King 25001-119 spherical bearing replacement?
Discussion in 'Suspension' started by SR-71A, Sep 15, 2022.
  1. Sep 15, 2022 at 1:54 PM
    SR-71A
    SR-71A [OP] Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Has anyone replaced the lower spherical bearings on King coils for our trucks (2nd or 3rd gens) with aftermarket?
    Mine are shot and Id like to replace them asap before a big trip in Oct. I have a few emails out to folks like PolyPerformce to see what leads times are on King OEM replacement parts. Poly also sells FK Bearings. Looks like a good replacement with good reviews, I just need to know the size.
    Anyone happen to know the size?
    https://www.polyperformance.com/fk-rod-ends-com-commercial-series-bearings
    WrecklessAbandon likes this.
  2. Sep 15, 2022 at 10:20 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    @WrecklessAbandon just bought 3 trucks worth of these... where from?
  3. Sep 16, 2022 at 7:25 AM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    msgs350 and Bertw192[QUOTED] like this.
  4. Sep 16, 2022 at 8:02 AM
    SR-71A
    Zack
    Southern Maine
    Thank you sir! And yes good point I guarantee mine are fused as well :rolleyes:
    Looks like the King P/N for those is KRS-25017-032?
  5. Sep 16, 2022 at 8:50 AM
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    I think the spacer you are looking for is KRS-25016-006
    SR-71A[OP] likes this.
  6. Sep 16, 2022 at 9:33 AM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I hope so, because that's what @AccuTune Offroad sold me...
  7. Sep 16, 2022 at 9:55 AM
    SR-71A
    Zack
    Southern Maine
    Awesome thanks guys. Thats my biggest complaint with King, not easy to find info on them which makes it difficult to service properly
  8. Sep 18, 2022 at 8:23 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
  9. Sep 19, 2022 at 8:32 AM
    SR-71A
    Zack
    Southern Maine
    Interesting. Didnt think to look at a different manuf. Makes sense they are all the same size.
    Any issues with the Icon spacers offsetting the bearing, vs Kings centered design?
    Thanks to @NocturnalTaco for the very helpful quote from another thread
  10. Sep 19, 2022 at 8:45 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^If you're running the sway bar, Icon's instructions put the longer spacer in front for clearance. If you ditched the sway bar, I'd run the longer spacer in the rear for more clearance to the CV axle. The bolt head needs to be on the same side as the short spacer, so the weight isn't coming down on the reduced diameter portion of the shank.
    The spirolox retaining rings in the Icon kit don't require snap ring pliers. Two pocket screwdrivers or picks work well.
    IvanhoeTaco likes this.
  11. Sep 19, 2022 at 9:20 AM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Kings run equal length spacers.
  12. Sep 19, 2022 at 9:42 AM
    SR-71A
    Zack
    Southern Maine
    Because of that Id think running Icon spacers in a King shock would tweak the entire thing a bit and put some twist on the upper joint? Probably not a big deal but idk.
    I need to go back and find the thread that talked about replacing the lower OEM bolt with one that isnt shouldered
    3JOH22A[QUOTED] likes this.
  13. Sep 19, 2022 at 9:44 AM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    There's a pivot at the top of the shock, so maybe it wouldn't matter...
    :notsure:
    But I wouldn't run anything outside of King's spec.
    SR-71A[QUOTED][OP] likes this.
  14. Sep 19, 2022 at 10:04 AM
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    I haven't done the math but with the size of the spacers, I assume this be a less than 1° difference. I do agree about running king spec just to be safe though. There are king kits out there for about the same price as the icon kit.
  15. Sep 19, 2022 at 10:19 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    The upper joint is the same heim bearing so no issues, no added bending loads on the shock shaft.
  16. Sep 21, 2022 at 7:51 AM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    I also sell bearing and spacer kits for Fox, King, Icon in different grades of bearings from FK. They all have an F1 fit which is going to be the tightest to start with and give the longest service life. I include longer lasting coated C Clips that are easier to work with than the Spiralocs after they are rusted together.
    FKSS10T
    https://www.303shockservices.com/pr...-coilover-lower-mount-replacement-bearing-kit
    FKS10T
    COM10T
    https://www.303shockservices.com/product-page/2-5-coilover-lower-mount-replacement-bearing-kit
    TW10 for 10% off.
    mtnkid85, Shveet, a2lowvw and 7 others like this.
  17. Sep 21, 2022 at 8:56 AM
    SR-71A
    Zack
    Southern Maine
    Awesome man. Actually just replied to your email. If Id known you had a whole kit with stainless steel FK bearings I would have just ordered that right from the start and been done with it. As it is I already have regular bearings and clips, just need the spacers.
    TMFF[QUOTED] likes this.
  18. Sep 22, 2022 at 3:29 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    Is the price difference between the 3 due to the bearings? I need to order up a set and curious of the differences between the 3.
    Thank you.
  19. Sep 22, 2022 at 12:32 PM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    Correct.
    COM - Low carbon steel
    FKS - alloy steel
    FKSS - stainless steel
    FK has more info in their website. https://www.fkrodends.com/products/spherical-bearings/
    ClassyTacos[QUOTED] likes this.
  20. Sep 22, 2022 at 7:50 PM
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    I ordered COM10T bearings because I didn't know better....did I mess up? Are the FKS and FKSS worth the additional cost? What bearing do fox/king/icon/ads come standard with?
    ClassyTacos likes this.
