but used market is still a bit silly. So find myself leaning towards a new ‘23 AC to enjoy the Kimbo with for a year or two while the rush / kinks get sorted on the gen4.
  13. May 30, 2023 at 3:04 PM
    #2033
    colter121
    colter121 New Member
    2019 Tacoma TRD
    Hey! I had been slowly going through this thread reading a bunch of stuff and I saw you live in AK. I also live in AK and am planning on buying a Kimbo. I was wondering if you still live in AK if I could maybe just come take a look at it and see what it looks like in person? Would also love any feedback you have on how it is to camp in the winter with it here in AK. Thanks so much!
  14. May 30, 2023 at 11:37 PM
    #2034
    TaKimbo
    Might need to pick up the Kimbo before I’m able to do air bags / e-rated tires. Pretty sure I know the answer, but… any thoughts on if this is completely a no go for a couple hour drive?
  15. May 31, 2023 at 12:36 PM
    #2035
    Voltron4x4
    Denver, Colorado
    This and that...
  16. May 31, 2023 at 12:50 PM
    #2036
    Voltron4x4
    Denver, Colorado
    This and that...
    Tires would be the main concern, but if you are absolutely unable to get the tires just take it slow. Tires build up heat depending on the weather so be careful with the PSI. Kimbo did hold mine about a month until I was able to drive out. That might buy you some more time.
  17. May 31, 2023 at 1:01 PM
    #2037
    TaKimbo
    Yeah perhaps i can squeeze in tires if I can find them in stock somewhere, and then handle bags later. Appreciate the response. And buying from a private seller, so wanna grab it before it gets snagged from someone else :)
  18. May 31, 2023 at 1:33 PM
    #2038
    Voltron4x4
    Denver, Colorado
    This and that...
    Got it. Yeah the airbags can wait. SL tires would be a tense drive. Maybe go your second best pick for E-rated.
  19. May 31, 2023 at 1:55 PM
    #2039
    TaKimbo
    Re: tires, I’ll be stuffing whatever i get onto stock ‘23 Sport wheels. Trying to figure out if I go 265/65/17 or 265/70/17. Once again, thanks if anyone has suggestions. This thread has been an amazing resource.
  20. May 31, 2023 at 2:14 PM
    #2040
    Voltron4x4
    Denver, Colorado
    This and that...
    I went 245/75/17 so 31.5in. They are under 50lbs and help a little with traction in certain conditions being a skinny. They are on TRD Sema wheels and spacers though so they get pushed out a little. I can fit larger but fuel economy is a factor of course. A wider tire would help with stability I'm guessing with a stock setup, just a little heaver tire.
