King 2.5 Extended Travel has Violent Full Extension
Discussion in 'Suspension' started by ArizonaNativ, Sep 6, 2019.
  1. Sep 6, 2019 at 4:55 PM
    ArizonaNativ
    ArizonaNativ [OP] Well-Known Member
    Tucson
    I installed 2.5 king resi's on the front of my 15 tacoma. No aftermarket bumper so vendor recommended keeping the 600 spring. I cranked the coils 3 turns to achieve a lift because they came setup for leveling a stock truck.
    When I hit speed bumps or dips in the road the shock goes to extend, then its almost like there is no top out bumper or rebound and it slams into the end of its travel in a very violent feeling motion.
    This even happens when I am crawling over <5 mph the aggressive speed bumps in my complex.
    Anyone else with experiences like this?
  2. Sep 6, 2019 at 4:59 PM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    Have you reached out to the seller?
    Do you have aftermarket bump stops? What UCAs do you have?
    DavesTaco68 likes this.
  3. Sep 6, 2019 at 5:03 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Did you tighten the collar after adjusting
    Gunshot-6A likes this.
  4. Sep 6, 2019 at 5:04 PM
    ArizonaNativ
    Tucson
    I have not reached out to the seller, I wasnt really thinking the shocks were bad.
    Have SPC UCAs and alignment has been checked a couple times this year.
    No aftermarket bumps, I guess I should gopro the problem it feels so much like extension but I guess it is possible I am hitting the bumps hard on compression.
  5. Sep 6, 2019 at 5:05 PM
    ArizonaNativ
    Tucson
    Yes the collar it torqued to King Spec. and I have checked all bolts in the front end system.
  6. Sep 6, 2019 at 5:06 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Your shocks won’t unload like that while crawling <5mph so you might be slightly exaggerating.
    600 pound springs are pretty soft, to me it sounds like your are driving way too fast, the only way you get rapid extension is when a tire goes airborne very fast.
  7. Sep 6, 2019 at 5:07 PM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    they will if they are shot
  8. Sep 6, 2019 at 5:08 PM
    YSL
    YSL Well-Known Member
    Socal
    MB 2019 TRD Pro
    are you talking about when you are coming out of the bump as in; the suspension extending back out there is a sound? or while it is being compressed?
  9. Sep 6, 2019 at 5:08 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I've had Icon and king on my truck. Personally I think king down travel is rough
  10. Sep 6, 2019 at 5:09 PM
    YSL
    Socal
    MB 2019 TRD Pro
    my down travel was pretty bad until I lowered the front down a bit to 2.25" lift. it's now smooth and no more thud going over speed bumps or potholes.
  11. Sep 6, 2019 at 5:10 PM
    ArizonaNativ
    Tucson
    I can tell you they are unloading like that. If I am going faster then 5mph it is certainly no more then 10mph but seriously 5mph is more realistic, like having to hit the gas to go completely go over the speed bump slow.
  12. Sep 6, 2019 at 5:13 PM
    ArizonaNativ
    Tucson
    Hmmm interesting. I did wait for the suspension to settle when new before cranking the 3 turns, and I couldn't recall if I had this issue but sounds like maybe I acquired this issue when raising to the approximately 3 inch range..
  13. Sep 6, 2019 at 5:14 PM
    ArizonaNativ
    Tucson
    They have 10k miles on them with most of that being highway. No leaks, I would be surprised it they were somehow shot.
  14. Sep 6, 2019 at 5:15 PM
    YSL
    Socal
    MB 2019 TRD Pro
    measure your coilovers from the the top hat to the center of the bottom bolt holding it in place; should be 21"-21.5" to be safe and not have to deal with your violent down travel.
    71tattooguy and hoverlover like this.
  15. Sep 6, 2019 at 5:15 PM
    ArizonaNativ
    Tucson
    Coming out of the bump, when the shock hits full extension. almost feels like the front tires bound of the ground sometimes and I am talking at real low speeds.
  16. Sep 6, 2019 at 5:16 PM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    Ive seen stranger things with new parts
  17. Sep 6, 2019 at 5:16 PM
    YSL
    Socal
    MB 2019 TRD Pro
    I had the exact same issue when raised to ~3", lowered a bit and problem solved.
  18. Sep 6, 2019 at 5:19 PM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    too much pre load.
    uncrank those 3 turns you did there..
    Hami0528, VanDoom, hoverlover and 2 others like this.
  19. Sep 6, 2019 at 5:26 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I have the same issue with my ADS. I think they are cranked up too high so the down travel is a bit short. Also the preload adds more force to the rebound. But it happens over any sharped edged bump or any time the suspension unloads quickly (regardless of my speed). It’s kind of annoying but I also don’t want to lower them.
  20. Sep 6, 2019 at 6:00 PM
    JoeCOVA
    Joe
    Colorado Springs
    I’m curious to what you are actually lifted to. Can you post some pics of your suspension. Maybe you are driving around maxed out.
