King 3.0s Stock LCA’s?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Totoya4x4, Apr 24, 2023.
  1. Apr 24, 2023 at 8:00 AM
    Totoya4x4
    Totoya4x4 [OP] Member
    2022 Tacoma TRD Sport DCLB, 3.0 King Off-Road Racing Shocks, ICON AAL, Element UCA’s
  2. Apr 24, 2023 at 11:36 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
  3. Apr 24, 2023 at 11:46 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    They definitely do - if you recently won the lottery...
    OP to answer your question, the lower end looks the same to me as the 2.5s so it might work. But I dont have any direct experience with them. I know there are one or two folks on here running them.
    Interesting, looking at the pics of that kit I dont see any threads for preload adjustment like all the common 2.5s have
    Edit: I see now its adjustable on the bottom end of the shock under the coil. Interesting
  4. Apr 24, 2023 at 12:05 PM
    gudujarlson
    Minnesota
    I don’t think accutune or headstrong sell a King 3.0 for a Tacoma. I see a King 3.0 OEM replacement shock sold on 4wheelparts, but when I google the part number I get hits for Fords.
    https://www.4wheelparts.com/p/king-...oir-coil-overs-33001-207a/_/R-FBJG-33001-207A
    I could not find anything useful on King’s site.
    In any case, I personally see no reason to put 3.0’s on a Taco unless you are building a long travel race truck and in that case you should already know the answer to the question
    a2lowvw likes this.
  5. Apr 24, 2023 at 12:07 PM
    SR-71A
    Zack
    Southern Maine
    33001-209A
  6. Apr 24, 2023 at 12:15 PM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    with the cost difference from the 2.5’s to the 3.0’s and no additional travel/lift it sure doesn’t make sense to me.
  7. Apr 24, 2023 at 12:17 PM
    gudujarlson
    Minnesota
    In any case, I believe even the 2.5s require a UCA and sway bar relocation kit due to the increased outer spring diameter. I’m not 100% sure because my kit came with both.
  8. Apr 24, 2023 at 12:37 PM
    Totoya4x4
    I’m not even planning to build a race truck, I just want to be somewhat different and I like the beefier look of the front and rear 3.0s, and if I do plan on doing long travel I can keep using those until I can no longer rebuild them
  9. Apr 24, 2023 at 12:39 PM
    gudujarlson
    Minnesota
    I don’t think OEM spec shocks work with long travel kits unless you are willing to give up travel.
    I suggest asking your questions in the long travel form. You are getting into race truck territory and not many people in this forum take if that far.
    https://www.tacomaworld.com/forums/long-travel-suspension.113/
    Jojee117 and Chew like this.
  10. Apr 24, 2023 at 12:43 PM
    Totoya4x4
    I understand, I have the UCA’s, the diff drop kit, the add a leaf already installed on a 3 inch level. I just wanna know can I slap those shocks in place, or will I need to get something extra? Im trying not to do any sort of major cutting to my vehicle besides mounting the external reservoirs. I just want to do this correctly and once and not eff up my truck.
    GunthorNC likes this.
  11. Apr 24, 2023 at 12:47 PM
    gudujarlson
    Minnesota
    Slap them in and report back.
  12. Apr 24, 2023 at 12:50 PM
    gudujarlson
    Minnesota
  13. Apr 24, 2023 at 12:51 PM
    MGMDesertTaco
    SR-71A likes this.
  14. Apr 24, 2023 at 12:54 PM
    gudujarlson
    Minnesota
    Also, it would help if you told us the part number and/or linked the shocks you are talking about. Otherwise we are left making assumptions.
  15. Apr 24, 2023 at 12:57 PM
    gudujarlson
    Minnesota
  16. Apr 24, 2023 at 1:07 PM
    SR-71A
    Zack
    Southern Maine
    Im telling you 33001-209A is the part number. Google it... You'll see Downsouth, SDHQ, Filthy, Poly Performance, etc selling them for Tacos.
    I think the idea behind the larger diameter and finned resi is heat dissipation and much larger oil capacity for extended high-speed type of stuff. Soooo realistically most folks wont see any benefit from them
    medicfung likes this.
  17. Apr 24, 2023 at 1:08 PM
    gudujarlson
    Minnesota
    That doesn’t mean the OP is talking about that part number. There are also universal fit king 3.0s. I believe you made an assumption?
  18. Apr 24, 2023 at 2:40 PM
    Totoya4x4
    I know that they make King 3.0s for the 2016+ Tacomas, I’m not worried about that part. Will the ones made for the Tacoma fit on the stand Lower Control Arms/ Stock Length or not. If so do I have to do ANYTHING ELSE besides drilling holes to mount the external reservoirs?? P.S. I have the 3 inch lift level, done correctly, dropped diff, added uniball UCA’s (Element Hard Parts) for the front. Rear did the ICON add-a-leaf. All in all I could care less ab the rear. I just wanna know about the front.
  19. Apr 24, 2023 at 2:42 PM
    Totoya4x4
  20. Apr 24, 2023 at 2:43 PM
    Totoya4x4
    Here are the rears.
    https://caliraisedoffroad.com/produ...-tube-remote-reservoir-bypass-shock-33001-210
