*King 2.5x8" Long Travel Coilovers New*
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Tacomoto23, Apr 16, 2017.
  1. Apr 16, 2017 at 11:51 PM
    Tacomoto23
    Tacomoto23 [OP] Well-Known Member
    Carey
    Torrance,CA
    21’ TRD 4x4
    New in box King 2.5x8" coilovers. Valved and spec'd for a Camburg LT kit.
    Specs:
    500lb springs
    +2" rod ends
    Over cap top cap
    90 degree hose fitting
    Ordered these for my long travel kit but went a different route.
    -These will not fit with your stock or uniball upper control arms.
    -$1350
    -Located in Torrance, CA. Local pickup has priority, shipping on buyer.
    DustStorm4x4 likes this.
  2. Apr 17, 2017 at 7:06 AM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
  3. Apr 17, 2017 at 8:23 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Thanks Brian but these are for long travel setup I can't use these. Plus I already have fronts installed
    Trident904 likes this.
  4. Apr 17, 2017 at 8:32 AM
    virvak2
    virvak2 Well-Known Member
    Kyle
    Castle Rock
    '13 TRD Off-Road
  5. Apr 17, 2017 at 8:33 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
  6. Apr 17, 2017 at 8:42 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
  7. Apr 17, 2017 at 8:46 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Im guessing TC and Camburg have different coilover fitments right?
  8. Apr 17, 2017 at 8:58 AM
    Tacomoto23
    Carey
    Torrance,CA
    21’ TRD 4x4
    Yessir. It's the top cap design that's different.
    Coot83[QUOTED] likes this.
  9. Apr 17, 2017 at 9:01 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Ah oh well, good to know for sure!
  10. Apr 17, 2017 at 9:39 AM
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    Both use a cap over shock
  11. Apr 17, 2017 at 9:44 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    But are they the same top cap specs?
  12. Apr 17, 2017 at 9:49 AM
    glorifiedwelder
    jason
    Santa Clarita, ca
    Yeah their is only one cap over style. Only difference I see is that tc sells their c/o's with 600lb springs. I thought camburg was the same but I guess not
  13. Apr 17, 2017 at 9:52 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Is it just me or is 500 pretty soft? I think my 600lb springs ride pretty nice.
    bski22 and Justinlhc like this.
  14. Apr 17, 2017 at 10:02 AM
    glorifiedwelder
    jason
    Santa Clarita, ca
    I'd talk to camburg or tc. I've never used 500lb but depending on vehicle weight they probably will be just fine
  15. Apr 17, 2017 at 10:18 AM
    Tacomoto23
    Carey
    Torrance,CA
    21’ TRD 4x4
    Not to get the two mixed up, top cap meaning mounting cap.
    On the King shocks,Total Chaos uses the "oem style" mounting top where Camburg uses the plate design.
  16. Apr 17, 2017 at 10:19 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Ah that makes perfect sense!
  17. Apr 17, 2017 at 10:20 AM
    Tacomoto23
    Carey
    Torrance,CA
    21’ TRD 4x4
    Since I'm running Camburg's 4" lift spindles as well, I opted for a 500lb coil rather than a 600lb for a lower ride height.
  18. Apr 20, 2017 at 7:46 PM
    erok81
    erok81 Well-Known Member
    Imposter
    Must keep fingers off letters w a n t. If they only had 700lb springs.
    Tacomoto23[OP] likes this.
  19. Apr 20, 2017 at 8:09 PM
    Tacomoto23
    Carey
    Torrance,CA
    21’ TRD 4x4
    You already are LT front though aren't you?
  20. Apr 21, 2017 at 4:42 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Dude isn't that kind of stiff for LT?
