King 2.5x8" Coilover W/ Resi
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by jjhitchen, Jun 27, 2013.
  1. Jun 27, 2013 at 2:51 PM
    jjhitchen
    jjhitchen [OP] Relentless
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    Sold!
  2. Jun 27, 2013 at 2:54 PM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    Won't fit on 4wd trucks? Or just with your LT kit?
  3. Jun 27, 2013 at 3:02 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    The bottom of the coilover needs to have the spacer at the bottom (forget what it's actually called) but it allows the cv's room to go by into the hub...
    OP are you able to have a shop swap them out?
  4. Jun 27, 2013 at 3:06 PM
    BulletToothTony
    Look at the bottom of my coilovers that's what I was referring to.
  5. Jun 27, 2013 at 3:06 PM
    xgalvanxgx
    xgalvanxgx seymour butts
    Gerardo
    OC (Lake Forest) California
    TRD Off-Road BlackSandPearl 07 PreRunner
    DTF Race Kit with 2.5 x 10 Kings, DMZ SUA rear with 16" triple bypass Kings, King bumpstops front and rear, 17" KMC RG1 powdered in Matte Bronze with black ring with 37" BFG KO2s, front and rear DTF bumpers, front Fiberwerx glass and Mcneil trophy bedsides, K&N 77 Series Intake, Magnaflow, Pioneer touchscreen, Rockford Fosgate 10" sub with box and amp. Dyanamat walls, Andres' devil horn emblem, 50" D4 curved LED bar, rear chase light rack (brake, ambers, white lights) Engine brace, deleted inner wheel wells for max up travel. Cab roll rage built into bedcage.
    where were you like 2 weeks ago! :annoyed:
  6. Jun 27, 2013 at 3:06 PM
    jjhitchen
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    I need a one inch extended rod end on the kit im using to clear the tie rods and 4wd axles
  7. Jun 27, 2013 at 3:07 PM
    jjhitchen
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    I thought i needed these 2 weeks ago!!! sorry dude!
  8. Jun 27, 2013 at 3:07 PM
    jjhitchen
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    bingo
  9. Jun 27, 2013 at 3:17 PM
    Monster Coma
    Corey
    Ahh gotcha I see whatcha mean. Bummer
  10. Jun 27, 2013 at 3:50 PM
    jjhitchen
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    Yeah its a drag but no big deal, hopefully somebody can use these
  11. Jun 27, 2013 at 4:05 PM
    jjhitchen
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    I looked into swapping parts because the rod ends do unscrew but there were a few other things i needed so it just makes more sense to sell these and find another pair that are set up for 4wd right away
  12. Jun 27, 2013 at 11:25 PM
    jjhitchen
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    Night night bump
  13. Jun 28, 2013 at 1:08 PM
    jjhitchen
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    lunch bump
  14. Jul 6, 2013 at 8:56 AM
    jjhitchen
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    Shocks are freshened up with some new oil and ready to sell, BUMP!!!!
  15. Jul 6, 2013 at 10:02 AM
    Infamous Coating
    Infamous Coating Well-Known Member
    Avondale, AZ
    2012 Tacoma prerunner
    4" Maxtrac spindles and a 2" block on the rear
    Do these come with the top mount and res mounts?
  16. Jul 6, 2013 at 6:35 PM
    jjhitchen
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    Top plate adapters would be needed to bolt into the coil buckets but they are simple to make and resi mounts are something you would have to make but it is very easy.
  17. Jul 6, 2013 at 10:33 PM
    in2nite
    in2nite Well-Known Member
    James
    SoCal.
    blk 07 prerunner
    Engage Offroad L/T front and rear, Kings and 50t pack, Hella 4000's, Pro Comp Wheels and tires
    Joel put them up on Dezert Rangers and on Facebook Socaltacomas. They will be gone pretty quick.
  18. Jul 7, 2013 at 9:39 AM
    jjhitchen
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    I have top mount brackets for these that I will include, so you just need a hose clamp for the resi
  19. Jul 7, 2013 at 9:40 AM
    jjhitchen
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    They are on Dezert Rangers and Race Dezert right now! Thank you James.
  20. Jul 7, 2013 at 12:20 PM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
    bummppppp.
