kinetik battery
Discussion in '2nd Gen. Tacomas (2005-2015)' started by l_prettyman, May 25, 2010.
  1. May 25, 2010 at 9:40 AM
    l_prettyman
    l_prettyman [OP] Well-Known Member
    Logan
    Maryland
    18 TRD Offroad
    can a kinetik 2000 battery be used under the hood as a primary battery?? i have one laying around and i have been thinking of using it as primary. is it possible?
  2. May 25, 2010 at 10:03 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    No way, it will never work. You should just go ahead and send that battery to me. Thanks.
  3. May 25, 2010 at 10:36 AM
    l_prettyman
    Logan
    Maryland
    18 TRD Offroad
    it honestly wont work? and make an offer on it
  4. May 25, 2010 at 10:41 AM
    Agent7
    Agent7 Senior Executive of Nothing.
    Toronto, Canada
    07 Tacoma TRD Sport 4x4 6spd
    BHLM, Stubby Antenna, Custom Front Grill, Debaged Tailgate, Added TRD Emblem, Removed Factory Pinstripes, Leer 100XL Cap, Prolumen 6000K HID Kit with custom glare shields, Eurolite Yellow fog lights, 20" Fast Hustler wheels (black w/3" deepdish polished lip), Cooper Zeon LTZ 275/60/20's, Spidertrax 1.25" Wheel Spacers, Custom LED Gauges, Pioneer AVIC F700BT All-In-One Indash Navigation (Hacked)
    He was being sarcastic, because it's a sweet battery, and yes it will work as a main.
  5. May 25, 2010 at 10:52 AM
    l_prettyman
    Logan
    Maryland
    18 TRD Offroad
    not too much power going through the system?
  6. May 25, 2010 at 10:57 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    the system will only draw what it needs.
    the battery has an ability to put out 2000 watts, but that doesn't mean as soon as you hook it up it'll dump as much as it can into the system
  7. May 25, 2010 at 10:58 AM
    l_prettyman
    Logan
    Maryland
    18 TRD Offroad
    ah good deal. i cant wait to hook it up tonight
  8. May 25, 2010 at 7:44 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I'm sure I'm going to make someone mad but this battery is pure snake oil IMO. It's more marketing then performance.
    They hide behind words like "power cell". Every damn battery is a power cell. They use something that audio nuts can relate to - 3800 watts. Audio guys like lots of "watts" in the equipment. The watts the battery has is available total watt hours or in other words AMP hours which is battery speak. It is NOT continuous watts. 3800 watts in a 12V battery is 317 amps, which for a auto or deep-cycle battery is quite normal. Also this is nothing more than a deep-cycle AGM (Absorbed Gas Mat) battery which is twice as expensive for the same wattage/amp hours as a good old walmart battery. A AGM battery is used for equipment that doesn't stay upright like airplanes and some boats. If your truck goes upside down you have bigger problems then needing a loud stereo.
    Also regardless on what they tell you, a charging system in a vehicle is not designed for a deep-cycle battery - especially an AGM. They say the alternator can't supply enough power so you need the battery. Where do you think the battery gets it's charging current from?
    Now all that being said, AGM batteries might have a place in the trunk of a car where hydrogen gas from charging regular lead-acid batteries might become explosive. An engine compartment is hot and is bad for AGM batteries. They are sensitive to abuse. My Tacoma doesn't have a trunk.
    See http://www.batteryfaq.org/ in the section "7. WHAT DO I LOOK FOR IN BUYING A NEW BATTERY?"
    I'm just trying to save you some hard earned money for some other mod. No offense is intended.
  9. May 25, 2010 at 8:33 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    ^^^^ very good info.
    it won't save him money though since he already has the battery laying around.
    but yes, there is a good reason that an optima yellow top is not an ideal choice for a primary battery, but a red top will work great.
    Logan,
    it is still safe to run this battery, Knayrb is just saying that there are much better options
  10. May 26, 2010 at 10:37 AM
    l_prettyman
    Logan
    Maryland
    18 TRD Offroad
    thanks, with his post i was getting worried, but like i said this battery was for an old audio system in my car.
