kinda squirrely at freeway speeds, steering dampener?
Discussion in '1st Gen. Tacomas (1995-2004)' started by sep, Mar 4, 2010.
  1. Mar 4, 2010 at 9:33 AM
    sep
    sep [OP] Member
    San Luis Obispo, CA
    2003 Prerunner
    Hi guys, my 03 prerunnner has king coils in the front and 3 link rear, its set up pretty soft. Yesterday doing 75 in the rain, the steering gets kinda twitchy and small adjustments cause lots of body roll. Any way to fix this with say, a steering dampener? My alignment and tire rotation are all normal, but driving freeway speeds gets kinda hairy. thanks
  2. Mar 4, 2010 at 9:49 AM
    sethr21785
    sethr21785 Well-Known Member
    Seth
    Lake Jackson TX
    00 Tundra
    what size tires do you have?? You can always get a bigger dampener. I put a heavy duty one on my wrangler
  3. Mar 4, 2010 at 10:11 AM
    sep
    sep [OP] Member
    San Luis Obispo, CA
    2003 Prerunner
    265/75r16
    i bought this truck used, the tires do seem slightly larger than stock.
  4. Mar 4, 2010 at 11:33 AM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    its just cus your suspension is super soft. you could dampen it but i honestly dont think its going to help. my suspenions real soft and its real twitchy going fast. just gotta have smooth hands
  5. Mar 4, 2010 at 11:40 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Did you install UCAs? If not then your caster can be too low and cause poor handling at higher speeds. Also, do you have the Sway bar still?
  6. Mar 4, 2010 at 11:56 AM
    sep
    sep [OP] Member
    San Luis Obispo, CA
    2003 Prerunner
    just went out and checked, stock UCAs, still has sway bar.
    found this online:
    "With too little positive caster, steering may be touchy at high speed and wheel returnability may be diminished when coming out of a turn."
    this is exactly what im experiencing. if i take my truck to a shop, could they fix this pretty easily?
  7. Mar 4, 2010 at 11:59 AM
    GSRON
    GSRON Well-Known Member
    Ron
    Northern CA
    2019 TRD OR Cement
    Quikfix seat risers and lic plate mount, MESO interior and stage 1 tails, glove box and console dividers, shelf for center console, FACTOR 55 hitch link, TC bed stiffeners, OE bed mat,
    In this case a steering stabilizer would be a band-aid on a bigger problem. Unless your trying to stop kick-back from really big tires (and your not) it won't solve your problem. It will just hide it at best.
  8. Mar 4, 2010 at 12:10 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You just bought the truck.... was that your first time on the highway with it?
    If yes...then the truck was probably like that when you bought it and it wanders simply because of the suspension setup on it.
    Does it have coil springs in the rear? IFS front?
    Got any pictures?
    Sounds like its a baja style truck and I'm guessing it's the nature of the beast when it comes to that suspension. Hell....we owned a Jeep Grand Cherokee that has solid axles & coil suspension from the factory and that thing feels floaty.
    Check all your steering components, ball joints, etc. Also, check the rear suspension components - make sure nothing is loose or coming apart.
  9. Mar 4, 2010 at 12:14 PM
    sep
    sep [OP] Member
    San Luis Obispo, CA
    2003 Prerunner
    here's some pictures, i was kinda hoping i could just make small improvements, long drives take a toll when i start losing concentration. but oh well, that's what 5hr energy is for right? =)
    [​IMG][​IMG][​IMG]
  10. Mar 4, 2010 at 12:22 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    You need upper control arms to fix the problem.
  11. Mar 4, 2010 at 12:39 PM
    sep
    sep [OP] Member
    San Luis Obispo, CA
    2003 Prerunner
    what kind of aftermarket uca do you recommend? id rather not spend a million dollars to fix a slight annoyance, but if its cheap enough ill pull the trigger.
  12. Mar 4, 2010 at 12:52 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    They are not very cheap. $528 for the set.
  13. Mar 4, 2010 at 12:53 PM
    sep
    sep [OP] Member
    San Luis Obispo, CA
    2003 Prerunner
    ah yeah i just found that set on wheelersoffroad, hmm does look pretty good though. thanks for the help!
  14. Mar 4, 2010 at 2:25 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    At the very least take it in, and get the camber set to where it's supposed to be. I'd say you've got a bunch of little problems, that are causing your wandering problems.
    UCA's that aren't up to the task
    Camber probably way off
    Rear suspension that's way softer than stock, causing the truck to ride nose high at speed, worsening your camber problem
