King 25001-119 spherical bearing replacement?
Discussion in 'Suspension' started by SR-71A, Sep 15, 2022.
  1. Nov 10, 2022 at 3:32 PM
    #41
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    Remove coilover, remove both C clips, prop coilover on a 2x4, find correct size socket, hammer out bearing. Drink a beer. Hammer in new bearing, put C clips back in, reinstall coilover. Drink a beer.
    Do the same thing for the other side.
    Celebrate by drinking another beer.
    TVH475, Naveronski, medicfung and 2 others like this.
  2. Nov 10, 2022 at 3:34 PM
    #42
    TB7
    TB7 Member
    Tarik
    2019 Cement Tacoma TRD Off-Road
    -Front: SPC UCAs, Dirt King LCAs -Rear: OME Dakar Heavy Leafs -2.5" King Shocks + Reservoirs Front + Rear -C4Fabrication Front & Rear Bumpers + Sliders -Prinsu Cab Rack, Leitner Classic Bed Rack -Decked Drawer System -Baja Designs 30" Bar, Amber Corners & Fogs -1552 Analog HD Wheels + 33s
    Well Fuckin A... color me excited.
    Thanks bud.
  3. Nov 10, 2022 at 3:58 PM
    #43
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    :cheers:
  4. Nov 11, 2022 at 7:19 AM
    #44
    SR-71A
    SR-71A [OP] Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Unfortunately I've been way too busy, haven't gotten to this yet. Living in the NorthEast mine are in pretty rough shape rust-wise. Im anticipating possibly needing to use the shop press. Seems like it should be an easy enough job though if you dont live in a state that uses road salt and calcium chloride like its going out of style :rolleyes:
  5. May 19, 2024 at 9:17 PM
    #45
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    TMFF[QUOTED] likes this.
  6. May 20, 2024 at 3:15 AM
    #46
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
  7. Sep 17, 2024 at 7:19 PM
    #47
    hingerat
    hingerat Member
    2016 Taco
    Orange Virus
    Been working on replacing my bearings for a couple weeks now and have been struggling with corrosion. The LCA bolt seized to the spacers and would free spin but not move. The solution was to cut the forward sleeve on the LCA, seized too, and drop the whole thing between the axle and steering arm, then cut the bolt. Bought the 303 bolt/bearing kit so good there. But, damaged the rod end in the process and having a lot of trouble removing the circlips to push the bearing.
    Does anyone know the rod end part number to replace with? Needless to say everything is going back together with anti-seize!!!
  8. Sep 22, 2024 at 1:56 PM
    #48
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    How is the rod end damaged? That's a tricky part to replace without shaft clamps and a good spring compressor.
  9. Sep 22, 2024 at 2:34 PM
    #49
    hingerat
    hingerat Member
    2016 Taco
    Orange Virus
    Damage is cosmetic but the bearing is sized in the eye in the passenger side, driver’s side still has a portion of the bolt and spacers from where I had to cut them out. The circlips are now captive by the bolt/spacer combination.
    Didn’t realize the rod end was so difficult to replace.
  10. Sep 22, 2024 at 7:10 PM
    #50
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    Get some picks and small flat head screwdrivers, with some work you can usually get the C-clips out even with the spacers rusted in.
    SR-71A[OP] likes this.
  11. Sep 23, 2024 at 5:44 AM
    #51
    SR-71A
    Zack
    Southern Maine
    Yup. Heat, penetrating oil, and picks you can get it out
    Once both clips are out I think you should be able to press the entire thing out, bolt and all. Could be wrong but as I recall the spherical bearing is the largest diameter
